I am trying to solve the low frequency magnetoquasistatic equation with AV formulation with Coulomb gauge. I use Nedelec1 for A, CG1 for the scalar potential V and the lagrange multipliers used to force the A gauge. In steady state, with monolitic mumps LU, I get a reasonable solution, but I would like to use an iterative solver to limit memory. I am trying a fieldsplit with Schur, using Hypre AMS for the Nedelec elements providing the discrete gradient and edge vectors, while I use mumps lu for the remaining part, which should handle the singular lagrange multiplier block. I always get nan on the AMS iteration 0. Am I missing something or is there something wrong in the solver setup? Here is the minimal example, with the mesh generation script :
gmsh.model.add("cube_with_two_tori")
occ = gmsh.model.occ
# Parameters
L = 1.0
cube = occ.addBox(-L/2, -L/2, 0, L, L, L)
cx = 0.0
cy = 0.0
# Torus centers and radii
z1 = 0.35
z2 = 0.65
R1 = 0.18 # major radius
R2 = 0.30
r1 = 0.05 # tube radius
r2 = 0.05 # tube radius
torus1 = occ.addTorus(cx, cy, z1, R1, r1)
torus2 = occ.addTorus(cx, cy, z2, R2, r2)
bill = occ.addCylinder(0,0,z1,0,0,0.5*(z2-z1),R1*0.5)
# Make all volumes conformal
occ.fragment([(3, cube)], [(3, torus1), (3, torus2), (3, bill)])
occ.synchronize()
vols = gmsh.model.getEntities(3)
air_vols = []
loop1_vols = []
loop2_vols = []
for dim, tag in vols:
x, y, z = occ.getCenterOfMass(dim, tag)
rho = ((x - cx) ** 2 + (y - cy) ** 2) ** 0.5
d1 = ((rho - R1) ** 2 + (z - z1) ** 2) ** 0.5
d2 = ((rho - R2) ** 2 + (z - z2) ** 2) ** 0.5
if d1 < r1 * 0.7:
loop1_vols.append(tag)
elif d2 < r2 * 0.7:
loop2_vols.append(tag)
air_vols.append(tag)
# Physical groups
ct = 1
for dim, tag in gmsh.model.getEntities(dim=3):
gmsh.model.addPhysicalGroup(3, [tag], ct)
ct += 1
ct = 100
for dim, tag in gmsh.model.getEntities(dim=2):
gmsh.model.addPhysicalGroup(2, [tag], ct)
ct += 1
ct = 200
for dim, tag in gmsh.model.getEntities(dim=1):
gmsh.model.addPhysicalGroup(1, [tag], ct)
ct += 1
ct = 300
for dim, tag in gmsh.model.getEntities(dim=0):
gmsh.model.addPhysicalGroup(0, [tag], ct)
ct += 1
occ.synchronize()
# Mesh options
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 0.03)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.07)
gmsh.model.mesh.generate(3)
gmsh.model.mesh.optimize()
gmsh.write("cube_with_two_tori.msh")
gmsh.finalize()
from __future__ import annotations
import math
import time
import basix.ufl
from dolfinx import fem
from dolfinx.fem.petsc import (
apply_lifting,
assemble_matrix,
assemble_vector,
discrete_gradient,
set_bc,
from dolfinx.io.gmsh import read_from_msh
def build_piecewise_sigma(mesh, cell_tags):
"""Create DG0 conductivity field matching compare_solvers materials.
- air tags (1, 3, 4): sigma = 10 S/m
- copper tag (2): sigma = 5e7 S/m
q0 = fem.functionspace(mesh, ("DG", 0))
sigma = fem.Function(q0)
sigma.x.array[:] = 0.0
air_value = PETSc.ScalarType(10.0)
copper_value = PETSc.ScalarType(5.0e7)
for tag in (1, 3, 4):
cells = cell_tags.find(tag)
sigma.x.array[cells] = air_value
copper_cells = cell_tags.find(2)
sigma.x.array[copper_cells] = copper_value
sigma.x.scatter_forward()
return sigma
def build_current_density_function(v_hcurl):
"""Interpolate source J = 1e5 * (-sin(atan2(y,x)), cos(atan2(y,x)), 0)."""
