If you want more control over the solver, you can also use solver = PETScSNESSolver()
and (solve with solver.solve(problem, u.vector())
, problem
being an inherited class of NonlinearProblem
, see the Cahn-Hilliard demo). PETSc SNES is documented here, see section 5.2 for options for the nonlinear solvers.
You can set any PETSc options with, for instance, PETScOption.set('snes_linesearch_monitor')
edit: to get the option accepted, you need then to do:
PETScOptions.set('snes_linesearch_monitor') # for example some monitoring
PETScOptions.set('snes_view') # print the solver config
snes = solver.snes().create()
snes.setFromOptions()
With solver.snes()
and solver.snes().ksp
you can access the underlying PETSc nonlinear and linear (ksp) solvers (petsc4py
objects) and manipulate them, extract convergence history and such.
