It does not seem like you have an appropriate version of PETSc installed
It seems like you are on the DOLFINx main branch, and not on the 0.5.X branch that is compatible with your ffcx installation
Well this is strange because this is the version I have installed:
Version: 3.18.2
So I don’t know how I can fix that.
Now I’m in the c++ build and this is what it outputs:
CMake Error at /home/krizerator/.local/lib/python3.8/site-packages/cmake/data/share/cmake-3.25/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
Could NOT find UFCx: Found unsuitable version "0.5.0.post0", but required
is at least "0.6" (found
/usr/lib/python3/dist-packages/ffcx/codegeneration)
Reason given by package: UFCx could not be found.
Call Stack (most recent call first):
/home/krizerator/.local/lib/python3.8/site-packages/cmake/data/share/cmake-3.25/Modules/FindPackageHandleStandardArgs.cmake:598 (_FPHSA_FAILURE_MESSAGE)
cmake/modules/FindUFCx.cmake:63 (find_package_handle_standard_args)
CMakeLists.txt:199 (find_package)
Looks like the exact same thing as before, I’m not sure if I’m doing it right
Did you set PETSC_DIR and PETSC_ARCH so that it points to the installation of PETSc?
Make sure that the branches of DOLFINx, FFCx and Basix are consistent, and that python3 -m pip list
lists these versions of fenics-basix
and fenics-ffcx
Yes I set them to the installation directory and the versions of basix and ffcx are 0.5.0 and 0.5.0.post0 respectively. Still the same error.
What is the output of git branch
when you call it from within the dolfinx folder?
The output is this:
* main
You should not use the main branch of DOLFINx if you use the 0.5.X version of the other libraries. You should use the v0.5.2
branch Release v0.5.2 · FEniCS/dolfinx · GitHub
Excuse me the question if it’s too basic, but how can I use this version? I’ve only used GitHub a few times and I’m not sure how this works. I just want to make fenics work in my pc but neither legacy fenics or fenicsx work and I need to make sure I can simulate stuff. I’m really worried because it’s taken a long time for me to achieve this trying to fix packages and so on. Isn’t there an “easy way” to install fenics? I mean I know how to program but I’m not an expert in a lot of things like docker (I don’t even know what a container is in programming) or Git. Some time ago fenics worked fine but now it doesn’t. I could even generate simulations like this but not anymore:
If there is an easy way out of all of this and you know it, like uninstalling and reinstalling properly or something I’d appreciate it.
Use git checkout v0.5.2
inside the dolfinx repo
I have already referred you to
You will have an issue with trying to install both dolfin and dolfinx globally on your system, as they depend on different versions of ufl.
Long story short: to make life simple, use conda to install dolfin/dolfinx
I followed the steps for conda and into the fenicsx-env I ran the program and still there are some errors:
INFO:root:running build_ext
INFO:root:building 'libffcx_forms_3ab349c4998802b05e03df1716e1be81cd712806' extension
INFO:root:/home/krizerator/anaconda3/envs/fenicsx-env/bin/x86_64-conda-linux-gnu-cc -Wno-unused-result -Wsign-compare -DNDEBUG -fwrapv -O2 -Wall -fPIC -O2 -isystem /home/krizerator/anaconda3/envs/fenicsx-env/include -fPIC -O2 -isystem /home/krizerator/anaconda3/envs/fenicsx-env/include -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/krizerator/anaconda3/envs/fenicsx-env/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/krizerator/anaconda3/envs/fenicsx-env/include -fPIC -I/home/krizerator/anaconda3/envs/fenicsx-env/lib/python3.10/site-packages/ffcx/codegeneration -I/home/krizerator/anaconda3/envs/fenicsx-env/include/python3.10 -c libffcx_forms_3ab349c4998802b05e03df1716e1be81cd712806.c -o ./libffcx_forms_3ab349c4998802b05e03df1716e1be81cd712806.o -O2 -g0
INFO:root:/home/krizerator/anaconda3/envs/fenicsx-env/bin/x86_64-conda-linux-gnu-cc -shared -Wl,--allow-shlib-undefined -Wl,-rpath,/home/krizerator/anaconda3/envs/fenicsx-env/lib -Wl,-rpath-link,/home/krizerator/anaconda3/envs/fenicsx-env/lib -L/home/krizerator/anaconda3/envs/fenicsx-env/lib -Wl,--allow-shlib-undefined -Wl,-rpath,/home/krizerator/anaconda3/envs/fenicsx-env/lib -Wl,-rpath-link,/home/krizerator/anaconda3/envs/fenicsx-env/lib -L/home/krizerator/anaconda3/envs/fenicsx-env/lib -Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,--disable-new-dtags -Wl,--gc-sections -Wl,--allow-shlib-undefined -Wl,-rpath,/home/krizerator/anaconda3/envs/fenicsx-env/lib -Wl,-rpath-link,/home/krizerator/anaconda3/envs/fenicsx-env/lib -L/home/krizerator/anaconda3/envs/fenicsx-env/lib -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/krizerator/anaconda3/envs/fenicsx-env/include -DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /home/krizerator/anaconda3/envs/fenicsx-env/include ./libffcx_forms_3ab349c4998802b05e03df1716e1be81cd712806.o -o ./libffcx_forms_3ab349c4998802b05e03df1716e1be81cd712806.cpython-310-x86_64-linux-gnu.so
WARNING:py.warnings:/home/krizerator/anaconda3/envs/fenicsx-env/lib/python3.10/site-packages/pyvista/plotting/plotting.py:131: UserWarning:
This system does not appear to be running an xserver.
