Thank you for the message.
I need this for my bachelor thesis and am a bit pressed for time.
This formula is to be solved:
\begin{equation}
(\nabla \phi) . (\nabla \rho) - \frac{\rho ^2}{\epsilon_0} = 0
\end{equation}
(How can I insert latex code here?).
Here is the MWE:
#Mesh Erzeugung:(mit GMSH)
from dolfinx import mesh
import warnings
warnings.filterwarnings("ignore")
from dolfinx import fem
from dolfinx import nls
from dolfinx import log
from dolfinx import io
from dolfinx.cpp.mesh import to_type, cell_entity_type
from dolfinx.fem import Constant, Function, FunctionSpace, assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc
from dolfinx.fem.petsc import apply_lifting, assemble_matrix, assemble_vector, create_vector, set_bc
from dolfinx.graph import create_adjacencylist
from dolfinx.geometry import BoundingBoxTree, compute_collisions, compute_colliding_cells
from dolfinx.io import (XDMFFile, cell_perm_gmsh, distribute_entity_data, extract_gmsh_geometry,
extract_gmsh_topology_and_markers, ufl_mesh_from_gmsh)
from dolfinx.mesh import create_mesh, meshtags_from_entities
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
import tqdm.notebook
import scipy.constants as c
#Domain-Definieren:
L = 1.
H = 1.
c_x = 0.50
c_y = 0.50
r = 0.01
gdim = 2
rank = MPI.COMM_WORLD.rank
if rank == 0:
rectangle = gmsh.model.occ.addRectangle(0,0,0, L, H, tag=1)
obstacle = gmsh.model.occ.addDisk(c_x, c_y, 0, r, r)
if rank == 0:
Mesh_domain = gmsh.model.occ.cut([(gdim, rectangle)], [(gdim, obstacle)])
gmsh.model.occ.synchronize()
#Verbinden aller Mesh-Punkte
Mesh_domain_marker = 1
if rank == 0:
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], Mesh_domain_marker)
gmsh.model.setPhysicalName(volumes[0][0], Mesh_domain_marker, "Mesh_domain")
inlet_marker, outlet_marker, wall_marker, obstacle_marker, wall_top = 2, 3, 4, 5, 6
inflow, outflow, walls, obstacle, top = [], [], [], [], []
if rank == 0: #Walls sind Ground, Obstical ist Leiter
for boundary in boundaries:
if np.allclose(center_of_mass, [0, H/2, 0]):
inflow.append(boundary[1])
elif np.allclose(center_of_mass, [L, H/2, 0]):
outflow.append(boundary[1])
elif np.allclose(center_of_mass, [L/2, 0, 0]):
walls.append(boundary[1])
elif np.allclose(center_of_mass, [L/2, H, 0]):
top.append(boundary[1])
obstacle.append(boundary[1])
gmsh.model.setPhysicalName(1, inlet_marker, "Inlet")
gmsh.model.addPhysicalGroup(1, outflow, outlet_marker)
gmsh.model.setPhysicalName(1, outlet_marker, "Outlet")
gmsh.model.addPhysicalGroup(1, obstacle, obstacle_marker)
gmsh.model.setPhysicalName(1, obstacle_marker, "Obstacle")
gmsh.model.addPhysicalGroup(1, top, wall_top)
gmsh.model.setPhysicalName(1, wall_top, "top")
if rank == 0:
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 8)
gmsh.option.setNumber("Mesh.RecombineAll", 2)
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
if MPI.COMM_WORLD.rank == 0:
# Mesh Geometrie
x = extract_gmsh_geometry(gmsh.model)
# Topologie für jedes Element vom Mesh
topologies = extract_gmsh_topology_and_markers(gmsh.model)
num_cell_types = len(topologies.keys())
cell_information = {}
cell_dimensions = np.zeros(num_cell_types, dtype=np.int32)
for i, element in enumerate(topologies.keys()):
properties = gmsh.model.mesh.getElementProperties(element)
name, dim, order, num_nodes, local_coords, _ = properties
cell_information[i] = {"id": element, "dim": dim, "num_nodes": num_nodes}
cell_dimensions[i] = dim
# Sort elements by ascending dimension
perm_sort = np.argsort(cell_dimensions)
# Broadcast cell type data and geometric dimension
cell_id = cell_information[perm_sort[-1]]["id"]
tdim = cell_information[perm_sort[-1]]["dim"]
num_nodes = cell_information[perm_sort[-1]]["num_nodes"]
cell_id, num_nodes = MPI.COMM_WORLD.bcast([cell_id, num_nodes], root=0)
if tdim - 1 in cell_dimensions:
num_facet_nodes = MPI.COMM_WORLD.bcast( cell_information[perm_sort[-2]]["num_nodes"], root=0)
gmsh_facet_id = cell_information[perm_sort[-2]]["id"]
marked_facets = np.asarray(topologies[gmsh_facet_id]["topology"], dtype=np.int64)
facet_values = np.asarray(topologies[gmsh_facet_id]["cell_data"], dtype=np.int32)
cells = np.asarray(topologies[cell_id]["topology"], dtype=np.int64)
cell_values = np.asarray(topologies[cell_id]["cell_data"], dtype=np.int32)
cell_id, num_nodes = MPI.COMM_WORLD.bcast([None, None], root=0)
cells, x = np.empty([0, num_nodes], np.int64), np.empty([0, gdim])
