Computing derivative of residual vector w.r.t material parameter for finite element model updating
Hi all,
I am doing finite-element model updating for hyperelastic material models where I need analytic sensitivities of the residual w.r.t. constant material parameters:
\frac{\partial \mathbf{R}}{\partial m} \in \mathbb{R}^{N_u}
I do not use the adjoint method, so I need explicit parameter derivatives (implicit-function-theorem based optimization) and afterward solve a linear system with the Jacobian matrix to obtain the derivative of the displacement vector with repect to the material parameter:
\mathbf{J} \frac{\partial \mathbf{u}}{\partial m} = - \frac{\partial \mathbf{R}}{\partial m} , \quad \mathbf{K} = \frac{\partial \mathbf{R}}{\partial \mathbf{u}} \in \mathbb{R}^{N_u \times N_u}
Because my material model uses spline-based energies, I rely on dolfinx_external_operator. This introduces the constraint that material parameters (although constant) must be quadrature Functions, since external operators evaluate operands at quadrature points.
As a consequence, the only working pattern is:
Qe = basix.ufl.quadrature_element(
    domain.topology.cell_name(),
    degree=quadrature_degree,
    value_shape=()
Q = fem.functionspace(domain, Qe)
m = fem.Function(Q)  # Constant material parameter represented as a field
m.x.array[:] = 2.0
# Define external operator Psi and residual R in terms of m
dR_dm = ufl.derivative(R, m)
dR_dm_exp = ufl.algorithms.expand_derivatives(dR_dm)
R_repl, ops = replace_external_operators(dR_dm_exp)
A = assemble_matrix(fem.form(R_repl))  # <-- Matrix, not vector
Here, the assembly for dR/dm therefore gives a matrix. However, for a constant scalar parameter the mathematical object I actually want is a vector.
Questions
  1. Given the assembled matrix A above, what is the recommended way in FEniCSx to obtain the “physical” sensitivity vector dR/dm, for a constant material parameter represented as a quadrature Function?
  2. Is there any supported way (with FEMExternalOperator) to obtain dR/dm directly as a vector, without assembling the full Jacobian in parameter space? In my calibration problems I typically have 20–30 material parameters; storing 20–30 large matrices for all parameter sensitivities is quite expensive.
Minimal Code Example
The code below defines a variational problem for hyperelasticity with a simple linear energy density function expressed as external operator.
from dolfinx import *
import basix
import dolfinx.fem as femx
from dolfinx_external_operator import (
    FEMExternalOperator,
    replace_external_operators,
    evaluate_operands,
    evaluate_external_operators,
default_scalar_type = PETSc.ScalarType
def make_linear_iso_energy_external():
    External operator representing dPsi/dI1 for a very simple
    isochoric energy Psi(I1_bar; slope) = slope * I1_bar
    def psi_external(derivatives):
        # derivatives is (k_I1, k_slope)
        if derivatives == (0, 0):
            return lambda I1_vals, slope_vals: slope_vals.reshape(-1)
        elif derivatives == (1, 0):
            return lambda I1_vals, slope_vals: np.zeros_like(I1_vals).reshape(-1)
        elif derivatives == (0, 1):
            return lambda I1_vals, slope_vals: np.ones_like(slope_vals).reshape(-1)
            raise NotImplementedError(f"No implementation for derivatives={derivatives}")
    return psi_external
if __name__ == "__main__":
    comm = MPI.COMM_WORLD
    # Mesh and spaces
    domain = mesh.create_unit_cube(comm, 1, 1, 1)
    V = fem.functionspace(domain, ("CG", 1, (domain.geometry.dim,)))  # vector P1
    u = fem.Function(V)
    # Measure (quadrature of degree 3)
    quadrature_degree = 2
    dx = ufl.Measure(
        "dx",
        domain=domain,
        metadata={"quadrature_scheme": "default", "quadrature_degree": quadrature_degree},
    # Kinematics
    d = domain.geometry.dim
    I = ufl.Identity(d)
    F = ufl.variable(I + ufl.grad(u))
    C = F.T * F
    J = ufl.det(F)
    I1 = ufl.tr(C)
    # Quadrature space for external operator and material parameter (slope)
        value_shape=(),
    # Slope parameter
    slope = fem.Function(Q)
    slope.x.array[:] = 5.0  # constant in space, but stored in quadrature field
    # External operator for dPsi/dI1_bar depending on two parameters
    dPsi_dI1 = FEMExternalOperator(I1, slope, function_space=Q)
    dPsi_dI1.external_function = make_linear_iso_energy_external()
    # Simple Piola stress: isochoric part via external operator + volumetric penalty
    P_iso = ufl.diff(I1, F) * dPsi_dI1
    P_vol = ufl.diff(J, F) * (10.0 * (J - 1.0))  # volumetric energy: 5*(J - 1)^2
    P = P_iso + P_vol
    # Weak form
    R = ufl.inner(P, ufl.grad(v)) * dx
    # solve the forward problem (not shown here)
    # Residual w.r.t slope parameter
    dR_ds = ufl.derivative(R, slope)
    dR_ds_exp = ufl.algorithms.expand_derivatives(dR_ds) # Needed to expand derivatives of external operators
    dR_ds_replaced, dR_ds_ops = replace_external_operators(dR_ds_exp)
    dR_ds_form = femx.form(dR_ds_replaced)
    s_ops = evaluate_operands(dR_ds_ops)
    evaluate_external_operators(dR_ds_ops, s_ops)
    dR_dS_mat = femx.petsc.assemble_matrix(dR_ds_form)
    dR_dS_mat.assemble() # <-- Matrix
Dear @SolidMechanicsFan,
Is there any supported way (with FEMExternalOperator) to obtain dR/dm directly as a vector, without assembling the full Jacobian in parameter space? In my calibration problems, I typically have 20–30 material parameters; storing 20–30 large matrices for all parameter sensitivities is quite expensive.