PyVista will likely segfault when rendering.
Try starting a virtual frame buffer with xvfb, or using
``pyvista.start_xvfb()``
warnings.warn(
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple MacOS to find memory corruption errors
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
system msg for write_line failure : Bad file descriptor
I also did this
Thank you so much! Looks like things are starting to work out now but somehow strange… When I start running the code, looks like there’s only one import error towards ufl:
(base) krizerator@Clarke:/mnt/d/A--X/Programming/Python$ python3 demo_poisson.py
File "demo_poisson.py", line 72, in <module>
ModuleNotFoundError: No module named 'ufl'
Notice that this happens when I run it on the base. But when I run it in the venv mentioned in Problem about pyvista - #2 by dokken, then I get this:
(fenicsx-env) krizerator@Clarke:/mnt/d/A--X/Programming/Python$ python3 demo_poisson.py
Why would it be? And what could I do to fix the import problem? I already checked the ufl but it’s installed:
(base) krizerator@Clarke:/mnt/d/A--X/Programming/Python$ pip3 show ufl
Version: 2017.1.0
Summary: Unified Form Language
Home-page: https://bitbucket.org/fenics-project/ufl/
Author: Martin Sandve Alnæs, Anders Logg
Author-email: fenics-dev@googlegroups.com
License: UNKNOWN
Location: /home/krizerator/.local/lib/python3.8/site-packages
Requires: numpy, six
Required-by:
Mixing conda
and pip
is not adviced, as your pip3
installation is probably not linked to the conda python env
. Try calling python3 -m pip show ufl
and see what you get.
Try to remove the last few lines of the demo poisson (that uses pyvista) and I guess the code will be running fine.
It is unclear to me what you have added from
as you do not show the code.
Hello and happy new year, best wishes!
I figured out that effectively when I’m using conda, ufl and other packages are not found. As soon as I quit conda, there’s not that problem anymore.
I just followed the instructions as mentioned there. It looks like it worked.
Now, I removed the last lines as you mentioned for demo_poisson.py but now I get this error:
[0]PETSC ERROR: or see https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
malloc_consolidate(): invalid chunk size
[Clarke:00459] *** Process received signal ***
[Clarke:00459] Signal: Aborted (6)
[Clarke:00459] Signal code: (-6)
[Clarke:00459] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f5f805bd090]
[Clarke:00459] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7f5f805bd00b]
[Clarke:00459] [ 2] /lib/x86_64-linux-gnu/libc.so.6(abort+0x12b)[0x7f5f8059c859]
[Clarke:00459] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x8d26e)[0x7f5f8060726e]
[Clarke:00459] [ 4] /lib/x86_64-linux-gnu/libc.so.6(+0x952fc)[0x7f5f8060f2fc]
[Clarke:00459] [ 5] /lib/x86_64-linux-gnu/libc.so.6(+0x95ad8)[0x7f5f8060fad8]
[Clarke:00459] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0x97c83)[0x7f5f80611c83]
[Clarke:00459] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_malloc+0x1b9)[0x7f5f80614299]
[Clarke:00459] [ 8] /lib/x86_64-linux-gnu/libopen-pal.so.40(opal_show_help_yy_create_buffer+0x39)[0x7f5f774e0219]
[Clarke:00459] [ 9] /lib/x86_64-linux-gnu/libopen-pal.so.40(opal_show_help_init_buffer+0x12)[0x7f5f774e1a32]
[Clarke:00459] [10] /lib/x86_64-linux-gnu/libopen-pal.so.40(opal_show_help_vstring+0x1a3)[0x7f5f774dfa73]
[Clarke:00459] [11] /lib/x86_64-linux-gnu/libopen-rte.so.40(orte_show_help+0xe3)[0x7f5f77554413]
[Clarke:00459] [12] /lib/x86_64-linux-gnu/libmpi.so.40(MPI_Abort+0x70)[0x7f5f79c2add0]
[Clarke:00459] [13] /lib/x86_64-linux-gnu/libpetsc_real.so.3.12(PetscSignalHandlerDefault+0x1e2)[0x7f5f606d34f2]
[Clarke:00459] [14] /lib/x86_64-linux-gnu/libpetsc_real.so.3.12(+0x12c577)[0x7f5f606d3577]
[Clarke:00459] [15] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f5f805bd090]
[Clarke:00459] [16] /home/krizerator/.local/lib/python3.8/site-packages/basix/_basixcpp.cpython-38-x86_64-linux-gnu.so(+0x2eb1b)[0x7f5f5f552b1b]
[Clarke:00459] [17] /home/krizerator/.local/lib/python3.8/site-packages/basix/_basixcpp.cpython-38-x86_64-linux-gnu.so(+0x3f63d)[0x7f5f5f56363d]
[Clarke:00459] [18] /home/krizerator/.local/lib/python3.8/site-packages/basix/_basixcpp.cpython-38-x86_64-linux-gnu.so(+0x43eb8)[0x7f5f5f567eb8]
[Clarke:00459] *** End of error message ***
Aborted
Again it seems like you are linking against an outdated version of PETSc
I just tried installing with Ubuntu instructions from a VM and it works. I couldn’t solve the problem with petsc but at least now I can see the results.
