CompiledSubdomain using C++ class
My goal is to speed up the evaluation of the SubDomain Gamma
    mesh =     UnitSquareMesh(50,50, 'left/right')
    PHI = FunctionSpace(mesh, 'CG', 1)
    phi_expr = Expression('2.0*(1.0 - x[0])*x[0] + 0.2 - x[1]', degree=2)
    phi = interpolate(phi_expr , PHI)
    File("phi_initial.pvd") << phi
    class Gamma(SubDomain):
            return phi(x) > 0.5
with a C++ expression as follows
omega_out_code = """
#include <pybind11/eigen.h>
#include <math.h>
namespace py = pybind11;
#include <dolfin/function/Function.h>
#include <dolfin/mesh/SubDomain.h>
class OmegaOut : public dolfin::SubDomain
public:
  // Create expression with 3 components
  OmegaOut() : dolfin::SubDomain() {}
  // Function for evaluating expression on each cell
  bool inside(Eigen::Ref<const Eigen::VectorXd> x, bool on_boundary) const override
    Eigen::Array<double, 1, 1> values;
    phi.eval(values, x);
    return values[0] > 0.5;
  dolfin::Function phi;
PYBIND11_MODULE(SIGNATURE, m)
  py::class_<OmegaOut, std::shared_ptr<OmegaOut>, dolfin::SubDomain>
    (m, "OmegaOut")
    .def(py::init<>())
    .def_readwrite("phi", &OmegaOut::phi);
c = CompiledSubDomain(compile_cpp_code(omega_out_code).OmegaOut(), phi=phi, degree=0)
but I get the error:
  File "test_nitsche_stokes.py", line 140, in <module>
    main()
  File "test_nitsche_stokes.py", line 57, in main
  File "/usr/local/lib/python3.6/dist-packages/dolfin/mesh/subdomain.py", line 125, in __new__
    return compile_subdomain(inside_code, properties)
  File "/usr/local/lib/python3.6/dist-packages/dolfin/mesh/subdomain.py", line 118, in compile_subdomain
    subdomain = compile_class(cpp_data, mpi_comm=mpi_comm)
  File "/usr/local/lib/python3.6/dist-packages/dolfin/jit/jit.py", line 145, in compile_class
    raise RuntimeError("Expression must be a string, or a list or tuple of strings")
RuntimeError: Expression must be a string, or a list or tuple of strings
Is this not supported for SubDomain yet?
The following way of defining c seems to work:
c = compile_cpp_code(omega_out_code).OmegaOut()
c.phi = phi.cpp_object()
# (Change phi_expr definition to just "x[0]" for simpler testing.)
print(c.inside([0.75,0.5],False))
