Combination of derivative and custom derivative
Hi, I am trying to solve a time-dependent non-linear elasticity problem. The boundary conditions are implemented using a Nitsche method which results in a nonlinear problem. Discretization results in a mixed problem, which has to be solved in each iteration.
I am not sure, if derivative() can also handle the part
F2 = gamma/h**2 * dot(ppos(dot(u, n)), dot(phi2, n)) * ds(1)
My idea was to use derivative on the form F1 and provide the derivative of F2 by hand and sum up both to get the Jacobian for the NonLinearVariational solver.
Unfortunately I get the error:
ufl.algorithms.check_arities.ArityMismatch: Adding expressions with non-matching form arguments () vs ('v_0',).
Is this the right idea to handle the derivative?
I provided a MWE below.
Thank you
from vtkplotter.dolfin import plot as dolfin_plot
from ufl import nabla_div
import sys
from mshr.cpp import Rectangle, generate_mesh
if __name__ == '__main__':
    #TODO: https://fenicsproject.org/qa/12129/computing-jacobian-manually-coupled-problem-hilliard-equation/
    k = 10
    # Define geometry
    l_end = -3.0
    r_end = 3.0
    t_end = 2.0
    b_end = 0.0
    m_t_end = 1.0
    m_l_end = -1.5
    m_r_end = 1.5
    l_b_end = 1.0
    r_b_end = 1.0
    t_l_r_end = -0.75
    t_r_l_end = 0.75
    rect1 = Rectangle(Point(l_end, l_b_end), Point(t_l_r_end, t_end))
    rect2 = Rectangle(Point(t_r_l_end, r_b_end), Point(r_end, t_end))
    rect3 = Rectangle(Point(m_l_end, b_end), Point(m_r_end, m_t_end))
    rect = rect1 + rect2 + rect3
    mesh = generate_mesh(rect, k)
    # Plot mesh
    #dolfin_plot(mesh, title="Mesh")
    # Degree of interpolation polynomials
    degree = 2
    # parameters
    rho = 1
    # Lamé constants
    mu = 1
    beta = 1.25
    lambda_ = beta
    # constants
    gamma_nitsche = Constant(100.0)
    # Time stepping parameters
    T_start = 0
    T_final = 10  # final time
    t = 0
    num_steps = 10   # number of time steps
    dt = (T_final - T_start)/num_steps    # time step size
    # Define function space for system of PDEs
    P1 = VectorElement('Lagrange', cell=triangle, degree=degree)
    element = MixedElement([P1, P1])
    tol = 1E-14
    def clamped_boundary(x, on_boundary):  # beam is only fixed on the left end
        return on_boundary and near(x[0], 0.0, tol) #x[0] < tol
    u_D1 = Constant((0, 0))
    bc1 = DirichletBC(V.sub(0), u_D1, clamped_boundary)
    bc2 = DirichletBC(V.sub(1), u_D1, clamped_boundary)
    def force_on_rhs_boundary(x, on_boundary):
        return on_boundary and near(x[0], 60.0, tol)
    class topbot(SubDomain):
            return on_boundary and 0.0 + tol < x[0] < 60.0 - tol
    # force on rhs boundary
    # f1 = 1
    # u_D2 = Constant((f1, 0))
    # time dependent force: f(t) = 1-e^{-\kappa t}
    kappa = 0.5
    tt = np.linspace(0, 10, 100)
    S = 1.0
    SW = 0
    y = S-(S-0)*np.exp(-kappa*tt)
    fct = str(S) + '-(' + str(S) + '-' + str(SW) + ')*exp(-kappa*t)'
    u_D22 = Expression((fct, '0'), degree=1, kappa=kappa, t=0)
    u_D21 = Constant((0, 0))
    bc3 = DirichletBC(V.sub(0), u_D21, force_on_rhs_boundary)
    bc4 = DirichletBC(V.sub(1), u_D22, force_on_rhs_boundary)
    # Mark boundaries as "ds"
    boundaries = MeshFunction("size_t", mesh, dim=1)
    boundaries.set_all(0)
    # Mark boundaries where u*n=0 as "1"
    topbot = topbot()
    topbot.mark(boundaries, 1)
    # Boundary conditions
    bcs = [bc3, bc4]
    # Define strain and stress
    def epsilon(z):  # strain
        return 0.5*(nabla_grad(z) + nabla_grad(z).T)
        # return sym(nabla_grad(z))
    def sigma(z):  # stress
        return lambda_*nabla_div(z) * Identity(d) + 2 * mu * epsilon(z)
    # Define test functions
    vu = Function(V)
    v, u = split(vu)
    print(type(u))
    vnun = Function(V)
    v_n, u_n = split(vnun)
    (phi1, phi2) = TestFunctions(V)
    d = v.geometric_dimension()
    # Define source terms
    f_1 = Constant((0, 0))
    f_2 = Constant((0, 0))
    gamma = Constant(gamma_nitsche)
    h = CellDiameter(mesh)
    def ppos(x):
        return (x+abs(x))/2
    # Weak formulation
    F1 = (dot(v-v_n, phi2) * dx
         - dt * inner(sigma(u), epsilon(phi2)) * dx
         - dt * dot(v, phi1) * dx
         + dot(u-u_n, phi1) * dx)
    # Add Nitsche term:
    F1 -= dot(dot(n, dot(sigma(u), n)), dot(phi2, n)) * ds(1)
    # Add penalty term
    F = F1 + F2
    vuh = Function(V)
    dvu = Function(V)
    dv, du = split(dvu)
    for n in range(num_steps):
        # Update current time
        print('t: ', t)
        # Update bc
        u_D22.t = t
        #J = derivative(F, vuh, du)
        # Compute derivative of F for Newton method
        R = action(F1, vuh)
        DR = derivative(R, vuh, dvu)
        print(type(DR))
        def heavyside(u):
            return conditional(ufl.operators.And(ge(u[0], 0), ge(u[1], 0)), 1, 0)
        DR2 = heavyside(u) * dot(du, phi1) * dx
        #DR2 = action(DR2, vuh)
        # Sum over directional derivatives:
        DR = DR + DR2
        problem = NonlinearVariationalProblem(R, vuh, bcs, DR)
        solver.solve()
        # Split solutions
        vh, uh = vuh.split(True)
        U = VectorFunctionSpace(mesh, 'P', degree)
        print('Lösung u: Dolfin Plot')
        uh_plot = project(uh, U)
        dolfin_plot(uh_plot, style='paraview', lw=0)
        U = FunctionSpace(mesh, 'P', degree)
        u_magnitude = sqrt(dot(uh_plot, uh_plot))
        u_magnitude = project(u_magnitude, U)
        print('Displacement magnitude')
        print('Max/Min Displacement')
        print('min/max u:',
          u_magnitude.vector().min(),
          u_magnitude.vector().max())
        # Update previous solution
        v_n = vh
        u_n = uh
The derivative function is pretty robust, and still works with conditional and abs. Of course abs is not differentiable when its argument is zero, but that is still a problem if the derivative is implemented manually. Testing it quickly, it seems that UFL considers the derivative of abs at zero to be zero:
mesh = UnitIntervalMesh(1)
#u = Constant(-2) # prints -1.0
#u = Constant(2) # prints 1.0
u = Constant(0) # prints 0.0
print(assemble(diff(abs(u),u)*dx(domain=mesh)))
With conditional, it just returns the derivative of whichever branch is active.
