Hi @dokken ,thanks for your reply.Your guess is what I want to do.And here are the reproducible example:
import sys
from dolfinx import geometry
from dolfinx.fem import (Constant, Function, FunctionSpace,
assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc)
create_vector, create_matrix, set_bc)
from dolfinx.geometry import BoundingBoxTree, compute_collisions, compute_colliding_cells
from dolfinx.io import (XDMFFile, distribute_entity_data, gmshio)
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
class simulation:
def __init__(self, c_x, c_y, o_x, o_y, r, r2,
obstacle_type='cylinder',
save_mesh='false',
save='false',
visualize='false'):
self.L = 2.2
self.H = 0.41
self.c_x = c_x
self.c_y = c_y
self.r = r
self.gdim = 2
self.model_rank = 0
self.mesh_comm = MPI.COMM_WORLD
self.save = save
self.o_x = o_x
self.o_y = o_y
self.r2 = r2
self.obstacle_type = obstacle_type
self.save_mesh = save_mesh
self.visualize = visualize
def generate_mesh(self):
rectangle = gmsh.model.occ.addRectangle(0, 0, 0, self.L, self.H, tag=1)
obstacle1 = gmsh.model.occ.addDisk(self.c_x, self.c_y, 0, self.r, self.r)
pre_fluid = gmsh.model.occ.cut([(self.gdim, rectangle)], [(self.gdim, obstacle1)])
if self.r2 == 0:
fluid = pre_fluid
if self.obstacle_type == 'cylinder':
obstacle2 = gmsh.model.occ.addDisk(self.o_x, self.o_y, 0, self.r2, self.r2)
elif self.obstacle_type == 'rectangular':
obstacle2 = gmsh.model.occ.addRectangle(self.o_x, self.o_y, 0, self.r2, self.r2)
fluid = gmsh.model.occ.cut([(self.gdim, rectangle)], [(self.gdim, obstacle2)])
gmsh.model.occ.synchronize()
fluid_marker = 1
volumes = gmsh.model.getEntities(dim=self.gdim)
assert (len(volumes) == 1)
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], fluid_marker)
gmsh.model.setPhysicalName(volumes[0][0], fluid_marker, "Fluid")
self.inlet_marker, self.outlet_marker, self.wall_marker, self.obstacle_marker = 2, 3, 4, 5
inflow, outflow, walls, obstacle = [], [], [], []
for boundary in boundaries:
if np.allclose(center_of_mass, [0, self.H / 2, 0]):
inflow.append(boundary[1])
elif np.allclose(center_of_mass, [self.L, self.H / 2, 0]):
outflow.append(boundary[1])
elif np.allclose(center_of_mass, [self.L / 2, self.H, 0]) or np.allclose(center_of_mass, [self.L / 2, 0, 0]):
walls.append(boundary[1])
obstacle.append(boundary[1])
gmsh.model.addPhysicalGroup(1, walls, self.wall_marker)
gmsh.model.setPhysicalName(1, self.wall_marker, "Walls")
gmsh.model.addPhysicalGroup(1, inflow, self.inlet_marker)
gmsh.model.setPhysicalName(1, self.inlet_marker, "Inlet")
gmsh.model.addPhysicalGroup(1, outflow, self.outlet_marker)
gmsh.model.setPhysicalName(1, self.outlet_marker, "Outlet")
gmsh.model.addPhysicalGroup(1, obstacle, self.obstacle_marker)
gmsh.model.setPhysicalName(1, self.obstacle_marker, "Obstacle")
res_min = self.r / 3
distance_field = gmsh.model.mesh.field.add("Distance")
gmsh.model.mesh.field.setNumbers(distance_field, "EdgesList", obstacle)
threshold_field = gmsh.model.mesh.field.add("Threshold")
gmsh.model.mesh.field.setNumber(threshold_field, "IField", distance_field)
gmsh.model.mesh.field.setNumber(threshold_field, "LcMin", res_min)
gmsh.model.mesh.field.setNumber(threshold_field, "LcMax", 0.25 * self.H)
gmsh.model.mesh.field.setNumber(threshold_field, "DistMin", self.r)
gmsh.model.mesh.field.setNumber(threshold_field, "DistMax", 2 * self.H)
min_field = gmsh.model.mesh.field.add("Min")
gmsh.model.mesh.field.setNumbers(min_field, "FieldsList", [threshold_field])
gmsh.model.mesh.field.setAsBackgroundMesh(min_field)
gmsh.option.setNumber("Mesh.Algorithm", 8)
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
gmsh.option.setNumber("Mesh.RecombineAll", 1)
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
gmsh.model.mesh.generate(self.gdim)
gmsh.model.mesh.setOrder(2)
mesh, _, ft = gmshio.model_to_mesh(gmsh.model, self.mesh_comm, self.model_rank, gdim=self.gdim)
ft.name = "facet markers"
return mesh, ft
def compute(self, mesh, ft, jet):
jet_position = jet.get("position")
jet_x = jet.get("jet_x")
jet_y = jet.get("jet_y")
global u_probes_t, p_probes_t
bb_tree = geometry.BoundingBoxTree(mesh, mesh.topology.dim)
jet_cells = []
jet_points = []
jet_cell_candidates = geometry.compute_collisions(bb_tree, jet_position.T)
