Can't run Navier-Stokes solution in parallel
Hello there,
I have a script that solves the 3D fluid flow over a sphere in a rectangular channel. This script is basically adapted from one of the tutorials. I split the script into two files, one part that I run in serial to create the mesh, subdomains and boundaries,
python3 laminar_flow_mwe_serial.py
and another that is supposed to run in parallel to actually solve the problem.
# WORKS
python3 laminar_flow_mwe_parallel.py
# WORKS!
mpirun -np 1 python3 laminar_flow_mwe_parallel.py
# DOES NOT WORK!
mpirun -np 2 python3 laminar_flow_mwe_parallel.py
The issue I have is that, whenever I try to use more than 1 process to run the script, it freezes. to be specific, the processes are created, they are using about 100% of CPU each, and in this case each uses about 5% of my memory. But nothing else happens, this can be running forever and does not complete more than one iteration. I know that it is stuck after the first iteration because I can see that the XDMF files with the results are created, but then they do not grow in size, which should happen after each time step’s solution is added to the file (this happens when run in serial). Based on what I saw, it seems to iterate forever in the first step of the time loop (tentative velocity step).
Trying to find what the issue is, I have tested many solver/pre-conditioner combinations. None of them work in parallel, some of them work in serial (problem diverges with some solvers, I think).
I have tested this in the current docker images (both the 2019 stable and the most recent dev image), and also in an anaconda installation of fenics. I also tested the 2018 version, with the same results.
Here are the two files (inserted inline b/c did not find a way to add attachments):
laminar_flow_mwe_serial.py - Creates the mesh, subdomains and boundaries.
Channel with sphere - Part 1 - Serial Code
Code to generate rectangular channel with a sphere in cross-flow. This will be used to develop and test Navier-Stokes equations.
It also creates a spherical subdomain downstream of the sphere cut-out. This will be used to test surface and volume integrals.
Part 1 - Generatese and saves the mesh, boundaries and subdomains into H5 files.
# Environment setup
import os
# This may work to speed up mesh generation and/or matrix assembly
# DO NOT COMBINE WITH MPI
os.putenv("OMP_NUM_THREADS","4")
os.putenv("OPENBLAS_NUM_THREADS","4")
# FEniCS imports
mpi_comm = MPI.comm_world
mpi_rank = mpi_comm.Get_rank()
# Basic simulation parameters (m, kg, s)
D = 0.01                    # diameter of the sphere
radius=0.5*D                # radius
D_perturb = 0.005           # perturbation to create asymmetric mesh
n_segments = 50             # mesh segments at the surface of the sphere
n_cells_per_dir = 64        # mesh resolution for generate_mesh()
# Create mesh
box_size = np.array([12*D, 4*D, 4*D])
center = np.array([4*D,2*D+D_perturb,2*D])
channel = Box(Point(0.0, 0.0, 0.0), Point(box_size))
sphere = Sphere(Point(center), radius=D/2, segments=n_segments)
domain = channel - sphere
mesh = generate_mesh(domain, n_cells_per_dir)
# Define boundaries
def inflow_fun(x,xlim=0.0):
    return near(x[0],xlim)
def outflow_fun(x,xlim=box_size[0]):
def walls_fun(x,xlim=box_size):
    return (
            near(x[1],0.0) or
            near(x[1],xlim[1]) or
            near(x[2],0.0) or
            near(x[2],xlim[2])
def sphere_fun(x,center=center,radius = radius):
    return (
        x[0] >= center[0] - radius and
        x[0] <= center[0] + radius and
        x[1] >= center[1] - radius and
        x[1] <= center[1] + radius and
