in my attempt to reproduce the plasticity demo from dolfiny in dolfinx, I ran into convergence problems of NewtonSolver (which I used instead of the snes block solver). For debugging, I tried to have a look at the jacobian, but can’t because of ArityMismatch.
This is my MWE:
from dolfinx import log
from dolfinx import fem, mesh
import basix
from dolfinx.fem import locate_dofs_geometrical
from basix.ufl import mixed_element
# Define mesh
L = 20.0
domain = mesh.create_box(MPI.COMM_WORLD, [[0.0, 0.0, 0.0], [L, 1, 1]], [1, 1, 1], mesh.CellType.tetrahedron)
Ue = basix.ufl.element("P", domain.basix_cell(), 1, shape=(domain.geometry.dim,))
He = basix.ufl.quadrature_element(domain.basix_cell(), value_shape=(), degree=1)
Te = basix.ufl.blocked_element(He, shape=(domain.geometry.dim, domain.geometry.dim), symmetry=True)
V_el = mixed_element([Ue, Te]) # u, P
V = fem.functionspace(domain, V_el)
# Define boundaries
V0, _ = V.sub(0).collapse()
u_L = fem.Function(V0)
u_L.x.array[:] = 0.
u_R = fem.Function(V0)
u_R.x.array[1] = 0.1
dofs_L = locate_dofs_geometrical((V.sub(0), V0), lambda x: np.isclose(x[0], 0))
bc_L = fem.dirichletbc(u_L, dofs_L, V.sub(0))
dofs_R = locate_dofs_geometrical((V.sub(0), V0), lambda x: np.isclose(x[0], L))
bc_R = fem.dirichletbc(u_R, dofs_R, V.sub(0))
bcs = [bc_L, bc_R]
# Define functions
w = fem.Function(V)
u, P = ufl.split(w)
u0, P0 = ufl.split(w)
δw = ufl.TestFunction(V)
δu, δP = ufl.split(δw)
#Define physics
mu = fem.Constant(domain, 100.0)
la = fem.Constant(domain, 10.)
Sy = fem.Constant(domain, 0.300)
def rJ2(A):
"""Square root of J2 invariant of tensor A"""
J2 = 1 / 2 * ufl.inner(A, A)
rJ2 = ufl.sqrt(J2)
return ufl.conditional(rJ2 < 1.0e-12, 0.0, rJ2)
I = ufl.Identity(3) # noqa: E741
F = I + ufl.grad(u)
E = 1 / 2 * (F.T * F - I)
E_el = E - P
S = 2 * mu * E_el + la * ufl.tr(E_el) * I
S = ufl.variable(S)
f = ufl.sqrt(3) * rJ2(ufl.dev(S)) - (Sy)
g = f
dgdS = ufl.diff(g, S)
S = S.expression()
δE = ufl.derivative(E, w, δw)
dλ = ufl.max_value(f, 0)
dx = ufl.Measure("dx", domain=domain, metadata={"quadrature_degree": 4})
form = ( ufl.inner(δE, S) * dx + ufl.inner(δP, (P - P0) - dλ * dgdS) * dx)
J = ufl.derivative(form, w, δw)
jacobian = dolfinx.fem.form(J)
# A = dolfinx.fem.petsc.assemble_matrix(jacobian)
# def convertToDense(A_petsc):
# Convert the PETSc matrix to a dense numpy array
# for debugging purposes
# A_petsc.assemble()
# A_dense = A_petsc.convert("dense")
# # return (len(A_dense.getDenseArray()), len(A_dense.getDenseArray()[0]))
# return A_dense.getDenseArray()
# print(convertToDense(A))
# exit()
# log.set_log_level(log.LogLevel.INFO)
# problem = NonlinearProblem(form, w, bcs)
# solver = NewtonSolver(domain.comm, problem)
# solver.convergence_criterion = "incremental"
# solver.rtol = 1e-6
# solver.report = True
# num_its, converged = solver.solve(w)
# assert (converged)
Which produces the following errror:
File "/home/bjoern/examples/plasticity_beam_devel_perfect_plast_mwe.py", line 70, in <module>
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/forms.py", line 337, in form
return _create_form(form)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/forms.py", line 331, in _create_form
return _form(form)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/forms.py", line 254, in _form
ufcx_form, module, code = jit.ffcx_jit(
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/jit.py", line 62, in mpi_jit
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/jit.py", line 212, in ffcx_jit
File "/usr/lib/python3/dist-packages/ffcx/codegeneration/jit.py", line 205, in compile_forms
impl = _compile_objects(
File "/usr/lib/python3/dist-packages/ffcx/codegeneration/jit.py", line 330, in _compile_objects
_, code_body = ffcx.compiler.compile_ufl_objects(
File "/usr/lib/python3/dist-packages/ffcx/compiler.py", line 108, in compile_ufl_objects
analysis = analyze_ufl_objects(ufl_objects, options["scalar_type"]) # type: ignore
File "/usr/lib/python3/dist-packages/ffcx/analysis.py", line 94, in analyze_ufl_objects
form_data = tuple(_analyze_form(form, scalar_type) for form in forms)
File "/usr/lib/python3/dist-packages/ffcx/analysis.py", line 94, in <genexpr>
File "/usr/lib/python3/dist-packages/ffcx/analysis.py", line 180, in _analyze_form
form_data = ufl.algorithms.compute_form_data(
File "/usr/lib/python3/dist-packages/ufl/algorithms/compute_form_data.py", line 427, in compute_form_data
check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode)
File "/usr/lib/python3/dist-packages/ufl/algorithms/check_arities.py", line 213, in check_form_arity
check_integrand_arity(itg.integrand(), arguments, complex_mode)
File "/usr/lib/python3/dist-packages/ufl/algorithms/check_arities.py", line 194, in check_integrand_arity
arg_tuples = map_expr_dag(rules, expr, compress=False)
File "/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py", line 35, in map_expr_dag
(result,) = map_expr_dags(
File "/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py", line 103, in map_expr_dags
r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
File "/usr/lib/python3/dist-packages/ufl/algorithms/check_arities.py", line 78, in product
raise ArityMismatch(
ufl.algorithms.check_arities.ArityMismatch: Multiplying expressions with overlapping form argument number 0, argument is v_0.
It’s Fenicx 0.9 on WSL Ubuntu / Windows. Many thanks!