When you define the form, use u directly, not the test function
R = ufl.inner(P, ufl.grad(u)) * dx
Just pay attention to when to update u before or after assembling R, which is a vector now.
Looks OK to me, but I don’t have much experience with optimisation problems. @dokken Do you have any suggestions regarding the 1st question?
@SolidMechanicsFan
The pull request:
should make it possible to use the real function space, which can be found at:
together with external operator, where this would be the function_space of the operator.
@dokken
Perfect, “real” function space seems the right choice here.
Can you comment on what function_space you are referring to?
Example (below): Let the strain energy density be the external operator and the invariant I1 be its main operand. I pass the material parameters associated with the energy as additional operands. The function space of this operator is related to the quadrature points of the dx measure integrating the weak form. It can not be a real function space, as the energy can be different at every quadrature point of the domain.
Is the code below what you had in mind? Or would you suggest a different implementation?
# Real parameter space for scalar material parameter
R = create_real_functionspace(domain)
kappa = fem.Function(R)
kappa.x.array[:] = 5.0
# Quadrature space for external operator output
        value_shape=(),
# External operator for energy derivative
myOp = FEMExternalOperator(I1, kappa, function_space=Q)
I was thinking about the space that goes into the external operator.
This of course, only makes sense if and only if all inputs to the operator is from the real space.
In general, if you have spatial dependencies in the external operator (or other polynomial dependencies, you should use the real space for the slop input, while since I1 is spatially varying, you should still use Q for the dPsiDI1 operator.
Thanks, and sorry for not coming back to this sooner.
Just to confirm: for operators depending on both spatial fields (e.g. (I_1)) and global scalar parameters, the recommended setup is:
  • scalar parameters in a Real function space,
  • spatial quantities as usual UFL operands,
  • and the external operator output still living in the quadrature space Q .
So in that mixed case, using function_space=Q for the operator remains the efficient approach? Or would you suggest using two operators?
I recently implemented mixed-element space in external operators, meaning they can now live beyond the quadrature space, particularly mixed spaces obtained from basix.ufl.mixed_element: Support by external operators of functional spaces beyond quadrature by a-latyshev · Pull Request #39 · a-latyshev/dolfinx-external-operator · GitHub. See a test example: dolfinx-external-operator/test/test_external_operators_evaluation.py at main · a-latyshev/dolfinx-external-operator · GitHub. This should work for both v0.10 and v0.11. I will publish new releases later on.
Furthermore, on top of v0.11, I adopted MixedFunctionSpace. You can find the tests here: dolfinx-external-operator/test/test_external_operators_evaluation.py at alatyshev/MixedFunctionSpace · a-latyshev/dolfinx-external-operator · GitHub.
If we compare both approaches, the second one with MixedFunctionSpace is more straightforward and requires fewer resources. In the case of MixedFunctionSpace, the replacement looks like this:
    F_blocks = [ufl.extract_blocks(F, i) for i in range(num_blocks)]
    J_blocks = derivative_block(F_blocks, u_sol, u_trial)
    for i in range(num_blocks):
        for j in range(num_blocks):
            J_rep, J_op = replace_external_operators(J_blocks[i][j])
            J_replaced_blocks[i][j] = J_rep
As for your scalar parameters, real functions are now in DOLFINx (v0.11): Release notes — DOLFINx Python 0.11.0.post0. I have a simple example where an operand of an external operator is an object from a real function space: dolfinx-external-operator/test/test_operands_evaluation.py at alatyshev/v0.11 · a-latyshev/dolfinx-external-operator · GitHub.
I hope this will help.
BTW, @dokken, do you think it’s an optimal way to compute the Jacobian automatically?
You could just replace the first line with
F_blocks = ufl.extract_blocks(F)