        x[2] >= center[2] - radius and
        x[2] <= center[2] + radius
# This is here so we can use it when we need to define an additional subdomain
dummy_position = 0.5 * box_size
# placed 2*D downstream of the sphere
dummy_position[0] = center[0] + 4 * radius
def dummy_subdomain_fun(x,center=dummy_position,radius=radius):
    # start at the center of the box
    # subdomain is a sphere
    return (np.sqrt(np.sum(np.square(x-center))) <= radius)
class Inflow(SubDomain):
        return inflow_fun(x) and on_boundary
class Outflow(SubDomain):
        return outflow_fun(x) and on_boundary
class Walls(SubDomain):
        return walls_fun(x) and on_boundary
class Sphere(SubDomain):
        return sphere_fun(x) and on_boundary
class DummySubdomain(SubDomain):
        return dummy_subdomain_fun(x)
boundaries = MeshFunction('size_t', mesh, mesh.topology().dim()-1)
subdomains = MeshFunction('size_t', mesh, mesh.topology().dim())
inflow_bnd = Inflow()
outflow_bnd = Outflow()
walls_bnd = Walls()
sphere_bnd = Sphere()
dummy_subdomain = DummySubdomain()
# marking boundaries
boundaries.set_all(0)
inflow_bnd.mark(boundaries, 1)
outflow_bnd.mark(boundaries, 2)
walls_bnd.mark(boundaries, 3)
# the sphere could have gotten the same marker b/c they are both no-slip
sphere_bnd.mark(boundaries, 4)
# mark subdomains
subdomains.set_all(0)
dummy_subdomain.mark(subdomains, 1)
# save mesh and boundaries
# File names
basename = "channel_sphere/channel_sphere"
mesh_filename = basename + "_mesh.xdmf"
subdomains_filename = basename + "_subdomains.xdmf"
boundaries_filename = basename + "_boundaries.xdmf"
## Use XDMF files
# # write the mesh
file_mesh = XDMFFile(mpi_comm, mesh_filename)
file_mesh .write(mesh)
# write subdomains
file_subdomains = XDMFFile(mpi_comm, subdomains_filename)
file_subdomains.write(subdomains)
# write boundaries
file_boundaries = XDMFFile(mpi_comm, boundaries_filename)
file_boundaries.write(boundaries)
# # Extra, for visualization with ParaView (though XDMF can also be used here)
# File("channel_sphere/channel_sphere.pvd") << mesh
# File("channel_sphere/boundaries.pvd") << boundaries
# File("channel_sphere/subdomains.pvd") << subdomains
laminar_flow_mwe_parallel.py - Solves 3D, transient, laminar Navier-Stokes
Channel with sphere - Part 2 - Parallel Code
It also creates a spherical subdomain downstream of the sphere cut-out. This will be used to test surface and volume integrals later on.
Part 2 - Loads mesh, boundaries and subdomains from files, it then applies boundary conditions, assembles and solves.
# Environment setup
import os
# FEniCS imports
# Define communicator and rank for this process, in case we are running with MPI
# These are used for set_log_level() in DOLFIN
CRITICAL  = 50  # errors that may lead to data corruption and such
ERROR     = 40  # things that go boom
WARNING   = 30  # things that may go boom later
INFO      = 20  # information of general interest
PROGRESS  = 16  # what's happening (broadly)
TRACE     = 13  # what's happening (in detail)
DBG       = 10  # sundry
set_log_level(INFO)
parameters["std_out_all_processes"] = True
#parameters['ghost_mode'] = 'none' #'shared_facet'
parameters["allow_extrapolation"] = True
#parameters["num_threads"] = 8
PETScOptions.set('pc_type', 'asm')
#PETScOptions.set('sub_pc_type', 'hypre_amg')
PETScOptions.set('sub_pc_type', 'ilu')
#PETScOptions.set('sub_pc_type', 'lu')
#PETScOptions.set('pc_asm_overlap', '100')
T = 0.01                 # final time
#mu = 8.9E-4             # dynamic viscosity of water
mu = 18.37E-6            # dynamic viscosity of air
