Boundary conditions definition dolfinx.fem.locate_dofs_geometrical
hope you are good.
Im a student and new to fenicsx
And I have a few questions.
I want to set the x-component of the displacement to 0 on the left edge of a plate (2D geometry). For this, I’m using the script snippet below. But I got curious and wanted to print the contents of left_dofs_x.
here is what I got:
dtype=int32), array([505, 506, 516, 525, 533, 540, 546, 551, 555, 558, 560], dtype=int32)]
According to the documentation, locate_dofs_geometrical returns an array of degrees-of-freedom indices (local to the process) for degrees-of-freedom whose coordinate evaluates to True for the marker function.
If V is a list of two function spaces, then a 2-D array of shape (number of dofs, 2) is returned.
  • My first question is: don’t V.sub(0) and V_ux correspond to the same subspace?
  • My second question is: are the two columns (arrays) indices of degrees of freedom (local to the process) whose coordinate evaluates to True for the marker function left_edge, or does each array have a different meaning?
    I noticed that the indices of the first array are double the indices of the second array.
# Fix horizontal displacement on left edge (ux = 0)
V_ux, mapping = V.sub(0).collapse() # subspace of V for component ux
def left_edge(x):
    return np.isclose(x[0], 0.0)
left_dofs_x = fem.locate_dofs_geometrical((V.sub(0), V_ux), left_edge)
print("left_dofs_x =", left_dofs_x)
u0_x = fem.Function(V_ux)
bc_left_x = fem.dirichletbc(u0_x, left_dofs_x, V.sub(0))
Thanks in advance for taking your time to read this and for any reply
You’d have to supply a full working code for someone to reproduce your results, but to answer your questions:
They reference the same subspace, but are not the same representation of that space: V_ux ( the collapse’d one) is a stand-alone space whereas V.sub(0) is still part of V. That also explains
The coefficient numbers of V.sub(0) reference the dof in the V representation whereas those of V_ux reference the dofs in the stand-alone V_ux itself.
If your V is based on a mixed element with twice the same element, then that would explain why the coefficient numbers for V.sub(0) appear double that of V_ux
First of all, thanks for your reply.
i understood better the difference between V.sub(0) and V_ux
I don’t think that my V is based on a mixed element, well i’m not sure
Here is the full working code
### Linear elasticity - 2D Plate under pure elongation
#------------- Import modules -------------------
from ufl import sym, grad, Identity, tr, inner, Measure, TestFunction, TrialFunction, sqrt
from dolfinx import fem, io
import dolfinx.fem.petsc
from dolfinx.mesh import create_rectangle, CellType, locate_entities_boundary, meshtags #MeshTags
#------------- Mesh and geometry --------------------
length, height = 5.0, 1.0
Nx, Ny = 50, 10                      # mesh refinement
domain = create_rectangle(
    MPI.COMM_WORLD,
    [np.array([0.0, 0.0]), np.array([length, height])],
    [Nx, Ny],
    cell_type=CellType.triangle,
## domain dimension
dim = domain.topology.dim
print(f"Mesh topology dimension d={dim}.")
#-------------- Function space (displacement field) and solution function -------------------
degree = 1 # degree of polynomial approximation for the displacement field (1=linear, 2=quadratic, 3=cubic)
shape = (dim,) # dim is the topological dimension of the domain (2 here)
V = fem.functionspace(domain, ("P", degree, shape))
u_sol = fem.Function(V, name="Displacement")
#-------------- Variational formulation -------------------
#-------------- Material parameters definition -------------------
# SI units: m, Pa, kg/m^3
E = fem.Constant(domain, 210e9)     # Young's modulus (Pa)
nu = fem.Constant(domain, 0.3)      # Poisson's ratio
lmbda = E * nu / (1 + nu) / (1 - 2 * nu)
mu = E / 2 / (1 + nu)
#-------------- Definition of strain and stress functions -------------------
def epsilon(v):
    return sym(grad(v))
def sigma(v):
    return lmbda * tr(epsilon(v)) * Identity(dim) + 2.0 * mu * epsilon(v)
# print("mu (UFL):\n", mu)
# print("epsilon (UFL):\n", epsilon(u_sol))
# print("sigma (UFL):\n", sigma(u_sol))
#-------------- Test and trial functions (real and virtual displacement fields) -------------------
#-------------- Integration measure -------------------
dx = Measure("dx", domain=domain)
# There is no body force in this case so set f = 0
f  = fem.Constant(domain, np.array([0.0, 0.0]))
#-------------- Bilinear and linear forms -------------------
a = inner(sigma(u), epsilon(v)) * dx
L = inner(f, v) * dx  # Initialize L with the volume term f (here zero)
