equation
I am trying to solve the wave equation \partial_{tt} u - \Delta u = 0 in fenicsx in 2D (but keeping everything constant in the y-axis). I reformulate it into a first order system by introducing a second variable:
I use Crank-Nicolson to discretize the \partial_t and the weak form is:
where v,q are the basis functions corresponding to u,p and I have neglected boundary integrals and constants with \Delta t for readability. The matrices are defined here:
the choice b:=(1,0) makes E,F represent the partial derivative \partial_x. I use the following analytic solution
which determines the initial condition for u,p and the boundary condition for u (p does not need a boudnary condition, it is uniquely determined by u)
numerical tests
I would now expect an L^2 convergence rate of 2 from both first order FEM polynomials and from Crank-Nicolson, which is also what I get.
When I choose Lagrange Finite Elements of degree 2, and I pick a fixed, small \Delta t (i tried \approx 10^{-3}) and then refine only the mesh-size, I expect an L^2 convergence rate of 3. This does not work.
Any suggestions what could be the issue?
Here is my code:
In the section with # parameters, one can switch the polynomial degree pdeg and how small the time-step should be.
I just realized, that this code uses V for u and W for v.
from basix.ufl import element
from dolfinx.fem import (Constant, Function, dirichletbc,
form, functionspace, locate_dofs_topological)
from dolfinx.fem.petsc import assemble_matrix_block,assemble_vector_block
from dolfinx.mesh import *
from ufl import dx, ds, grad, inner, FacetNormal, dot
from dolfinx.fem import Function, FunctionSpace, assemble_scalar
# error
def error_L2(uh, u_ex, degree_raise=3):
degree = uh.function_space.ufl_element().degree()
family = uh.function_space.ufl_element().family()
mesh = uh.function_space.mesh
W = FunctionSpace(mesh, (family, degree + degree_raise)) # high-dim space
# interpolate
u_W = Function(W)
u_W.interpolate(uh)
u_ex_W = Function(W)
u_ex_W.interpolate(u_ex)
# Compute error
e_W = Function(W)
e_W.x.array[:] = u_W.x.array - u_ex_W.x.array
error = form(ufl.inner(e_W, e_W) * ufl.dx)
error_local = assemble_scalar(error)
error_global = mesh.comm.allreduce(error_local, op=MPI.SUM)
return np.sqrt(error_global)
# exact solution
class V_exact:
def __init__(self):
self.t = 0.0
def eval(self, x):
return np.sin(np.pi*x[0])*np.cos(np.pi*self.t)
# Nx = 40
errors = np.array([])
hlist = np.array([])
scalings = [1,2,4,8,16,32,64,128,256,512,1042,2048]
for i in range(len(scalings)-3):
# parameters
Nx = 1*scalings[i]*1
Ny = 1*scalings[i]*1
Nt = 1*scalings[i]*1
# Nt = 1024 # UNCOMMENT THIS
T_end = 2*np.pi+0.5
h = 1/Nx
dt = T_end/Nt
hlist = np.append(hlist,h)
t = 0
pdeg = 1 # CHANGE TO 2
# mesh, spaces, functions
msh = create_unit_square(MPI.COMM_WORLD, Nx, Nx)
n = FacetNormal(msh)
P1 = element("Lagrange", "triangle", pdeg)
XV = functionspace(msh, P1)
Xp = functionspace(msh, P1)
V = ufl.TrialFunction(XV)
p = ufl.TrialFunction(Xp)
W = ufl.TestFunction(XV)
q = ufl.TestFunction(Xp)
V_old = Function(XV)
V_new = Function(XV)
p_old = Function(Xp)
p_new = Function(Xp)
b = Constant(msh, (1.,0.))
# init cond
def initcond_V(x): return np.sin(np.pi * x[0])
def initcond_p(x): return 0+0.0*x[0]
V_old.interpolate(initcond_V)
p_old.interpolate(initcond_p)
V_new.interpolate(initcond_V)
p_new.interpolate(initcond_p)
# BC
facetsV = locate_entities_boundary(msh, dim=1,
marker=lambda x: np.logical_or.reduce((
np.isclose(x[0], 0.0),
np.isclose(x[0], 1.0))))
dofsV = locate_dofs_topological(XV, entity_dim=1, entities=facetsV)
BCs = [dirichletbc(0.0,dofsV, XV)]
# weak form
M = inner(V,W)*dx
E = inner(grad(p),b*W)*dx
F = inner(grad(V),b*q)*dx
N = inner(p,q)*dx
a = form([[M, -dt/2*E],
[-dt/2*F, N]])
A = assemble_matrix_block(a, bcs=BCs)
Vp_vec = A.createVecLeft()
# solver
solver = PETSc.KSP().create(msh.comm)
solver.setOperators(A)
for i in range(Nt):
# Update the right hand side
l = form([inner(V_old,W)*dx + dt/2*inner(grad(p_old),b*W)*dx - dt*inner(p_old*dot(b,n),W)*ds,
inner(p_old,q)*dx + dt/2*inner(grad(V_old),b*q)*dx - dt*inner(V_old*dot(b,n),q)*ds])
L = assemble_vector_block(l,a,bcs=BCs)
# solve
solver.solve(L, Vp_vec)
# extract solution
offset = XV.dofmap.index_map.size_local * XV.dofmap.index_map_bs
V_new.x.array[:offset] = Vp_vec.array_r[:offset]
p_new.x.array[:(len(Vp_vec.array_r) - offset)] = Vp_vec.array_r[offset:]
# Update solution at previous time step
V_old.x.array[:] = V_new.x.array
p_old.x.array[:] = p_new.x.array
# error in high-dim polynomial space
V_ex_expr = V_exact()
V_ex_expr.t = T_end
error = error_L2(V_new, V_ex_expr.eval, degree_raise=5)
errors = np.append(errors,error)
print(error)
# print errors and convergence rate
# print(errors)
rates = np.log(errors[1:] / errors[:-1]) / np.log(hlist[1:] / hlist[:-1])
print(rates)
