Hello everyone,
I am working on with fenics heat solver in order to model heat dissipation in a cylinder into a time independent function. In essence I am trying to remove the time variable of ‘dt’ in the function F. Any ideas how I would go about this ? I have my code below.
Thanks,
#!/usr/bin/env python
# coding: utf-8
# In[63]:
FEniCS tutorial demo program: Diffusion of a Gaussian hill.
u'= Laplace(u) + f in a square domain
u = u_D on the boundary
u = u_0 at t = 0
u_D = f = 0
The initial condition u_0 is chosen as a Gaussian hill.
import time
t = 2.0 # final time
num_steps = 50 # number of time steps
dt = t / num_steps # time step size
#Making a cylindrical geometry 10 cm radius and 15 cm height in S.I
cylinder = Cylinder(Point(0, 0, -7.5), Point(0, 0, 7.5), 5, 5)
domain = cylinder
# Making Mesh ( THe value corresponds to the mesh density)
mesh = generate_mesh(domain, 20) # generates 3D model of the cylindrical geometry in x, y, and z
axes.
# Define boundary condition
def boundary(x, on_boundary):
return on_boundary
# ( not sure what this really represents )
bc = DirichletBC(V, Constant(0), boundary)
# Define initial value ( not sure what this really represents )
u_0 = Expression('exp(-a*pow(x[0], 2) - a*pow(x[1], 2))',
degree=2, a=5)
u_n = interpolate(u_0, V)
f = Constant(0)
F = u*v*dx + dt*dot(grad(u), grad(v))*dx - (u_n + dt*f)*v*dx
a, L = lhs(F), rhs(F)
# Create VTK file for saving solution
vtkfile = File('heat_gaussian/solution.pvd')
# Time-stepping
t = 0
for n in range(num_steps):
# Update current time
# Compute solution
solve(a == L, u, bc)
# Save to file and plot solution
vtkfile << (u, t)
plot(u)
# Update previous solution
u_n.assign(u)