j_fun = fem.Function(v_hcurl)
def j_expr(x):
theta = np.arctan2(x[1], x[0])
values = np.zeros((3, x.shape[1]), dtype=PETSc.ScalarType)
values[0, :] = -1.0e5 * np.sin(theta)
values[1, :] = 1.0e5 * np.cos(theta)
return values
j_fun.interpolate(j_expr)
j_fun.x.scatter_forward()
return j_fun
def assemble_system(mesh, cell_tags, point_tags):
"""Assemble mixed AV-lambda linear system and return matrix, rhs, metadata.
Problem: Magnetostatic AV-lambda formulation with Coulomb gauge constraint.
This is a saddle-point problem arising from:
- curl(1/mu * curl(A)) = J (current source) + grad(V) (electric coupling)
- div(sigma * grad(V)) = -div(sigma * grad(lambda)) (Coulomb gauge constraint)
- div(A) = lambda (Lagrange multiplier constraint)
Mixed FE spaces:
- A in H(curl) via Nedelec elements (order 1)
- V, lambda in H^1 via Lagrange elements (order 1)
Materials: air (tags 1,3,4), copper (tag 2) with different conductivities.
Source: current density J on volume tag 1 only.
BCs: V = lambda = 0 on point tag 300.
# Mixed function space: (A, V, lambda)
a_el = basix.ufl.element("N1curl", mesh.basix_cell(), 1)
v_el = basix.ufl.element("Lagrange", mesh.basix_cell(), 1)
l_el = basix.ufl.element("Lagrange", mesh.basix_cell(), 1)
w_space = fem.functionspace(mesh, basix.ufl.mixed_element([a_el, v_el, l_el]))
# Unknown and test functions
(a_trial, v_trial, l_trial) = ufl.TrialFunctions(w_space)
(w_test, q_test, r_test) = ufl.TestFunctions(w_space)
# Collapse maps needed for fieldsplit IS definitions
w0, map_a = w_space.sub(0).collapse()
_, map_v = w_space.sub(1).collapse()
_, map_l = w_space.sub(2).collapse()
# Material coefficients
mu0 = 4.0e-7 * math.pi
nu = PETSc.ScalarType(1.0 / mu0)
sigma = build_piecewise_sigma(mesh, cell_tags)
# Domain measures with subdomain tags
dx = ufl.Measure("dx", domain=mesh, subdomain_data=cell_tags)
# AV-lambda mixed formulation (magnetostatic with Coulomb gauge constraint):
# - A: magnetic vector potential (N1curl / H(curl), test fn w)
# - V: electric scalar potential (CG1 / H^1, test fn q)
# - lambda: Lagrange multiplier enforcing gauge (CG1 / H^1, test fn r)
# Weak form breakdown:
# 1. nu * <curl(A), curl(w)> : curl-curl bilinear form (stiffness from reluctivity)
# 2. <sigma·grad(V), w + grad(q)> : conductivity coupling (electric & constraint mixing)
# 3. <grad(lambda), w> : Lagrange multiplier to A (enforces constraint on A)
# 4. <A, grad(r)> : A to Lagrange multiplier (dual constraint coupling)
# This gives the saddle-point system:
# [ K_A 0 G^T ] [ A ] [ J ]
# [ 0 K_V D ] [ V ] = [ 0 ]
# [ G D^T 0 ] [ lambda ] [ 0 ]
# where K_A = curl-curl, K_V = sigma·grad, G = grad, D = mixed conductivity term
a_form = fem.form(
# Term 1: Magnetic energy (curl-curl)
nu * ufl.inner(ufl.curl(a_trial), ufl.curl(w_test))
# Term 2: Electric conductivity (appears on both A and V rows via Coulomb constraint)
+ ufl.inner(sigma * ufl.grad(v_trial), w_test + ufl.grad(q_test))
# Term 3: Lagrange multiplier constraint on A (gradient of lambda couples to w)
+ ufl.inner(ufl.grad(l_trial), w_test)