rho = 1.0                # density (FENICS tutorial had density of 1)
radius = 0.5*D              # radius
Re = 625                    # Reynolds number based on channel height/width
Vmax = mu * Re / (rho * (4*D))  # Inflow velocity
# Load mesh and mesh function for subdomains#
# file names
# read the mesh
mesh = Mesh(mpi_comm)
with XDMFFile(mpi_comm, mesh_filename) as xdmf_infile:
    xdmf_infile.read(mesh)
# read subdomains
# Define a mesh value collection of dim = 3, for the cell data
mvc_internal = MeshValueCollection("size_t", mesh=mesh, dim=3)
# read subdomain data into the mesh value collection
with XDMFFile(mpi_comm, subdomains_filename) as xdmf_infile:
    xdmf_infile.read(mvc_internal)
# create a mesh function from the mesh value collection
subdomains = MeshFunction("size_t", mesh, mvc_internal)
# read boundaries
# Define a mesh value collection of dim = 2, for the facet data (boundaries)
mvc_boundaries = MeshValueCollection("size_t", mesh=mesh, dim=2)
with XDMFFile(mpi_comm, boundaries_filename) as xdmf_infile:
    xdmf_infile.read(mvc_boundaries)
boundaries = MeshFunction("size_t", mesh, mvc_boundaries)
# Calculate dt as per CFL (with CFLmax = 0.5)
deltaX = mesh.hmin() # minimum mesh size
dt = 0.5*deltaX**2/mu
dt = 1E-2*dt # Just for testing
# number of time steps to reach target final time
num_steps = int(T/dt) + 1    # number of time steps
### SUBDOMAINS
# 0: Fluid
# 1: Spherical region downstream of the actual sphere
### BOUNDARIES
# 1: Inflow
# 2: Outflow
# 3: Walls
# 4: Sphere surfaces
# Define function spaces
Q = FunctionSpace(mesh, 'P', 1)
# Define inflow profile
inflow_profile = (\
    '{}*(1.0 - pow((x[2]-{})/({}),2))*(1.0 - pow((x[1]-{})/({}),2))'.format(\
    Vmax, 2*D, 2*D, 2*D, 2*D), '0', '0')
# Define boundary conditions USING SUBDOMAINS FROM MESH FUNCTION
bcu_inflow = DirichletBC(V, Expression(inflow_profile, degree=2), boundaries, 1)
bcu_walls = DirichletBC(V, Constant((0, 0, 0)), boundaries, 3)
bcu_sphere = DirichletBC(V, Constant((0, 0, 0)), boundaries, 4)
bcp_outflow = DirichletBC(Q, Constant(0), boundaries, 2)
bcu = [bcu_inflow, bcu_walls, bcu_sphere]
bcp = [bcp_outflow]
p = TrialFunction(Q)
q = TestFunction(Q)
# Define functions for solutions at previous and current time steps
u_n = Function(V)
u_  = Function(V)
p_n = Function(Q)
p_  = Function(Q)
U  = 0.5*(u_n + u)      # looks like Crank-Nicholson
n  = FacetNormal(mesh)
f  = Constant((0, 0, 0))
k  = Constant(dt)
mu = Constant(mu)
rho = Constant(rho)
# Define symmetric gradient
    return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
    return 2*mu*epsilon(u) - p*Identity(len(u))
dx = Measure('dx', domain=mesh, subdomain_data=subdomains)
# dS = Measure('dS', domain=mesh, subdomain_data=subdomains)
# Define variational problem for step 1
F1 = rho*dot((u - u_n) / k, v)*dx \
   + rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx \
   + inner(sigma(U, p_n), epsilon(v))*dx \
   + dot(p_n*n, v)*ds - dot(mu*nabla_grad(U)*n, v)*ds \
   - dot(f, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q))*dx
L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/k)*div(u_)*q*dx
a3 = dot(u, v)*dx
L3 = dot(u_, v)*dx - k*dot(nabla_grad(p_ - p_n), v)*dx
# Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
# Apply boundary conditions to matrices
[bc.apply(A1) for bc in bcu]
[bc.apply(A2) for bc in bcp]
# Create XDMF files for visualization output
xdmffile_u = XDMFFile(mpi_comm, 'results/velocity.xdmf')
xdmffile_p = XDMFFile(mpi_comm, 'results/pressure.xdmf')
# Time-stepping
t = 0
for n in range(num_steps):
    # Update current time
    if mpi_rank == 0:
       print('**********\nTime: {}/{}\n'.format(t,T))
