I am trying to implement the example in this article [Lombardi, D., Pagliantini, C. (2024). Conformal variational discretisation of infinite dimensional Hamiltonian systems with gradient flow dissipation], specifically the one about solving Navier-Stokes in vorticity formulation on the torus.
For simplicity, for now I just want to solve M \dot{y}=-\nu K y where M is the mass matrix and K is the stiffness matrix. My aim is to build the M and K matrices using dolfinx_mpc (imposing pure periodic boundary conditions), then use an external time-stepping method for the ODE above (for now I just use solve_ivp, but ideally I would like to test my own method on this problem).
The issue I believe I am encountering is that the solution I obtain does not satisfy the periodic boundary conditions. Below a MWE.
I am quite new to Fenics, so any kind of insight is greatly appreciated.
from dolfinx import mesh
from dolfinx import fem
from dolfinx import plot
from dolfinx.fem import functionspace
from dolfinx_mpc import assemble_matrix
import dolfinx_mpc
import dolfinx_mpc.utils
import scipy as sp
import scipy.integrate as integ
import pyvista
# Function for the right hand side
def FOM(t, y):
out = np.zeros(N)
out = -nu * K @ y
out = sp.sparse.linalg.spsolve(M, out)
uh = fem.Function(mpc.function_space) # Create function to store solution
uh.x.array[:] = out
uh.x.scatter_forward()
mpc.backsubstitution(uh)
return uh.x.array
# Parameters
nu = 1e-2
lmb = 25
nx = ny = 20
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([2*np.pi, 2*np.pi])],
[nx, ny], mesh.CellType.triangle)
V = functionspace(domain, ("Lagrange", 1))
tdim = domain.topology.dim
fdim = tdim - 1
boundary_dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
# No Dirichlet boundary conditions
bcs = []
# Periodic boundary conditions
def top_boundary(x):
return np.isclose(x[1], 2*np.pi)
def right_boundary(x):
return np.isclose(x[0], 2*np.pi)
def periodic_relation_left_right(x):
out_x = np.zeros(x.shape)
out_x[0] = x[0] - 2*np.pi
out_x[1] = x[1]
return out_x
def periodic_relation_bottom_top(x):
out_x[0] = x[0]
out_x[1] = x[1] - 2*np.pi
return out_x
mpc = dolfinx_mpc.MultiPointConstraint(V)
mpc.create_periodic_constraint_geometrical(
V, right_boundary, periodic_relation_left_right, bcs
V, top_boundary, periodic_relation_bottom_top, bcs
mpc.finalize()
# Mass and stiffness matrices assembly
phi_i = ufl.TrialFunction(V)
phi_j = ufl.TestFunction(V)
k = ufl.inner(ufl.grad(phi_i), ufl.grad(phi_j)) * ufl.dx
m = ufl.inner(phi_i, phi_j) * ufl.dx
k_compiled = fem.form(k)
m_compiled = fem.form(m)
# Get Scipy analogues for K and M
K = dolfinx_mpc.utils.gather_PETScMatrix(assemble_matrix(k_compiled, mpc, bcs=bcs))
M = dolfinx_mpc.utils.gather_PETScMatrix(assemble_matrix(m_compiled, mpc, bcs=bcs))
# Define initial stream function
psi0 = fem.Function(V)
psi0.interpolate(lambda x: 0.25*np.cos(3*x[0])*np.sin(4*x[1]) - 0.2*np.cos(5*x[1]) - 0.2*np.sin(5*x[0]))
y0 = - lmb*psi0.x.array
# Solving the FOM
# Time stepping grid
T = 10
h = 0.01
t0 = np.arange(0,T,h)
L = t0.size
N = V.dofmap.index_map.size_global * V.dofmap.index_map_bs
Y = np.zeros((N, L)) # snapshot matrix
# solve the system with initial condition y0
sol = integ.solve_ivp(FOM, (0,T), y0, atol=1e-10, rtol=1e-10, t_eval=t0, method='LSODA')
Y = sol.y
# Visualizing the solution on the mesh
# Plot mesh
u_topology, u_cell_types, u_geometry = plot.vtk_mesh(V)
u_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
u_grid.point_data["u_ref"] = Y[:,-1]
u_grid.set_active_scalars("u_ref")
u_plotter = pyvista.Plotter()
u_plotter.add_mesh(u_grid, show_edges=True)
u_plotter.view_xy()
if not pyvista.OFF_SCREEN:
u_plotter.show()
# 3D plot
warped = u_grid.warp_by_scalar()
plotter2 = pyvista.Plotter()
plotter2.add_mesh(warped, show_edges=True, show_scalar_bar=True)
plotter2.show()
