AttributeError: module 'ufl.sobolevspace' has no attribute 'HInf'
Hi all,
I just installed the latest fenicsx via conda on my mac. The error always occurred “AttributeError: module ‘ufl.sobolevspace’ has no attribute ‘HInf’” when I run any of the demos. Does anyone know what the issue is?
Thank you!
Hu
Please check what version of ufl you have installed with
python3 -c "import ufl;print(ufl.__version__); print(ufl)
print(ufl.version)
2019.1.0
print(ufl)
<module ‘ufl’ from ‘/Users/hu/.local/lib/python3.11/site-packages/fenics_ufl-2019.1.0-py3.11.egg/ufl/init.py’>
Should I update it?
Since you are using conda, you should either remove it, or remove it from your Python path