    ## Create solver??? Change parameters of existing default solver???
    # this would be the place to do it
    # print("** Solving tentative velocity step...\n" )
    if mpi_rank == 0:
    b1 = assemble(L1)
    [bc.apply(b1) for bc in bcu]
    #solve(A1, u_.vector(), b1) # fails b/c out of memory
    #solve(A1, u_.vector(), b1, 'bicgstab', 'petsc_amg')
    #parallel
    #solve(A1, u_.vector(), b1, 'gmres', 'jacobi')
    #solve(A1, u_.vector(), b1, 'gmres', 'default')
    #solve(A1, u_.vector(), b1, 'gmres', 'petsc_amg')
    #solve(A1, u_.vector(), b1, 'bicgstab', 'hypre_amg')
    # solve(A1, u_.vector(), b1, 'superlu') # doesn't work in serial, crazy memory use
    #solve(A1, u_.vector(), b1, 'bicgstab', 'default')
    solve(A1, u_.vector(), b1, 'gmres')
    if mpi_rank == 0:
        print("** Done!\n" )
    # print("** Solving pressure correction step...\n" )
    if mpi_rank == 0:
    b2 = assemble(L2)
    [bc.apply(b2) for bc in bcp]
    #solve(A2, p_.vector(), b2, 'bicgstab', 'hypre_euclid')
    #solve(A2, p_.vector(), b2, 'bicgstab', 'hypre_amg')
    #solve(A2, p_.vector(), b2)
    #solve(A2, p_.vector(), b2, 'gmres', prec)
    #parallel
    solve(A2, p_.vector(), b2, 'gmres', 'hypre_amg')
    #solve(A2, p_.vector(), b2, 'minres', 'hypre_amg')
    if mpi_rank == 0:
    # print("** Done!\n" )
    # print("** Solving velocity correction step...\n" )
    if mpi_rank == 0:
    b3 = assemble(L3)
    #solve(A3, u_.vector(), b3, 'cg', 'sor')
    #solve(A3, u_.vector(), b3, 'bicgstab', 'sor')
    #solve(A3, u_.vector(), b3, 'gmres', 'default')
    #parallel
    # solve(A3, u_.vector(), b3, 'bicgstab', 'jacobi')
    # solve(A3, u_.vector(), b1, 'gmres', 'petsc_amg')
    #solve(A3, u_.vector(), b3, 'mumps', 'ilu')
    solve(A3, u_.vector(), b3, 'gmres', 'jacobi')
    if mpi_rank == 0:
    xdmffile_u.write(u_, t)
    xdmffile_p.write(p_, t)
    # Update previous solution
    if mpi_rank == 0:
        print("** Updating solution for next iteration...\n" )
    u_n.assign(u_)
    p_n.assign(p_)
    if mpi_rank == 0:
    if mpi_rank == 0:
        print('**********Time step {}/{} completed.\t Time: {}/{} \t u max: {}\n'.format(n+1, num_steps, t, T, u_.vector().max()))
Any ideas about what the problem might be? Any help is appreciated, this is driving me crazy.
I tested your code, and I guess the problem lies in the last line. You try getting the maximal value of a distributed vector. With the following modification I can run the script with two mpi processes:
    d = Vector()
    d = u_.vector().gather_on_zero()
    if mpi_rank == 0:
        print('**********Time step {}/{} completed.\t Time: {}/{} \t u max: {}\n'.format(n+1, num_steps, t, T, d.max()))
Thanks @volkerk.
I implemented the modification you suggested, and that did not help the situation. I still kept it, because yours is the right way to do that operation. So thanks for that.
After much testing, it turns out that the problem is caused before reaching that part of the code. It happens before the loop even starts, in the following lines:
The problem is that the value of hmin may be different in each process, because the value of mesh.hmin() reported by each process is different (or may be different) depending on how the mesh is partitioned among the processes. I verified that these values are different by using a simple print statement following that calculation.
As a result, the value of num_steps can be different in each process, depending on the target final time T and how that and hmin affect the final results of the truncating operation int(T/dt) + 1. So I found myself in a situation in which 3 of the 4 processes I was using had a value of num_steps of 8, while one process had a value of 9. I believe this caused a hang/deadlock in interprocess communication, e.g. the process running an additional step (Process 2 in my case) waiting for a send/receive to complete before exiting.
At least that is my interpretation of what was happening. If anyone else has a different or better explanation, I would like to learn it. Otherwise, this should be marked as solved.
Thanks to anyone who read these posts and gave it a thought. Apologies for wasting your time on what should have been an easy-to-spot bug in the code.
