Hi everyone,
Not sure if this is a problem, but I’m wondering why I can’t use gmres with the hypre_euclid preconditioner to solve the problem defined in the Cahn-Hillard example.
Indeed, if I run the following (which is just a slight modification of the original script that is compliant with the current fenics version and modified to use gmres and hypre_eucluid):
import random
# Class representing the intial conditions
class InitialConditions(UserExpression):
def __init__(self):
super(InitialConditions, self).__init__()
random.seed(2 + MPI.comm_world.Get_rank())
def eval(self, values, x):
values[0] = 0.63 + 0.02*(0.5 - random.random())
values[1] = 0.0
def value_shape(self):
return (2,)
# Model parameters
lmbda = 1.0e-02 # surface parameter
dt = 5.0e-06 # time step
theta = 0.5 # time stepping family, e.g. theta=1 -> backward Euler, theta=0.5 -> Crank-Nicolson
# Create mesh and define function spaces
mesh = UnitSquareMesh(96, 96)
CG1 = FiniteElement("CG", triangle, 1)
mixed_element = MixedElement([CG1, CG1])
ME = FunctionSpace(mesh, mixed_element)
du = TrialFunction(ME)
q, v = TestFunctions(ME)
# Define functions
u = Function(ME) # current solution
u0 = Function(ME) # solution from previous converged step
# Split mixed functions
dc, dmu = split(du)
c, mu = split(u)
c0, mu0 = split(u0)
# Create intial conditions and interpolate
u_init = InitialConditions()
u.interpolate(u_init)
u0.interpolate(u_init)
# Compute the chemical potential df/dc
c = variable(c)
f = 100*c**2*(1-c)**2
dfdc = diff(f, c)
# mu_(n+theta)
mu_mid = (1.0-theta)*mu0 + theta*mu
# Weak statement of the equations
L0 = c*q*dx - c0*q*dx + dt*dot(grad(mu_mid), grad(q))*dx
L1 = mu*v*dx - dfdc*v*dx - lmbda*dot(grad(c), grad(v))*dx
L = L0 + L1
# Compute directional derivative about u in the direction of du (Jacobian)
a = derivative(L, u, du)
# Create nonlinear problem and Newton solver
problem = NonlinearVariationalProblem(L, u, J=a)
solver.parameters['newton_solver']['linear_solver'] = "gmres"
solver.parameters['newton_solver']['preconditioner'] = "hypre_euclid"
# Step in time
t = 0.0
T = 50*dt
while (t < T):
u0.vector()[:] = u.vector()
solver.solve()
I get the following error:
RuntimeError:
*** Reason: Solution failed to converge in 0 iterations (PETSc reason DIVERGED_NANORINF, residual norm ||r|| = 0.000000e+00).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 0
*** Git changeset: unknown
Thank you in advance.