#-------------- Boundary conditions -------------------
# Numerically, we must remove rigid body modes (translations + rotations).
# Here we impose minimal Dirichlet constraints to obtain a unique solution:
# - Fix both components of displacement (ux = uy = 0) at the bottom-left corner (x = 0, y = 0) -> remove 2 translations
# - Fix horizontal displacement (ux = 0) on the left edge -> remove rotation
# Locate the degrees of freedom at the bottom-left corner
def bottom_left_point(x):
    return np.isclose(x[0], 0.0) & np.isclose(x[1], 0.0)
bottom_left_point_dofs = fem.locate_dofs_geometrical(V, bottom_left_point)
u0_blp = fem.Function(V) # u0_blp is initialized to zero by default
u0_blp = np.zeros((2,), dtype=np.float64) # zero displacement vector at bottom-left corner
bc_blp = fem.dirichletbc(u0_blp, bottom_left_point_dofs, V) # Fix both components at bottom-left corner (x = 0, y = 0)
# Fix horizontal displacement (ux = 0) on the left edge
V_ux, mapping = V.sub(0).collapse() # subspace of V for the ux component
def left_edge(x):
#    print("x shape: ", x.shape)
u0_x = fem.Function(V_ux) # u0_x is initialized to zero by default
# Fix horizontal displacement (ux = epsilon*L) on the right edge
epsilon = 0.001  # prescribed uniaxial strain (0.1%)
def right_edge(x):
    return np.isclose(x[0], length)
right_dofs_x = fem.locate_dofs_geometrical((V.sub(0), V_ux), right_edge)
print("right_dofs_x =", right_dofs_x)
ulength_x = fem.Function(V_ux)
#Method 1
# or a fem.Expression
# ulength_x.interpolate(lambda x: epsilon * length * np.ones(x.shape[1], dtype=np.float64))
# print(f"ulength_x = {ulength_x} et le type est {type(ulength_x)}")
#Method 2
ulength_x.x.array[:] = epsilon * length
bc_right_x = fem.dirichletbc(ulength_x, right_dofs_x, V.sub(0))
# List of boundary conditions
bcs = [bc_blp, bc_left_x, bc_right_x]
#-------------- Assemble and solve linear system -------------------
petsc_options = {"ksp_type": "preonly", "pc_type": "lu"}
problem = fem.petsc.LinearProblem(a, L, u=u_sol, bcs=bcs,
                                  petsc_options=petsc_options)
problem.solve()
# ------------- Display displacement, strain, stress and von Mises -------------------
# spaces for tensorial / scalar fields
V_eps = fem.functionspace(domain, ("P", degree, (dim, dim)))   # strain (tensor)
V_sig = fem.functionspace(domain, ("P", degree, (dim, dim)))   # stress (tensor)
V_vm  = fem.functionspace(domain, ("P", degree, ()))          # Von Mises (scalar)
def project_field(expr, Vtarget, name_expr):
    """Interpolation via fem.Expression + interpolate"""
    interp = fem.Expression(expr, Vtarget.element.interpolation_points())
    F = fem.Function(Vtarget, name = name_expr)
    F.interpolate(interp)
    return F
# expressions for strain, stress and von Mises
eps_expr = sym(grad(u_sol)) #epsilon(u_sol)
sig_expr = lmbda * tr(eps_expr) * Identity(dim) + 2.0 * mu * eps_expr
s_dev = sig_expr - (1.0/3.0) * tr(sig_expr) * Identity(dim)
vm_expr = sqrt(1.5 * inner(s_dev, s_dev))
# project/interpolate
eps_proj = project_field(eps_expr, V_eps, "Déformation")
sig_proj = project_field(sig_expr, V_sig, "Contrainte")
vm_proj  = project_field(vm_expr, V_vm, "Von_Mises")
# .pvd output for visualization with Paraview
# 2
# with io.VTKFile(domain.comm, "results/linear_elasticity_2D_PureElongation/linear_elasticity_2D_PureElongation.pvd", "w") as vtk:
#     vtk.write_mesh(domain)
#     vtk.write_function(u_sol)
#     vtk.write_function(eps_proj)
#     vtk.write_function(sig_proj)
#     vtk.write_function(vm_proj)
# 1
vtk = io.VTKFile(domain.comm, "results/linear_elasticity_2D_PureElongation/linear_elasticity_2D_PureElongation.pvd", "w")
vtk.close()
if domain.comm.rank == 0:
    print("Solution written! (open with ParaView).")
I used Jeremy Bleyer’s github
and Js Dokken website
Could you recommend (if any exist) any documents to better understand how FEniCSx works?
Thanks
Ah you’re right, that’s why a MWE was important :wink: Your V is a vector-valued, created by V = fem.functionspace(domain, ("P", degree, shape)) with shape=(2,). So it carries 2 degrees of freedom for each node, while V_ux is collapsed to only the x-components. Hence the doubling; dof n in V_ux corresponds to dof 2n in V (and, per my previous post, also to dof 2n in V.sub(0) )
The prominent resources are:
But those mainly show how to use FEniCS, not really how FEniCS works. The FEniCS book is outdated, but can still help you understand some core concepts https://launchpadlibrarian.net/83776282/fenics-book-2011-10-27-final.pdf
And then there are more technical resources, but that’s quite a big step https://orbilu.uni.lu/bitstream/10993/59327/1/dolfinx-paper-zenodo.10447666.pdf
Thanks a lot M.Stein :grin:
