Boundaries not getting marked
Hi all,
I am loading a mesh from gmsh and marking the boundaries (mesh can be found here. I wish to mark the first quadrant as ‘2’, the fourth quadrant as ‘10’ and the second and third quadrant as ‘20’. Those boundaries are not getting marked properly (as seen in the paraview from loading pvd file). Please can anyone tell me the reason for not getting marked properly and how to fix it?
Thanks in advance.
import math
import mshr
import dolfin
import os
parameters["allow_extrapolation"]=True
dir_path = os.path.dirname(os.path.realpath(__file__))
R = 10.00 # Radius of the circular part
mesh = Mesh("mesh.xml")
class centre(SubDomain):
    def inside(self,x, on_boundary):
     tol = 3e-1
     return (near(x[0],0.00,tol) and near(x[1],0.00,tol))
class circle_boundary(SubDomain):
      tol = 1.0
      r=(x[0]**2+x[1]**2)**0.5
      return ( R-r < tol) and on_boundary
class circle_load(SubDomain):
      tol = 5e-1
      return ((R+tol > x[0] > 0-tol and R+tol > x[1] > 0-tol) and on_boundary)
class circle_bound1(SubDomain):
      tol = 5e-1
      return (( x[0] > 0 and  x[1] < 0) and on_boundary)
class circle_bound2(SubDomain):
      tol = 5e-1
      return ((0> x[0] > -R and R > x[1] > -R) and on_boundary)
boundaries = MeshFunction("size_t",mesh,mesh.topology().dim()-1)
boundaries.set_all(0)
centre= centre()
circle_boundary = circle_boundary()
circle_load = circle_load()
circle_bound1 = circle_bound1()
circle_bound2 = circle_bound2()
#circle_conc = circle_boundary - circle_load
centre.mark(boundaries,5)
circle_boundary.mark(boundaries,1)
circle_load.mark(boundaries,2)
circle_bound1.mark(boundaries,10)
circle_bound2.mark(boundaries,20)
meshfile=File(dir_path+'/mesh.pvd')
meshfile<<mesh
#plot(boundaries, interactive=True)
boundary_file = File(dir_path+'/boundaries1.pvd')
boundary_file <<boundaries
raise SystemExit()
After some cleanup with names, this is what I get:
        tol = 3e-1
        return near(x[0], 0.00, tol) and near(x[1], 0.00, tol)
        tol = 1.0
        r = (x[0] ** 2 + x[1] ** 2) ** 0.5
        return (R - r < tol) and on_boundary
        tol = 5e-1
        return (R + tol > x[0] > 0 - tol and R + tol > x[1] > 0 - tol) and on_boundary
        tol = 5e-1
        return (x[0] > 0 and x[1] < 0) and on_boundary
boundaries = MeshFunction("size_t", mesh, 0)
bcentre = centre()
bcircle_boundary = circle_boundary()
bcircle_load = circle_load()
bcircle_bound1 = circle_bound1()
bcentre.mark(boundaries, 5)
bcircle_boundary.mark(boundaries, 1)
bcircle_load.mark(boundaries, 2)
bcircle_bound1.mark(boundaries, 10)
from vtkplotter.dolfin import plot
plot(boundaries)
PS: to install vtkplotter you can use:
pip install vtkplotter
This does not answer my question. Yes! That is what I am getting. But I wish to mark the entire quadrant. Please let me know if you have any workaround to mark the entire quadrant rather than some portion of it. (from the condition provided in the snippet, I expect to get marked the entire quadrant.)
I would recommend to mark your boundaries in your GMSH file as Physical Line before converting your mesh. Please consider this:
Lets say we have a circle with radius = 1 and the quadrants are:
  • First quadrant: Top Right ## Should be marked as 2
  • Second quadrant: Top Left ## Should be marked as 20
  • Third quadrant: Bottom Left ## Should be marked as 20
  • Fourth quadrant: Bottom Right ## Should be marked as 10
Here is the GMSH file and how you can tag the quadrants:
Point(1) = {0, 0, 0, 1.0};
Point(2) = {1, 0, 0, 1.0};
Point(3) = {0, 1, 0, 1.0};
Point(4) = {-1, 0, 0, 1.0};
Point(5) = {0, -1, 0, 1.0};
Circle(1) = {2, 1, 3};
Circle(2) = {4, 1, 3};
Circle(3) = {4, 1, 5};
Circle(4) = {2, 1, 5};
Line Loop(5) = {2, -1, 4, -3};
Plane Surface(6) = {5};
Physical Surface(1) = {6};
Physical Line(2) = {1};
Physical Line(20) = {2,3};
Physical Line(10) = {4};
The mesh is something like this:
Then save the mesh in msh format (mesh.msh). Now you can convert it to xml format by running this in terminal:
 dolfin-convert mesh.msh newmesh.xml
Three files are created:
  1. newmesh.xml
  2. newmesh_facet_region.xml
  3. newmesh_physical_region.xml
Then run this:
mesh = Mesh("newmesh.xml")
facets = MeshFunction("size_t", mesh, "newmesh_facet_region.xml")
f = File("facets.pvd")
f<< facets
When you open the facets.pvd file, this is what you can see:
…indeed your mesh looks a bit weird:
vtkplotter mesh.xml -c black -bg white -a 0.1
Screenshot%20from%202019-04-26%2012-06-31
it’s not on a plane and its cell orientations are not uniform:
In any case you can play with the SubDomain to select the region you wish, e.g.
class sector1(SubDomain):
        return x[1]>0 and x[0]>0
class rim(SubDomain):
        r = sqrt(x[0]**2+x[1]**2)
        return 9.99<r
bs1 = sector1()
bs1.mark(boundaries, 5)
brm = rim()
brm.mark(boundaries, 10)
plot(boundaries)
Screenshot%20from%202019-04-26%2012-09-51
