Dear Fenics community,
I’m facing an issue when trying to convert a numpy array into a dolfin vector, when the function space (a subspace in my case) is discontinuous. The example is as follows:
l = 4.0
DOF = 50
mesh = IntervalMesh(DOF, 0, l)
degree = 1
P1 = FiniteElement("Lagrange", interval, degree)
P0 = FiniteElement("Discontinuous Lagrange", interval, degree-1)
element = MixedElement([P1, P0])
U = FunctionSpace(mesh, element)
# Numpy array
w_array = np.random.rand(DOF+1)
# Function on DG subspace
w_f = Function(U.sub(1).collapse())
# Numpy to dof assign
w_f.vector()[:] = w_array[:]
However, I get the following Runtime error:
*** Error: Unable to set local values of PETSc vector.
*** Reason: Size of values array is not equal to local vector size.
*** Where: This error was encountered inside PETScVector.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: unknown
Am I missing something?. Any help is appreciated.
Thanks!.
