BASIX error for SobolevSpace
I install Dolfinx on my MAC M1 with Conda. I also installed all requirements before and tried to build from source but there were lots of errors. So, I preferred to install it with Conda.
I can run demo_possion.py without a problem. However, for other demos, I have problems. One of them is SobolovSpace in Basix. This function is not included in BASIX and I encountered an error when I want to import it to the code. Besides, when I wanted to build Dolfinx on the Linux cluster, I could see the same problem when I wanted to ā€œmake installā€ in ā€œcpp/ā€ folder.
The error on macOS is:
AttributeError: module ā€˜basix’ has no attribute ā€˜SobolevSpace’
I would appreciate it if someone can help me.
hello,
I guess you did a pip install basix
try uninstalling basix with pip uninstall
and then doing
conda install -c conda-forge fenics-basix