# Term 4: Constraint dual form (A couples to gradient of r via Lagrange)
+ ufl.inner(a_trial, ufl.grad(r_test))
* dx,
# Current source only on volume tag 1, as in compare_solvers
j = build_current_density_function(w0)
l_form = fem.form(ufl.inner(j, w_test) * dx(1))
# Point constraints on V and lambda at point tag 300
point_entities = point_tags.find(300)
dofs_v = fem.locate_dofs_topological(w_space.sub(1), 0, point_entities)
dofs_l = fem.locate_dofs_topological(w_space.sub(2), 0, point_entities)
bc_v = fem.dirichletbc(PETSc.ScalarType(0.0), dofs_v, w_space.sub(1))
bc_l = fem.dirichletbc(PETSc.ScalarType(0.0), dofs_l, w_space.sub(2))
bcs = [bc_v, bc_l]
# Assemble linear system
a_mat = assemble_matrix(a_form, bcs=bcs)
a_mat.assemble()
b_vec = assemble_vector(l_form)
apply_lifting(b_vec, [a_form], [bcs])
b_vec.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
set_bc(b_vec, bcs)
metadata = {
"W": w_space,
"W0": w0,
"map_a": map_a.astype(np.int32),
"map_v": map_v.astype(np.int32),
"map_l": map_l.astype(np.int32),
return a_mat, b_vec, metadata
def solve_monolithic_lu(a_mat, b_vec):
"""Reference solve with preonly+LU(MUMPS)."""
x = a_mat.createVecRight()
ksp = PETSc.KSP().create(a_mat.comm)
ksp.setOperators(a_mat)
ksp.setType("preonly")
pc = ksp.getPC()
pc.setType("lu")
# ICNTL(24)=1: detect null pivots (handles gauge singularity in curl-curl block)
pc.setFactorSetUpSolverType()
pc.getFactorMatrix().setMumpsIcntl(24, 1)
t0 = time.perf_counter()
ksp.solve(b_vec, x)
elapsed = time.perf_counter() - t0
return {
"x": x,
"ksp": ksp,
"time": elapsed,
"reason": ksp.getConvergedReason(),
"its": ksp.getIterationNumber(),
def solve_fieldsplit_ams(a_mat, b_vec, meta):
"""FGMRES + FieldSplit Schur with AMS on A and LU on (V,lambda).
This solver uses a block preconditioner:
- Outer: FGMRES (flexible restarted GMRES, allows varying preconditioner)
- Outer PC: Fieldsplit with Schur complement factorization (UPPER form)
* Block (A): HYPRE AMS (Auxiliary Space Maxwell Solver for H(curl) problems)
- Uses discrete gradient (curl operator) and edge constant vectors
- Designed for curl-curl systems in H(curl) spaces
* Block (V,lambda): MUMPS LU (direct solver on Schur complement)
ksp.setType("fgmres")
ksp.setTolerances(rtol=1e-8, atol=1e-50, divtol=1e3, max_it=10000)
pc = ksp.getPC()
pc.setType("fieldsplit")
pc.setFieldSplitType(PETSc.PC.CompositeType.SCHUR)
pc.setFieldSplitSchurFactType(PETSc.PC.SchurFactType.UPPER)
pc.setFieldSplitSchurPreType(PETSc.PC.SchurPreType.A11)
# A vs (V, lambda) split
# Index set for A-block: all DOFs from Nedelec space (field 0)
# Index set for (V,lambda)-block: all DOFs from both CG1 spaces (fields 1 & 2)
is_a = PETSc.IS().createGeneral(meta["map_a"], comm=a_mat.comm)
map_vl = np.concatenate((meta["map_v"], meta["map_l"]))
is_vl = PETSc.IS().createGeneral(map_vl.astype(np.int32), comm=a_mat.comm)
pc.setFieldSplitIS(("field_0", is_a), ("field_1", is_vl))
# Materialize sub-KSPs after split setup
ksp.setUp()
sub_ksps = pc.getFieldSplitSubKSP()
ksp_a = sub_ksps[0]
ksp_vl = sub_ksps[1]
