Hi community,
I have an issue with implementation of a array as a function, the problem is about the assign of the nodal value with the array. The value calculated is correctly, but each value is assigned in wrong node. My code is below,
mesh = Mesh('meshp.xml')
xs = SpatialCoordinate(mesh)
#print (V.dofmap().entity_dofs(mesh, 0))
fkappa=Function(V)
mesh_points=mesh.coordinates()
#print(mesh_points)
fx_dofs = V.dofmap().dofs()
mn=len(mesh_points)
## calculate nodal curvature
dt=1.0
teta = np.zeros(mn)
#Calculate first derive
dx=np.zeros(mn)
dy=np.zeros(mn)
for nod in range(mn):
i=nod
teta[i]=dt*i
if i >0 and i < mn-1:
dx[i]=(mesh_points[i+1,0]-mesh_points[i-1,0])/(2*dt)
dy[i]=(mesh_points[i+1,1]-mesh_points[i-1,1])/(2*dt)
elif i == 0:
dx[i]=(mesh_points[i+1,0]-mesh_points[-1,0])/(2*dt)
dy[i]=(mesh_points[i+1,1]-mesh_points[-1,1])/(2*dt)
dx[i]=(mesh_points[0,0]-mesh_points[i-1,0])/(2*dt)
dy[i]=(mesh_points[0,1]-mesh_points[i-1,1])/(2*dt)
#Calculate second derive
ddx=np.zeros(mn)
ddy=np.zeros(mn)
i=nod
ddx[i]=(mesh_points[i+1,0]-2*mesh_points[i,0]+mesh_points[i-1,0])/(dt**2)
ddy[i]=(mesh_points[i+1,1]-2*mesh_points[i,1]+mesh_points[i-1,1])/(dt**2)
elif i == 0:
ddx[i]=(mesh_points[i+1,0]-2*mesh_points[i,0]+mesh_points[-1,0])/(dt**2)
ddy[i]=(mesh_points[i+1,1]-2*mesh_points[i,1]+mesh_points[-1,1])/(dt**2)
ddx[i]=(mesh_points[0,0]-2*mesh_points[i,0]+mesh_points[i-1,0])/(dt**2)
ddy[i]=(mesh_points[0,1]-2*mesh_points[i,1]+mesh_points[i-1,1])/(dt**2)
kappa=np.zeros(mn)
i=nod
kappa[i]=(dx[i]*ddy[i]-dy[i]*ddx[i])/(dx[i]**2+dy[i]**2)**(3/2)
fkappa.vector()[fx_dofs] = kappa
kfunc =fkappa.vector().get_local()
vtkfile = File('curvature.pvd')
vtkfile << fkappa
The value calculated is the curvature and in paraview it looks as follows
and this isn’t correct
thanks in advance for any help
