I am solving a stationary navier stokes problem that have a problem on the pressure field on one point of the inlet section. I was told that changing the ordering of the cells around that region might resolve the issue.
I was wondering if there is any way of permuting the ordering of a given mesh without having to reconstructing it.
Here is a MWE that might clarify what I’m trying to achieve:
import dolfinx.fem.petsc
import pyvista
from dolfinx import fem
import dolfinx.plot as dplt
from dolfinx.fem import (Constant, VectorFunctionSpace, Function, FunctionSpace, assemble_scalar,
dirichletbc, form, locate_dofs_topological,extract_function_spaces)
from dolfinx.fem.petsc import LinearProblem, NonlinearProblem
from dolfinx.mesh import create_unit_square, locate_entities, meshtags, create_rectangle, CellType, Mesh
from ufl import (VectorElement,FiniteElement,FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction, TrialFunctions, TestFunctions,
div, dot, dx, grad, inner, lhs, rhs, MixedElement, nabla_grad, split)
msh = create_rectangle(comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (1.0, 3.0)), n=(25, 75),
cell_type=CellType.triangle)
fdim = msh.topology.dim
msh.topology.create_connectivity(msh.topology.dim, msh.topology.dim-1)
num_facets_owned_by_proc = msh.topology.index_map(fdim).size_local
facets_entitites = _cpp.mesh.entities_to_geometry(msh, fdim, np.arange(num_facets_owned_by_proc, dtype=np.int32), False)
num_facets_owned_by_proc_1 = msh.topology.index_map(fdim-1).size_local
edges_entitites = _cpp.mesh.entities_to_geometry(msh, fdim-1, np.arange(num_facets_owned_by_proc_1, dtype=np.int32), False)
points = msh.geometry.x
for e, entity in enumerate(facets_entitites):
print(e,entity)
for e, entity in enumerate(edges_entitites):
print(e,entity)
# I want to shuffle the cells and edges within the msh object as I can do with the retrived data
np.random.seed(1)
np.random.shuffle(facets_entitites)
np.random.shuffle(edges_entitites)
Thanks