# A-block: preonly + HYPRE AMS
# AMS (Auxiliary Space Maxwell Solver) is designed for H(curl) discretizations.
ksp_a.setType("preonly")
pc_a = ksp_a.getPC()
pc_a.setType("hypre")
pc_a.setHYPREType("ams")
opts = PETSc.Options()
v_h1 = fem.functionspace(meta["W"].mesh, ("Lagrange", 1))
g_mat = discrete_gradient(v_h1, meta["W0"])
g_mat.assemble()
# Edge constant vectors: coordinate basis vectors in H(curl)
cvec0 = fem.Function(meta["W0"])
cvec1 = fem.Function(meta["W0"])
cvec2 = fem.Function(meta["W0"])
cvec0.interpolate(
lambda x: np.vstack(
(np.ones_like(x[0]), np.zeros_like(x[1]), np.zeros_like(x[2])),
cvec1.interpolate(
(np.zeros_like(x[0]), np.ones_like(x[1]), np.zeros_like(x[2])),
cvec2.interpolate(
(np.zeros_like(x[0]), np.zeros_like(x[1]), np.ones_like(x[2])),
cvec0.x.scatter_forward()
cvec1.x.scatter_forward()
cvec2.x.scatter_forward()
# Pass auxiliary data to AMS preconditioner
pc_a.setHYPREDiscreteGradient(g_mat)
pc_a.setHYPRESetEdgeConstantVectors(
cvec0.x.petsc_vec,
cvec1.x.petsc_vec,
cvec2.x.petsc_vec,
# Apply options and trigger HYPRE's internal AMS setup
ksp_a.setFromOptions()
# Explicit PC.setUp() triggers HYPRE's internal AMS setup NOW
# (without this, AMS setup may be deferred and skipped in fieldsplit context)
pc_a.setUp()
# (V, lambda)-block: preonly + LU(MUMPS)
ksp_vl.setType("preonly")
pc_vl = ksp_vl.getPC()
pc_vl.setType("lu")
pc_vl.setFactorSolverType("mumps")
# ICNTL(24)=1: detect null pivots (Schur complement may inherit singularity)
pc_vl.setFactorSetUpSolverType()
pc_vl.getFactorMatrix().setMumpsIcntl(24, 1)
ksp.solve(b_vec, x)
return {
"x": x,
"ksp": ksp,
"time": elapsed,
def main():
comm = MPI.COMM_WORLD
rank = comm.rank
mesh_file = "examples/data/cube_with_two_tori.msh"
if rank == 0:
print("=" * 80)
print("Minimal DOLFINx AV-lambda test (small mesh)")
print("=" * 80)
print(f"Loading mesh: {mesh_file}")
# read_from_msh returns (mesh, cell_tags, facet_tags, edge_tags, point_tags, ...)
loaded = read_from_msh(mesh_file, comm=comm, rank=0, gdim=3)
mesh = loaded[0]
cell_tags = loaded[1]
point_tags = loaded[4]
a_mat, b_vec, meta = assemble_system(mesh, cell_tags, point_tags)
if rank == 0:
print("System assembled")
print(f" Global size: {a_mat.getSize()[0]}")
print(f" A dofs: {meta['W0'].dofmap.index_map.size_global}")
print(f" V dofs: {len(meta['map_v'])}")
print(f" Lambda dofs: {len(meta['map_l'])}")
# Baseline
if rank == 0:
print("\n[1/2] Monolithic LU (MUMPS)")
lu_res = solve_monolithic_lu(a_mat, b_vec)
if rank == 0:
print(
f" reason={lu_res['reason']}, its={lu_res['its']}, "
f"time={lu_res['time']:.3f}s",
# AMS fieldsplit
if rank == 0:
print("\n[2/2] FieldSplit Schur + AMS(A) + LU(V,lambda)")
ams_res = solve_fieldsplit_ams(a_mat, b_vec, meta)
if rank == 0:
print(
f" reason={ams_res['reason']}, its={ams_res['its']}, "
f"time={ams_res['time']:.3f}s",
if rank == 0:
print("\nDone.")
if __name__ == "__main__":
main()
Thank you,
Mattia