cell_values = np.empty((0,), dtype=np.int32)
num_facet_nodes = MPI.COMM_WORLD.bcast(None, root=0)
marked_facets = np.empty((0, num_facet_nodes), dtype=np.int64)
facet_values = np.empty((0,), dtype=np.int32)
# Create distributed mesh
ufl_domain = ufl_mesh_from_gmsh(cell_id, gdim)
gmsh_cell_perm = cell_perm_gmsh(to_type(str(ufl_domain.ufl_cell())), num_nodes)
cells = cells[:, gmsh_cell_perm]
mesh = create_mesh(MPI.COMM_WORLD, cells, x[:, :gdim], ufl_domain)
tdim = mesh.topology.dim
fdim = tdim - 1
local_entities, local_values = distribute_entity_data(mesh, fdim, marked_facets, facet_values)
adj = create_adjacencylist(local_entities)
# Create DOLFINx MeshTags
ft = meshtags_from_entities(mesh, fdim, adj, np.int32(local_values))
ft.name = "Facet tags"
#Funktionspace und Vektorfunktionspace defenieren
s_cg1 = FiniteElement("CG", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, s_cg1)
V_E= fem.VectorFunctionSpace(mesh, ("DG", 0))
fdim = mesh.topology.dim - 1
#Konstanten, Funktionen und Randbedingungen definieren:
phi_0 = 80000 #V
rho0_0 = 1E-6 #C/m^3
T_0 = 20 #°C
p_0 = 1013 #hPa
h = c_y
#Kontroll-Variablen
LoopBreakPoint = 100
It = 0
CheckerRho = False
tol = 1e-1
num = 0
#Initialisierung der RB für rho
rho_aend = rho0_0
rho_0 = Constant(mesh, PETSc.ScalarType(rho0_0))
u1_0 = Constant(mesh, PETSc.ScalarType(phi_0))
E_0 = 33.7E+5 #V/m
K = 0.024 #sqrt(m)
delta = ((273.15 + 20)/(273.15 + T_0))*(p_0/1013)
E_c = E_0*delta*(1+(K/np.sqrt(delta*r))) # V/m
print("E_c: ", E_c)
#Boundary conditions definieren
# Walls
u1_nonslip = np.array((0,) *mesh.geometry.dim, dtype=PETSc.ScalarType)
u11_nonslip = np.array((0,) *mesh.geometry.dim, dtype=PETSc.ScalarType)
wall_facets = ft.indices[ft.values == wall_marker]
bcu1_walls = dirichletbc(PETSc.ScalarType(0), locate_dofs_topological(V, fdim, wall_facets), V)
# Obstacle
obstacle_facets = ft.indices[ft.values == obstacle_marker]
bcu1_obstacle = dirichletbc(PETSc.ScalarType(14e4), locate_dofs_topological(V, fdim, obstacle_facets), V)
#Boundary conditions for equations:
bcu1 = [bcu1_obstacle, bcu1_walls] # Spannung am Leiter und Ränder
#Laplace
u1 = ufl.TrialFunction(V)
v1 = ufl.TestFunction(V)
k = Constant(mesh, PETSc.ScalarType(0))
f = k/c.epsilon_0
epsilon = c.epsilon_0
a = ufl.inner(ufl.grad(u1),ufl.grad(v1)) * ufl.dx
L = ufl.inner(f , v1) * ufl.dx
u1 = fem.Function(V)
problem1 = fem.petsc.LinearProblem(a, L, bcu1, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
phi = problem1.solve()
#Bestimmung der Randbedingung für rho
while not CheckerRho:
print('solution for density is analysed')
It = It+1
print(It, "iteration of the PDE-system")
if It > LoopBreakPoint :
print('more then ', LoopBreakPoint, ' iterations')
break
phi_old = (phi.x.array.real)
E= - ufl.grad(phi)
E_expr = fem.Expression(E, V_E.element.interpolation_points)
EE = fem.Function(V_E)
EE.interpolate(E_expr)
rho = fem.Function(V)
v2 = ufl.TestFunction(V)
F = - ufl.inner((rho**2)/c.epsilon_0,v2)*dx + ufl.inner(ufl.dot(ufl.grad(phi),ufl.grad(rho)),v2)*dx # Kontinutätsgleichung
rho_BC = dirichletbc(PETSc.ScalarType(rho_aend), locate_dofs_topological(V, fdim, obstacle_facets), V)
problem2 = fem.petsc.NonlinearProblem(F, rho, bcs=[rho_BC])
#nonlinearproblem solver
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem2)
solver.max_it = 100
solver.atol = 1e-5
solver.rtol = 1e-12
n, converged = solver.solve(rho)
assert(converged)
print(f"Number of interations for Newton-solver: {n:d}")
#Poisson
aP = ufl.inner(grad(u1), grad(v1))*dx
LP = ufl.inner(-rho/c.epsilon_0,v1)*dx
problem3 = fem.petsc.LinearProblem(aP, LP, bcu1, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
phi = problem3.solve()
#new Checker for Rho
phi_current= (phi.x.array.real)
print('finished itteration ', It)
print ('Iterations for potential have ended. Finished in ', It ,' itterations')
if np.abs((phi_current - phi_old)).all() < tol:
print("1 max: ",(np.max(np.abs(EE.x.array))))
E= -ufl.grad(phi)
print("2 max: ",(np.max(np.abs(EE.x.array))))
print(np.abs((np.max(np.abs(EE.x.array))-E_c))/E_c, " < ", tol)
print("rho_aend: ", rho_aend)
if np.abs((np.max(np.abs(EE.x.array))-E_c)/E_c)< tol:
CheckerRho = True
print("!!! finish !!!")
CheckerRho = False
rho_aend += rho_aend*0.6*(((np.max(np.abs(EE.x.array))-E_c))/((np.max(np.abs(EE.x.array))+E_c)))
The problem, as I see it, is only in the while loop.
