Can't write DG0 time data to VTX
I can’t seem to write the time evolution of a DG0 function with VTXWriter. The values always stay the same for all time steps. This doesn’t occur with other interpolations (I tested CG1 and DG1 so far). Here is a MWE to illustrate what I mean:
domain = mesh.create_unit_square(MPI.COMM_WORLD, 2, 2)
V = fem.functionspace(domain, ("DG", 0))
v = fem.Function(V)
vtx = io.VTXWriter(domain.comm, "result.bp", v)
vtx.write(0.0)
v.interpolate(lambda x: np.full((x.shape[1],), 1))
vtx.write(1.0)
vtx.close()
I would expect the value of my field to be 0 at time 0 and 1 at time 1, but it is always 0 when I view the .bp in Paraview. Again, using another interpolation the result is as expected. Running v0.8.0 of dolfinx.
At first I thought this was just an issue in DOLFINx, so I modified the writer to add the time step counter into CellData, ref: Comparing main...dokken/time-dependent-celldata · FEniCS/dolfinx · GitHub
Inspecting the results.bp file, with the following MWE i get:
from dolfinx import mesh, fem, io, default_scalar_type
v = fem.Function(V)
vtx.write(0.0)
v.interpolate(lambda x: np.arange(1,1+x.shape[1], dtype=default_scalar_type))
vtx.write(1.0)
vtx.close()
 bpls result.bp/ -a -l
  uint32_t  NumberOfCells        2*{1} = 8 / 8
  uint32_t  NumberOfNodes        2*{1} = 9 / 9
  int64_t   connectivity         2*[1]*{8, 4} = 0 / 8
  double    f                    2*[1]*{8, 1} = 0 / 8
  double    geometry             2*[1]*{9, 3} = 0 / 1
  double    step                 2*scalar = 0 / 1
  uint32_t  types                2*scalar = 69 / 69
  string    vtk.xml              attr   =
<VTKFile type="UnstructuredGrid" version="0.1">
  <UnstructuredGrid>
    <Piece NumberOfPoints="NumberOfNodes" NumberOfCells="NumberOfCells">
      <Points>
        <DataArray Name="geometry" />
      </Points>
      <Cells>
        <DataArray Name="connectivity" />
        <DataArray Name="types" />
      </Cells>
      <PointData>
        <DataArray Name="vtkOriginalPointIds" />
        <DataArray Name="vtkGhostType" />
      </PointData>
      <CellData>
        <DataArray Name="TIME">step</DataArray>
        <DataArray Name="f" />
      </CellData>
    </Piece>
  </UnstructuredGrid>
</VTKFile>
  uint8_t   vtkGhostType         2*[1]*{9} = 0 / 0
  int64_t   vtkOriginalPointIds  2*[1]*{9} = 0 / 8
which seems correct.
Next, I checked if the data is correctly written to f with
bpls result.bp/ -a -l f -d
        step 0:
          block 0: [0:7, 0:0] = 0 / 0
    (0,0)    0 0 0 0 0 0
    (6,0)    0 0
        step 1:
          block 0: [0:7, 0:0] = 1 / 8
    (0,0)    1 2 3 4 5 6
    (6,0)    7 8
which looks correct. However opening it in paraview, I cannot step between the two time steps:
As you can see in data statistics, it realizes that there are two time steps,l but in data arrays we can observe that f is always 0. This seems to be an issue with Paraview’s VTXWriter.
I’ve made an issue at: Time dependent VTX CellData not rendered correctly in Paraview · Issue #4179 · ornladios/ADIOS2 · GitHub which might be transferred to VTK depending on what the developers says.
Thank you for the quick look at the issue. Any apparent reason why this only happens with DG0 interpolation, though?
Its because of how paraview/VTXReader reads cell data. In the original VTX documentation, there was only time dependent point data, no cell data, so I guess this is an oversight on their end.
Confirmed as an issue by the developers: Time dependent VTX CellData not rendered correctly in Paraview · Issue #4179 · ornladios/ADIOS2 · GitHub
We cant do much more than wait and see
FYI, I tested it out with the nightly binaries that Paraview offers on their website and it was fixed there.
