Hi all,
I’m trying to get the gradient of a UserExpression using the eval_cell method.
class CustomExpression(UserExpression):
def __init__(self, **kwargs):
super().__init__(kwargs)
def eval_cell(self, value, x, ufc_cell):
value[0] = 1
def value_shape(self):
return ()
mesh = UnitSquareMesh(16, 16)
my_expression = CustomExpression()
print(assemble(dot(grad(my_expression), n)*ds))
However I’m getting the following error:
fenics@4e87fe631d9d:~/shared$ python3 test.py
Cannot determine geometric dimension from expression.
File "test.py", line 21, in <module>
File "/usr/local/lib/python3.6/dist-packages/ufl/operators.py", line 381, in grad
return Grad(f)
File "/usr/local/lib/python3.6/dist-packages/ufl/differentiation.py", line 159, in __init__
self._dim = find_geometric_dimension(f)
File "/usr/local/lib/python3.6/dist-packages/ufl/domain.py", line 384, in find_geometric_dimension
error("Cannot determine geometric dimension from expression.")
File "/usr/local/lib/python3.6/dist-packages/ufl/log.py", line 172, in error
ufl.log.UFLException: Cannot determine geometric dimension from expression.
Thanks for the help!
Rémi
