I need to assign data from a mat file to a fem.Function, so that I can use it as the initial condition for my solver.
I don’t know how to ensure that the values from my mat file are read in in the correct order, as I understand that the ordering of vertices in the mesh doesn’t correspond to the ordering of the dofs in a function. So if I simply reshape my (7,7,3) data to be shape (147,), and assign these values to a function, the order of this reshaping is wrong. I know how to get the dofs of the FunctionSpace, but I’m not sure how to use this info.
I’ve looked at a lot of posts on the FEniCS legacy forum, in particular https://fenicsproject.org/qa/2715/coordinates-u_nodal_values-using-numerical-source-function/?show=2721#a2721 and https://fenicsproject.org/qa/3258/manually-setting-values-to-a-function/ , but they use legacy FEniCS parameters which don’t exist in FEniCSx.
I’d be very grateful for any pointers on this! Here is my MWE, I can provide the data mat file if it’s helpful.
import scipy.io
from dolfinx import fem, mesh
# Load in my data:
NTC1 = scipy.io.loadmat('testcase1/NTC1_testcase1.mat')
NTC1 = NTC1["NTC1"]
# Make mesh based on size of data:
L = NTC1.shape[0]-1
W = NTC1.shape[2]-1
mesh = mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, L, W])],
[L, L, W], cell_type=mesh.CellType.hexahedron)
# Define function space
V = fem.FunctionSpace(mesh,("CG",1))
# Get the dofs of the FunctionSpace, I'm not actually using this currently:
local_range = V.dofmap.index_map.local_range
dofs = np.arange(*local_range)
# Reshaping the (7,7,3) data to be (147,), possibly the step where it all goes wrong
NTC1 = np.reshape(NTC1, (mesh.geometry.x.shape[0],));
# Define function (that we want to put NTC1 values into):
N1 = fem.Function(V)
N1.vector[:] = NTC1 # and this messes up the ordering
Thanks,
Rose
Hi @dokken, thanks for the quick answer! Unfortunately I’m quite new to FEniCS so I’m struggling to understand your code and apply it to my case. My main questions are:
How do I apply this to my case, ie to the case of having data in a matrix loaded in from a mat file, which I want to assign to the dofs of a fem.Function? I have tried the following, but the ordering of nodes is still getting mixed up. When I print out vertex_to_dof_map, it is just a list of the indices in increasing number (0,1,2,…,last_vertex) so it makes sense that my line N1.vector[vertex_to_dof_map[i]] = NTC1[i] does nothing.
Looking at your code, the main bit I don’t understand is the use of V0. What does V0, V0_to_V = V.sub(0).collapse() do – am I right in assuming it “collapses” the MixedElement space V onto the subspace of linear Lagrange elements V0? In that case, is it only necessary in the case of a MixedElement subspace (which I don’t require)? I also don’t understand the line bs = V0.dofmap.bs
Here is the code I mentioned in 1:
from IPython import embed
import pyvista
import scipy.io
from dolfinx import fem, io, mesh, plot, nls, log
from dolfinx.io import gmshio
# Load my data
NTC1 = NTC1["NTC1"]
# Make a mesh of corresponding dimensions
L = NTC1.shape[0]-1
W = NTC1.shape[2]-1
# dokken's code on our FunctionSpace
el = ufl.VectorElement("Lagrange", mesh.ufl_cell(), 1)
V = dolfinx.fem.FunctionSpace(mesh, el)
u = dolfinx.fem.Function(V)
dof_layout = V0.dofmap.dof_layout
num_vertices = mesh.topology.index_map(
0).size_local + mesh.topology.index_map(0).num_ghosts
vertex_to_dof_map = np.empty(num_vertices, dtype=np.int32)
num_cells = mesh.topology.index_map(
mesh.topology.dim).size_local + mesh.topology.index_map(
mesh.topology.dim).num_ghosts
c_to_v = mesh.topology.connectivity(mesh.topology.dim, 0)
for cell in range(num_cells):
vertices = c_to_v.links(cell)
dofs = V0.dofmap.cell_dofs(cell)
for i, vertex in enumerate(vertices):
vertex_to_dof_map[vertex] = dofs[dof_layout.entity_dofs(0, i)]
geometry_indices = dolfinx.cpp.mesh.entities_to_geometry(
mesh, 0, np.arange(num_vertices, dtype=np.int32), False)
x = mesh.geometry.x
bs = V0.dofmap.bs
for vertex, geom_index in enumerate(geometry_indices):
dof = vertex_to_dof_map[vertex]
for b in range(bs):
parent_dof = V0_to_V[dof*bs+b]
u.x.array[parent_dof] = x[geom_index, b]
u0 = u.sub(0).collapse()
with dolfinx.io.VTXWriter(mesh.comm, "u.bp", [u0]) as vtx:
vtx.write(0.0)
# Applying the vertex_to_dof_map to put N values into f function:
NTC1 = np.reshape(NTC1, (mesh.geometry.x.shape[0],)); #reshape from matrix to vector of num_vertices length (=num_dofs length)
for i in np.ndindex(vertex_to_dof_map.shape):
Thanks,
Rose
Consider something like the following code:
L = 2
W= 3
nx = 3
ny = 5
nz = 7
msh = mesh.create_box(comm=MPI.COMM_WORLD,
points=((0.0, 0.0, 0.), (L, L, W)), n=(nx-1, ny-1, nz-1),
cell_type=mesh.CellType.hexahedron,)
dx, dy, dz = L/(nx-1), L/(ny-1), W/(nz-1)
values = np.arange(nx*ny*nz).reshape(nx, ny, nz)
P1 = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1)
V = fem.FunctionSpace(msh, P1)
dof_coordinates = V.tabulate_dof_coordinates()
# dof index map to i,j,k
map_vec = np.zeros((len(dof_coordinates), 3), dtype=np.int32)
eps = 2e-14
for dof_index, coordinate in enumerate(dof_coordinates):
map_vec[dof_index] = [(coordinate[0]+eps)//dx, (coordinate[1]+eps)//dy, (coordinate[2]+eps)//dz]
u = fem.Function(V)
for i, map_i in enumerate(map_vec):
u.x.array[i] = values[map_i[0], map_i[1], map_i[2]]
with io.XDMFFile(msh.comm, "u.xdmf", "w") as xdmf:
xdmf.write_mesh(msh)
xdmf.write_function(u)
Thank you so much, I really appreciate it!
