Hi everyone,
I hop this is not too similar to this thread, but since it’s about SubDomain child classes, I opened a new one.
I try to parallelize the execution of code somewhat in the manner of below code.
import multiprocessing
class PeriodicBoundary:#(SubDomain):
def map(self, x, y):
y[0] = x[0] - 1. # L
class aClass:
def __init__(self, i):
self.aBoundary = PeriodicBoundary()
def hello(self):
print("hello ")
if __name__ == "__main__":
number_of_threads = 10
class_list = [aClass(i) for i in range(number_of_threads)]
def hello_function(instance:aClass):
instance.hello()
pool = multiprocessing.Pool(processes=number_of_threads)
pool.map(hello_function, class_list)
pool.close()
This code works if you leave out the inheritance of SubDomain, but once you put it in, multiprocessing.Pool cannot run, because the PeriodicBoundary class cannot be pickled.
TypeError: can't pickle PeriodicBoundary objects
While the solution in this thread will work perfectly well in the real case I use, it will be very clunky and not modular at all. So I am wondering if anyone knows why this problem happens and how to circumvent it.
Best,
David
