Thank you for your reply! Attached is the simple channel flow problem from the (your) FEniCSx tutorial.
import pyvista
from dolfinx.fem import (
Constant,
Function,
functionspace,
assemble_scalar,
dirichletbc,
form,
locate_dofs_geometrical,
from dolfinx.fem.petsc import (
assemble_matrix,
assemble_vector,
apply_lifting,
create_vector,
set_bc,
from dolfinx.mesh import create_unit_square
from basix.ufl import element
from ufl import (
FacetNormal,
Identity,
TestFunction,
TrialFunction,
div,
dot,
ds,
dx,
inner,
lhs,
nabla_grad,
rhs,
sym,
from dolfinx import io
# After the mesh is created
with io.XDMFFile(
MPI.COMM_WORLD,
"/path/to/channel_flow_mesh.xdmf",
"w",
) as xdmf:
xdmf.write_mesh(mesh)
t = 0
T = 10
num_steps = 500
dt = T / num_steps
v_cg2 = element("Lagrange", mesh.topology.cell_name(), 2, shape=(mesh.geometry.dim,))
s_cg1 = element("Lagrange", mesh.topology.cell_name(), 1)
V = functionspace(mesh, v_cg2)
Q = functionspace(mesh, s_cg1)
p = TrialFunction(Q)
q = TestFunction(Q)
def walls(x):
return np.logical_or(np.isclose(x[1], 0), np.isclose(x[1], 1))
wall_dofs = locate_dofs_geometrical(V, walls)
u_noslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
bc_noslip = dirichletbc(u_noslip, wall_dofs, V)
def inflow(x):
return np.isclose(x[0], 0)
inflow_dofs = locate_dofs_geometrical(Q, inflow)
bc_inflow = dirichletbc(PETSc.ScalarType(8), inflow_dofs, Q)
def outflow(x):
return np.isclose(x[0], 1)
outflow_dofs = locate_dofs_geometrical(Q, outflow)
bc_outflow = dirichletbc(PETSc.ScalarType(0), outflow_dofs, Q)
bcu = [bc_noslip]
bcp = [bc_inflow, bc_outflow]
u_n = Function(V)
u_n.name = "u_n"
U = 0.5 * (u_n + u)
f = Constant(mesh, PETSc.ScalarType((0, 0)))
mu = Constant(mesh, PETSc.ScalarType(1))
rho = Constant(mesh, PETSc.ScalarType(1))
# Define strain-rate tensor
return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
return 2 * mu * epsilon(u) - p * Identity(len(u))
# Define the variational problem for the first step
p_n = Function(Q)
p_n.name = "p_n"
F1 = rho * dot((u - u_n) / k, v) * dx
F1 += rho * dot(dot(u_n, nabla_grad(u_n)), v) * dx
F1 += inner(sigma(U, p_n), epsilon(v)) * dx
F1 += dot(p_n * n, v) * ds - dot(mu * nabla_grad(U) * n, v) * ds
F1 -= dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = assemble_matrix(a1, bcs=bcu)
A1.assemble()
b1 = create_vector(L1)
u_ = Function(V)
a2 = form(dot(nabla_grad(p), nabla_grad(q)) * dx)
L2 = form(dot(nabla_grad(p_n), nabla_grad(q)) * dx - (rho / k) * div(u_) * q * dx)
A2.assemble()
b2 = create_vector(L2)
p_ = Function(Q)
a3 = form(rho * dot(u, v) * dx)
L3 = form(rho * dot(u_, v) * dx - k * dot(nabla_grad(p_ - p_n), v) * dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setHYPREType("boomeramg")
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.BCGS)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
from pathlib import Path
folder = Path("results")
folder.mkdir(exist_ok=True, parents=True)
vtx_u = VTXWriter(mesh.comm, folder / "poiseuille_u.bp", u_n, engine="BP4")
vtx_p = VTXWriter(mesh.comm, folder / "poiseuille_p.bp", p_n, engine="BP4")
vtx_u.write(t)
vtx_p.write(t)
def u_exact(x):
values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
values[0] = 4 * x[1] * (1.0 - x[1])
return values
u_ex = Function(V)
u_ex.interpolate(u_exact)
L2_error = form(dot(u_ - u_ex, u_ - u_ex) * dx)
for i in range(num_steps):
# Update current time step
# Step 1: Tentative veolcity step
with b1.localForm() as loc_1:
loc_1.set(0)
assemble_vector(b1, L1)
set_bc(b1, bcu)
solver1.solve(b1, u_.vector)
u_.x.scatter_forward()
# Step 2: Pressure corrrection step
with b2.localForm() as loc_2:
loc_2.set(0)
assemble_vector(b2, L2)
set_bc(b2, bcp)
solver2.solve(b2, p_.vector)
p_.x.scatter_forward()
with b3.localForm() as loc_3:
loc_3.set(0)
assemble_vector(b3, L3)
solver3.solve(b3, u_.vector)
u_n.x.array[:] = u_.x.array[:]
p_n.x.array[:] = p_.x.array[:]
# Write solutions to file
vtx_u.write(t)
vtx_p.write(t)
# Compute error at current time-step
error_L2 = np.sqrt(mesh.comm.allreduce(assemble_scalar(L2_error), op=MPI.SUM))
error_max = mesh.comm.allreduce(
np.max(u_.vector.array - u_ex.vector.array), op=MPI.MAX
# Print error only every 20th step and at the last step
if (i % 20 == 0) or (i == num_steps - 1):
