Hello, I am trying to use FEniCS to solve a system of N equations without using MixedElement, as the equations are not necessary to be solved all at once. I am attempting to use Python list to achieve the automation:
class InitialConditions(UserExpression):
def __init__(self, **kwargs):
random.seed(2 + MPI.rank(MPI.comm_world))
super().__init__(**kwargs)
def eval(self, values, x):
values = random.uniform(-0.001,0.001)
N = 99 # some large number of equations
mesh = UnitSquareMesh(300, 300)
du = [0]*N
v = [0]*N
u = [0]*N
u_n= [0]*N
u_init = InitialConditions()
V = FiniteElement("Lagrange", mesh.ufl_cell(), 1)
ME = FunctionSpace(mesh, V)
for i in range(N):
du[i] = TrialFunction(ME)
v[i] = TestFunctions(ME)
# Define functions
u[i] = Function(ME) # current solution
u_n[i] = Function(ME) # solution from previous converged step
# Create intial conditions and interpolate
u[i].interpolate(u_init)
u_n[i].interpolate(u_init)
L = [0]*N
ap = [0] *N ## ap == L , used ap instead of a
problem = [0] *N
for i in range(N):
dsum = 0
for a in range(N):
for b in range(a+1,N):
dsum += u_n[a]*u_n[b]**2
dFdu = dsum *v[i] + dot(grad(u_n[i]), grad(v[i]))
L[i] = ( u[i]- u_n[i] )*v[i]*dx + dt*( dsum *v[i] + dot(grad(u_n[i]), grad(v[i])) )*dx
# Compute directional derivative about u in the direction of du (Jacobian)
ap[i] = derivative(L[i], u[i], du[i])
problem[i] = NSol(ap[i], L[i]) # Nsol is a class to interface with newton solver
I haven’t gotten down to the time stepping part yet, I am currently stuck at grad(v[i]) where it give me an error saying that cannot be converted to any UFL type.
Beside, there is an warning from my class of initial condition, mentioning that: WARNING: user expression has not supplied value_shape method or an element. Assuming scalar element.
Does anyone have some inside on how to fix these issues and automate this process? Thanks!
I am also including my tentative codes for the time stepping part with Newton solver:
# Class for interfacing with the Newton solver
class NSol(NonlinearProblem): ## this will be moved to the beginning part of the code
def __init__(self, a, L):
self.L = L
self.a = a
def F(self, b, x):
assemble(self.L, tensor=b)
def J(self, A, x):
assemble(self.a, tensor=A)
# neglected some codes setting up PETSc
t = 0.0
dt = 1e-2
T = 10*dt
while (t < T):
for i in range(N):
u_n[i].vector()[:] = u[i].vector()
for i in range(N):
solver.solve(problem[i], u[i].vector())
# neglected some code exporting the solutions
