Hi Bhavesh,
Really appreciate your help. I had modified my eps and sigma functions. The error log with level(10) is shown below
Process 0: Building distributed mesh
Process 0: Compute partition of cells across processes
Process 0: Build mesh dual graph
Process 0: Build local part of mesh dual graph
Process 1: Building distributed mesh
Process 1: Compute partition of cells across processes
Process 1: Build mesh dual graph
Process 1: Build local part of mesh dual graph
Process 0: Elapsed wall, usr, sys time: 32.8091, 30.24, 2.49 (Compute local part of mesh dual graph)
Process 0: Build nonlocal part of mesh dual graph
Process 1: Elapsed wall, usr, sys time: 33.1491, 30.35, 2.72 (Compute local part of mesh dual graph)
Process 1: Build nonlocal part of mesh dual graph
Process 1: Elapsed wall, usr, sys time: 0.0276186, 0.03, 0 (Compute non-local part of mesh dual graph)
Process 0: Elapsed wall, usr, sys time: 0.373477, 0.35, 0.01 (Compute non-local part of mesh dual graph)
Process 0: Compute graph partition using PT-SCOTCH
Process 1: Compute graph partition using PT-SCOTCH
Process 1: Elapsed wall, usr, sys time: 0.0247914, 0.02, 0 (SCOTCH: call SCOTCH_dgraphBuild)
Process 0: Elapsed wall, usr, sys time: 0.0247842, 0.02, 0 (SCOTCH: call SCOTCH_dgraphBuild)
Process 0: Elapsed wall, usr, sys time: 30.3988, 28.61, 1.73 (SCOTCH: call SCOTCH_dgraphPart)
Process 1: Elapsed wall, usr, sys time: 30.6138, 29.15, 1.39 (SCOTCH: call SCOTCH_dgraphPart)
Process 0: Elapsed wall, usr, sys time: 0.427098, 0.35, 0.08 (SCOTCH: call SCOTCH_dgraphHalo)
Process 0: Elapsed wall, usr, sys time: 1.571e-06, 0, 0 (Get SCOTCH graph data)
Process 1: Elapsed wall, usr, sys time: 0.415835, 0.33, 0.09 (SCOTCH: call SCOTCH_dgraphHalo)
Process 1: Elapsed wall, usr, sys time: 1.798e-06, 0, 0 (Get SCOTCH graph data)
Process 1: Elapsed wall, usr, sys time: 0.369449, 0.37, 0 (Extract partition boundaries from SCOTCH graph)
Process 0: Elapsed wall, usr, sys time: 0.376192, 0.37, 0 (Extract partition boundaries from SCOTCH graph)
Process 1: Elapsed wall, usr, sys time: 33.3443, 31.7, 1.56 (Compute graph partition (SCOTCH))
Process 0: Elapsed wall, usr, sys time: 33.7291, 31.58, 2.08 (Compute graph partition (SCOTCH))
Process 0: Distribute mesh (cell and vertices)
Process 1: Distribute mesh (cell and vertices)
Process 0: Distribute cells during distributed mesh construction
Process 1: Distribute cells during distributed mesh construction
Process 1: Elapsed wall, usr, sys time: 8.43924, 5.84, 2.57 (Distribute cells)
Process 0: Elapsed wall, usr, sys time: 8.63252, 6.12, 2.49 (Distribute cells)
Process 1: Distribute vertices during distributed mesh construction
Process 0: Distribute vertices during distributed mesh construction
Process 1: Build shared vertices during distributed mesh construction
Process 0: Build shared vertices during distributed mesh construction
Process 1: Elapsed wall, usr, sys time: 28.5588, 26.44, 2.05 (Distribute vertices)
Process 1: Elapsed wall, usr, sys time: 62.9803, 57.41, 5.41 (Distribute mesh (cells and vertices))
Process 1: Build local mesh during distributed mesh construction
Process 0: Elapsed wall, usr, sys time: 27.7168, 25.4, 2.26 (Distribute vertices)
Process 0: Elapsed wall, usr, sys time: 63.4013, 57.78, 5.47 (Distribute mesh (cells and vertices))
Process 0: Build local mesh during distributed mesh construction
Process 1: Elapsed wall, usr, sys time: 22.2812, 21.79, 0.44 (Build local part of distributed mesh (from local mesh data))
Process 0: Elapsed wall, usr, sys time: 22.4858, 22.03, 0.39 (Build local part of distributed mesh (from local mesh data))
Process 0: Computing mesh entities of dimension 1
Process 1: Computing mesh entities of dimension 1
Process 1: Elapsed wall, usr, sys time: 37.4393, 35.86, 1.48 (Compute entities dim = 1)
Process 1: Requesting connectivity 1 - 2.