print(f"Time {t:.2f}, L2-error {error_L2:.2e}, Max error {error_max:.2e}")
# Close xmdf file
vtx_u.close()
vtx_p.close()
b1.destroy()
b2.destroy()
b3.destroy()
solver1.destroy()
solver2.destroy()
solver3.destroy()
And the following is my workflow for attempting to compute the vorticity of the final timestep:
import os
import tqdm.autonotebook
from dolfinx.cpp.mesh import to_type, cell_entity_type
Constant,
Function,
functionspace,
assemble_scalar,
dirichletbc,
form,
locate_dofs_topological,
set_bc,
apply_lifting,
assemble_matrix,
assemble_vector,
create_vector,
create_matrix,
set_bc,
from dolfinx.graph import adjacencylist
from dolfinx.geometry import bb_tree, compute_collisions_points, compute_colliding_cells
from dolfinx.io import VTXWriter, distribute_entity_data, gmshio
from dolfinx.mesh import create_mesh, meshtags_from_entities
from ufl import (
FacetNormal,
Identity,
Measure,
TestFunction,
TrialFunction,
as_vector,
div,
dot,
ds,
dx,
inner,
lhs,
grad,
nabla_grad,
rhs,
sym,
system,
from scipy.interpolate import griddata
import adios2
import hydra
from omegaconf import DictConfig, OmegaConf
def read_adios2_data(file_path, variable_name):
with adios2.open(file_path, "r") as fh:
steps = []
for step in fh:
var = step.read(variable_name)
steps.append(var)
return np.array(steps)
def extract_snapshots(data, start_time, end_time, num_snapshots, dt):
start_idx = int(start_time / dt)
end_idx = int(end_time / dt)
total_steps = end_idx - start_idx + 1
# Calculate the stride to get num_snapshots
stride = max(1, total_steps // num_snapshots)
# Extract snapshots with the calculated stride
snapshots = data[start_idx : end_idx + 1 : stride]
# If we have more than num_snapshots, truncate
snapshots = snapshots[:num_snapshots]
snapshots_2d = snapshots[:, :, :2]
n_timesteps = snapshots_2d.shape[0]
u_component = snapshots_2d[:, :, 0].reshape(n_timesteps, -1).T
v_component = snapshots_2d[:, :, 1].reshape(n_timesteps, -1).T
return np.vstack((u_component, v_component))
# change working directory to script location
os.chdir(os.path.dirname(os.path.realpath(__file__)))
bp_file_path = Path("./results/poiseuille_u.bp")
output_base_path = Path("./results/")
variable = "u_n"
t = 0
T = 10
num_steps = 500
dt = T / num_steps
num_snapshots = 200
if not bp_file_path.exists():
print(f"No .bp file found at {bp_file_path}. Skipping...")
raise ValueError("No data found")
# Construct output path
output_folder = output_base_path
output_folder.mkdir(parents=True, exist_ok=True)
output_file = output_folder / f"{variable}.npy"
# Read the data
data = read_adios2_data(str(bp_file_path), variable)
snapshot_matrix = extract_snapshots(data, t, T, num_snapshots, dt)
# Load the mesh
with io.XDMFFile(
MPI.COMM_WORLD,
"path/to/channel_flow_mesh.xdmf",
"r",
) as xdmf:
mesh = xdmf.read_mesh(name="mesh")
dg1 = element("DG", mesh.topology.cell_name(), 1)
Q = functionspace(mesh, dg1)
# Create functions for velocity and vorticity
u = fem.Function(V)
omega = fem.Function(Q)
# Get the number of spatial points
dofs = V.tabulate_dof_coordinates()
num_spatial_points = len(dofs)
# Reshape to match the function space structure
u_values = np.zeros(len(dofs) * 2)
u_values[0::2] = snapshot_matrix[:num_spatial_points, -1] # x-component
u_values[1::2] = snapshot_matrix[num_spatial_points:, -1] # y-component
# Assign values to u
u.x.array[:] = u_values
ux, uy = u.split()
vortex = ux.dx(1) - uy.dx(0)
omega.interpolate(fem.Expression(vortex, Q.element.interpolation_points()))
# Extract vorticity values and corresponding coordinates
vorticity_values = omega.x.array
vorticity_coords = Q.tabulate_dof_coordinates()
fig, ax = plt.subplots(figsize=(12, 6))
plt.tricontourf(
vorticity_coords[:, 0],
vorticity_coords[:, 1],
vorticity_values,
cmap="RdBu_r",
levels=500,
plt.savefig(
"./results/vorticity.png",
dpi=300,
bbox_inches="tight",
The whole workflow is:
- Create mesh and save to xdmf.
- Solve the channel flow problem and write to .bp using VTK
- Load mesh and extract snapshots from .bp data
- Create function space
V of CG2 for u and assign extracted values to u
Q of DG1 for vorticity and interpolate the vorticity expression to compute vorticity.
The paraview computed vorticity
Thank you for your help!
