Hi all,
I’m currently using the Docker installation of FEniCS and can’t manage to plot with matplotlib correctly.
When running the FEniCS container with the command fenicsproject run the message After calling 'plt.show()' you can access matplotlib plots at http://localhost:3000 is displayed. Though the code below doesn’t plot anything at this adress. Does anyone has an idea ? Thanks!
mesh = UnitCubeMesh(4, 4, 4)
plot(mesh)