jet_colliding_cells = geometry.compute_colliding_cells(mesh, jet_cell_candidates, jet_position.T)
for i, jet_point in enumerate(jet_position.T):
if len(jet_colliding_cells.links(i)) > 0:
jet_points.append(jet_point)
jet_cells.append(jet_colliding_cells.links(i)[0])
t = 0
T = 7 # Final time
dt = 1 / 1600 # Time step size
num_steps = 100 # It is just for testing
mu = Constant(mesh, PETSc.ScalarType(0.001)) # Dynamic viscosity
rho = Constant(mesh, PETSc.ScalarType(1)) # Density
v_cg2 = VectorElement("CG", mesh.ufl_cell(), 2)
s_cg1 = FiniteElement("CG", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, v_cg2)
Q = FunctionSpace(mesh, s_cg1)
fdim = mesh.topology.dim - 1
# Define boundary conditions
class InletVelocity():
def __init__(self, t):
self.t = t
def __call__(self, x):
values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
values[0] = 4 * 1.5 * np.sin(self.t * np.pi / 8) * x[1] * (0.41 - x[1]) / (0.41 ** 2)
return values
class JetVelocity():
def __init__(self, t, jet_x, jet_y):
self.t_jet = t
self.jet_x = jet_x
self.jet_y = jet_y
values[0] = self.jet_x
values[1] = self.jet_y
return values
# Inlet
u_inlet = Function(V)
u_jet = Function(V)
inlet_velocity = InletVelocity(t)
jet_velocity = JetVelocity(t, jet_x, jet_y)
u_inlet.interpolate(inlet_velocity)
u_jet.interpolate(jet_velocity)
bcu_inflow = dirichletbc(u_inlet, locate_dofs_topological(V, fdim, ft.find(self.inlet_marker)))
bcu_jets = dirichletbc(u_jet, locate_dofs_topological(V, fdim, jet_cells))
# Walls
u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bcu_walls = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, ft.find(self.wall_marker)), V)
# Obstacle
bcu_obstacle = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, ft.find(self.obstacle_marker)), V)
bcu = [bcu_inflow, bcu_obstacle, bcu_walls, bcu_jets]
# Outlet
bcp_outlet = dirichletbc(PETSc.ScalarType(0), locate_dofs_topological(Q, fdim, ft.find(self.outlet_marker)), Q)
bcp = [bcp_outlet]
u_ = Function(V)
u_.name = "u"
u_s = Function(V)
u_n = Function(V)
u_n1 = Function(V)
p = TrialFunction(Q)
q = TestFunction(Q)
p_ = Function(Q)
p_.name = "p"
phi = Function(Q)
f = Constant(mesh, PETSc.ScalarType((0, 0)))
F1 = rho / k * dot(u - u_n, v) * dx
F1 += inner(dot(1.5 * u_n - 0.5 * u_n1, 0.5 * nabla_grad(u + u_n)), v) * dx
F1 += 0.5 * mu * inner(grad(u + u_n), grad(v)) * dx - dot(p_, div(v)) * dx
F1 += dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = create_matrix(a1)
b1 = create_vector(L1)
a2 = form(dot(grad(p), grad(q)) * dx)
L2 = form(-rho / k * dot(div(u_s), q) * dx)
A2.assemble()
b2 = create_vector(L2)
a3 = form(rho * dot(u, v) * dx)
L3 = form(rho * dot(u_s, v) * dx - k * dot(nabla_grad(phi), v) * dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setType(PETSc.PC.Type.JACOBI)
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.MINRES)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
xdmf = XDMFFile(mesh.comm, "flow_around_cylinder.xdmf", "w")
xdmf.write_mesh(mesh)
for i in range(num_steps):
# Update current time step
# Update inlet velocity
inlet_velocity.t = t
A1.zeroEntries()
assemble_matrix(A1, a1, bcs=bcu)
A1.assemble()
with b1.localForm() as loc:
loc.set(0)
assemble_vector(b1, L1)
set_bc(b1, bcu)
solver1.solve(b1, u_s.vector)
u_s.x.scatter_forward()
# Step 2: Pressure corrrection step
with b2.localForm() as loc:
loc.set(0)
assemble_vector(b2, L2)
set_bc(b2, bcp)
solver2.solve(b2, phi.vector)
phi.x.scatter_forward()
p_.vector.axpy(1, phi.vector)
p_.x.scatter_forward()
with b3.localForm() as loc:
loc.set(0)
assemble_vector(b3, L3)
solver3.solve(b3, u_.vector)
u_.x.scatter_forward()
xdmf.write_function(u_, t)
xdmf.write_function(p_, t)
xdmf.close()
gmsh.clear()
if __name__ == '__main__':
jet_positions = [(0.3, 0.15, 0), (0.3, 0.25, 0)]
def positions(jet_positions):
jet_coordinates = np.zeros((3, len(jet_positions)))
jet_x = [i[0] for i in jet_positions]
jet_y = [i[1] for i in jet_positions]
jet_coordinates[0] = jet_x
jet_coordinates[1] = jet_y
return jet_coordinates
jet_coordinates = positions(jet_positions)
jet = {
"jet_x": 1,
"jet_y": 1,
"position": jet_coordinates
simu = simulation(c_x=0.3, c_y=0.2, o_x=0.3, o_y=0.2, r=0.05, r2=0)
mesh, ft = simu.generate_mesh()
simu.compute(mesh=mesh, ft=ft, jet=jet)