Process 1: Requesting connectivity 2 - 1.
Process 1: Computing mesh connectivity 1 - 2 from transpose.
Process 0: Elapsed wall, usr, sys time: 38.9781, 37.42, 1.46 (Compute entities dim = 1)
Process 0: Requesting connectivity 1 - 2.
Process 0: Requesting connectivity 2 - 1.
Process 0: Computing mesh connectivity 1 - 2 from transpose.
Process 1: Elapsed wall, usr, sys time: 3.23042, 3.22, 0.01 (Compute connectivity 1-2)
Process 1: Number mesh entities for distributed mesh (for specified vertex ids).
Process 0: Elapsed wall, usr, sys time: 3.60629, 3.53, 0.08 (Compute connectivity 1-2)
Process 0: Number mesh entities for distributed mesh (for specified vertex ids).
Process 1: Compute ownership for mesh entities of dimension 1.
Process 0: Compute ownership for mesh entities of dimension 1.
Process 1: Elapsed wall, usr, sys time: 11.0693, 9.84, 1.19 (Compute mesh entity ownership)
Process 0: Elapsed wall, usr, sys time: 6.97748, 5.89, 1.07 (Compute mesh entity ownership)
Process 0: Elapsed wall, usr, sys time: 60.7043, 56.04, 4.51 (Number mesh entities for distributed mesh (for specified vertex ids))
Process 0: Elapsed wall, usr, sys time: 60.9086, 56.24, 4.51 (Number distributed mesh entities)
Process 1: Elapsed wall, usr, sys time: 62.9243, 57.82, 4.95 (Number mesh entities for distributed mesh (for specified vertex ids))
Process 1: Elapsed wall, usr, sys time: 63.2047, 58.05, 5 (Number distributed mesh entities)
Process 0: Elapsed wall, usr, sys time: 263.355, 245.48, 17.23 (Build distributed mesh from local mesh data)
Process 1: Elapsed wall, usr, sys time: 263.765, 245.52, 17.62 (Build distributed mesh from local mesh data)
Process 0: Computing sub domain markers for sub domain 0.
Process 1: Computing sub domain markers for sub domain 0.
Process 1: Computing sub domain markers [=======> ] 17.7%
Process 0: Computing sub domain markers [======> ] 17.4%
Process 0: Computing sub domain markers [=============> ] 34.7%
Process 1: Computing sub domain markers [==============> ] 35.5%
Process 0: Computing sub domain markers [====================> ] 52.1%
Process 1: Computing sub domain markers [=====================> ] 53.2%
Process 1: Computing sub domain markers [============================> ] 70.9%
Process 0: Computing sub domain markers [===========================> ] 69.4%
Process 1: Computing sub domain markers [===================================> ] 88.7%
Process 0: Computing sub domain markers [==================================> ] 86.8%
Process 1: Computing sub domain markers [========================================] 100.0%
Process 0: Computing sub domain markers [========================================] 100.0%
Process 0: Computing sub domain markers for sub domain 1.
Process 1: Computing sub domain markers for sub domain 1.
Process 0: Computing sub domain markers [=======> ] 19.5%
Process 1: Computing sub domain markers [=======> ] 19.9%
Process 0: Computing sub domain markers [===============> ] 39.1%
Process 1: Computing sub domain markers [===============> ] 39.9%
Process 0: Computing sub domain markers [=======================> ] 58.6%
Process 1: Computing sub domain markers [=======================> ] 59.8%
Process 0: Computing sub domain markers [===============================> ] 78.1%
Process 1: Computing sub domain markers [===============================> ] 79.8%
Process 1: Computing sub domain markers [=======================================>] 99.7%
Process 0: Computing sub domain markers [=======================================>] 97.6%
Process 0: Computing sub domain markers for sub domain 2.
