Hi all,
Can dolfin-convert be used from inside Spyder instead of from the terminal? What I am doing is not working:
File “ipython-input-74-16c7fad52f64”, line 1, in
dolfin-convert
NameError: name ‘convert’ is not defined
How does it work?
Thank you!
I don’t have much experience with Spyder, although, in Python, you can run arbitrary terminal commands with os.system()
, e.g.,
import os
os.system("echo 'hello, world'")
I also believe dolfin-convert
is considered deprecated now, and I have seen developers encouraging people to use meshio
instead, which can be imported as a module.
Works perfectly, thank you! I will look into meshio!