Process 1: Computing sub domain markers for sub domain 2.
Process 1: Computing sub domain markers [=======================> ] 57.6%
Process 0: Computing sub domain markers [======================> ] 56.4%
Process 1: Computing sub domain markers [===============================> ] 77.6%
Process 0: Computing sub domain markers [==============================> ] 75.9%
Process 1: Computing sub domain markers [=======================================>] 97.5%
Process 0: Computing sub domain markers [======================================> ] 95.5%
Process 0: Computing sub domain markers for sub domain 3.
Process 1: Computing sub domain markers for sub domain 3.
Process 0: Elapsed wall, usr, sys time: 1.307e-06, 0, 0 (Number distributed mesh entities)
Process 1: Elapsed wall, usr, sys time: 1.347e-06, 0, 0 (Number distributed mesh entities)
Process 0: Elapsed wall, usr, sys time: 6.54318, 6.3, 0.22 (Init dofmap from UFC dofmap)
Process 1: Elapsed wall, usr, sys time: 6.62935, 6.21, 0.4 (Init dofmap from UFC dofmap)
Process 0: Determining node ownership for parallel dof map
Process 1: Determining node ownership for parallel dof map
Process 1: Finished determining dof ownership for parallel dof map
Process 0: Finished determining dof ownership for parallel dof map
Process 1: Elapsed wall, usr, sys time: 0.0117398, 0.01, 0 (SCOTCH: call SCOTCH_graphBuild)
Process 0: Elapsed wall, usr, sys time: 0.0123547, 0.02, 0 (SCOTCH: call SCOTCH_graphBuild)
Process 0: Elapsed wall, usr, sys time: 7.4089, 7.35, 0.05 (SCOTCH: call SCOTCH_graphOrder)
Process 0: Elapsed wall, usr, sys time: 8.93795, 8.54, 0.38 (Compute SCOTCH graph re-ordering)
Process 1: Elapsed wall, usr, sys time: 8.4239, 8.36, 0.04 (SCOTCH: call SCOTCH_graphOrder)
Process 1: Elapsed wall, usr, sys time: 9.90392, 9.53, 0.36 (Compute SCOTCH graph re-ordering)
Process 1: Elapsed wall, usr, sys time: 48.7861, 46.76, 1.91 (Init dofmap)
Process 0: Elapsed wall, usr, sys time: 49.4835, 47.52, 1.84 (Init dofmap)
Process 0: Elapsed wall, usr, sys time: 0.000212399, 0, 0 (Apply (PETScVector))
Process 1: Elapsed wall, usr, sys time: 0.0412292, 0.02, 0.02 (Apply (PETScVector))
Process 0: Elapsed wall, usr, sys time: 0.000161234, 0, 0 (Apply (PETScVector))
Process 1: Elapsed wall, usr, sys time: 0.000541833, 0, 0 (Apply (PETScVector))
Process 0: Elapsed wall, usr, sys time: 1.73358, 1.7, 0.02 (Init dof vector)
Process 1: Elapsed wall, usr, sys time: 1.73167, 1.7, 0.02 (Init dof vector)
Process 0: Solving linear variational problem.
Process 1: Solving linear variational problem.
File "fenics_mpi.py", line 142, in <module>
fe.solve(a == L, u, bc, solver_parameters={'linear_solver': 'mumps'})
File "/users/miniconda/envs/fenics/lib/python3.7/site-packages/dolfin/fem/solving.py", line 220, in solve
File "/users/miniconda/envs/fenics/lib/python3.7/site-packages/dolfin/fem/solving.py", line 247, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to access vector of degrees of freedom.
*** Reason: Cannot access a non-const vector from a subfunction.
*** Where: This error was encountered inside Function.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 77c758717da1cb8017bf95109363bb1a91a4f8e5
solver.solve()
RuntimeError:
*** Process: 1
Any comments on this log? Feels like everything works well but suddenly stop in solver. I hope to solve this problem with direct solver and I can offer enough memory. If there is nothing wrong with my code and mesh, but just solver limitation. I may switch to iterative solver.
Thank you.
