Coupling PDEs of multiple dimensions
Hello everyone,
I have been trying to couple PDEs of multiple dimensions(3D acoustic domain and 2D elastic plate domain), and fortunately, I have found a useful demo for doing this.
The problem here is that I got the same error as I was trying to fix with my code, which seems to be that the dimension of the integration measure does not match with the dimension of the integrands.
Now, I want to run this demo without errors since it’s such a good reference.
I believe the demo usually runs without errors, so this error could be due to that I am using FEniCSx 0.8.0 for a compatibility reason-- in that case, I would greatly appreciate if someone could give me a hint to modify the code so that this demo runs on 0.8.0.
Below is the block of the code in the above demo, followed by the error produced.
Thank you so much for your time and I am looking forward to hearing your advice.
v, w = ufl.TestFunctions(W)
u = dolfinx.fem.Function(V, name="Displacement")
psi = dolfinx.fem.Function(Q, name="Latent_variable")
psi_k = dolfinx.fem.Function(Q, name="Previous_Latent_variable")
mu = E / (2.0 * (1.0 + nu))
lmbda = E * nu / ((1.0 + nu) * (1.0 - 2.0 * nu))
def epsilon(w):
    return ufl.sym(ufl.grad(w))
def sigma(w, mu, lmbda):
    ew = epsilon(w)
    gdim = ew.ufl_shape[0]
    return 2.0 * mu * epsilon(w) + lmbda * ufl.tr(ufl.grad(w)) * ufl.Identity(gdim)
F = alpha * ufl.inner(sigma(u, mu, lmbda), epsilon(v)) * dx
F -= alpha * ufl.inner(f, v) * dx
F += -ufl.inner(psi - psi_k, ufl.dot(v, n)) * ds
F += ufl.inner(ufl.dot(u, n_g), w) * ds
F += ufl.inner(ufl.exp(psi), w) * ds - ufl.inner(g, w) * ds
residual = dolfinx.fem.form(ufl.extract_blocks(F), entity_maps=entity_maps)
Cell In[11], line 23
     21 F += ufl.inner(ufl.dot(u, n_g), w) * ds
     22 F += ufl.inner(ufl.exp(psi), w) * ds - ufl.inner(g, w) * ds
---> 23 residual = dolfinx.fem.form(ufl.extract_blocks(F), entity_maps=entity_maps)
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/dolfinx/fem/forms.py:249, in form(form, dtype, form_compiler_options, jit_options, entity_maps)
    246         return list(map(lambda sub_form: _create_form(sub_form), form))
    247     return form
--> 249 return _create_form(form)
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/dolfinx/fem/forms.py:246, in form.<locals>._create_form(form)
    244     return _form(form)
    245 elif isinstance(form, collections.abc.Iterable):
--> 246     return list(map(lambda sub_form: _create_form(sub_form), form))
    247 return form
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/dolfinx/fem/forms.py:246, in form.<locals>._create_form.<locals>.<lambda>(sub_form)
    247 return form
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/dolfinx/fem/forms.py:244, in form.<locals>._create_form(form)
    241 """Recursively convert ufl.Forms to dolfinx.fem.Form, otherwise
    242 return form argument"""
    243 if isinstance(form, ufl.Form):
--> 244     return _form(form)
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/dolfinx/fem/forms.py:186, in form.<locals>._form(form)
    184 if mesh is None:
    185     raise RuntimeError("Expecting to find a Mesh in the form.")
--> 186 ufcx_form, module, code = jit.ffcx_jit(
    187     mesh.comm, form, form_compiler_options=form_compiler_options, jit_options=jit_options
    188 )
    190 # For each argument in form extract its function space
    191 V = [arg.ufl_function_space()._cpp_object for arg in form.arguments()]
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/dolfinx/jit.py:51, in mpi_jit_decorator.<locals>.mpi_jit(comm, *args, **kwargs)
     47 @functools.wraps(local_jit)
     48 def mpi_jit(comm, *args, **kwargs):
     49     # Just call JIT compiler when running in serial
     50     if comm.size == 1:
---> 51         return local_jit(*args, **kwargs)
     53     # Default status (0 == ok, 1 == fail)
     54     status = 0
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/dolfinx/jit.py:201, in ffcx_jit(ufl_object, form_compiler_options, jit_options)
    199 # Switch on type and compile, returning cffi object
    200 if isinstance(ufl_object, ufl.Form):
--> 201     r = ffcx.codegeneration.jit.compile_forms([ufl_object], options=p_ffcx, **p_jit)
    202 elif isinstance(ufl_object, ufl.AbstractFiniteElement):
    203     r = ffcx.codegeneration.jit.compile_elements([ufl_object], options=p_ffcx, **p_jit)
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/ffcx/codegeneration/jit.py:276, in compile_forms(forms, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    274     except Exception:
    275         pass
--> 276     raise e
    278 obj, module = _load_objects(cache_dir, module_name, form_names)
    279 return obj, module, (decl, impl)
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/ffcx/codegeneration/jit.py:256, in compile_forms(forms, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    253     for name in form_names:
    254         decl += form_template.format(name=name)
--> 256     impl = _compile_objects(
    257         decl,
    258         forms,
    259         form_names,
    260         module_name,
    261         p,
    262         cache_dir,
    263         cffi_extra_compile_args,
    264         cffi_verbose,
    265         cffi_debug,
    266         cffi_libraries,
    267         visualise=visualise,
    268     )
    269 except Exception as e:
    270     try:
    271         # remove c file so that it will not timeout next time
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/ffcx/codegeneration/jit.py:383, in _compile_objects(decl, ufl_objects, object_names, module_name, options, cache_dir, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    379 libraries = _libraries + cffi_libraries if cffi_libraries is not None else _libraries
    381 # JIT uses module_name as prefix, which is needed to make names of all struct/function
    382 # unique across modules
--> 383 _, code_body = ffcx.compiler.compile_ufl_objects(
    384     ufl_objects, prefix=module_name, options=options, visualise=visualise
    385 )
    387 ffibuilder = cffi.FFI()
    389 ffibuilder.set_source(
    390     module_name,
    391     code_body,
    394     libraries=libraries,
    395 )
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/ffcx/compiler.py:113, in compile_ufl_objects(ufl_objects, options, object_names, prefix, visualise)
    111 # Stage 2: intermediate representation
    112 cpu_time = time()
--> 113 ir = compute_ir(analysis, _object_names, _prefix, options, visualise)
    114 _print_timing(2, time() - cpu_time)
    116 # Stage 3: code generation
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/ffcx/ir/representation.py:225, in compute_ir(analysis, object_names, prefix, options, visualise)
    214 ir_elements = [
    215     _compute_element_ir(e, analysis.element_numbers, finite_element_names)
    216     for e in analysis.unique_elements
    217 ]
    219 ir_dofmaps = [
    220     _compute_dofmap_ir(e, analysis.element_numbers, dofmap_names)
    221     for e in analysis.unique_elements
    222 ]
    224 irs = [
--> 225     _compute_integral_ir(
    226         fd,
    227         i,
    228         analysis.element_numbers,
    229         integral_names,
    230         finite_element_names,
    231         options,
    232         visualise,
    233     )
    234     for (i, fd) in enumerate(analysis.form_data)
    235 ]
    236 ir_integrals = list(itertools.chain(*irs))
    238 ir_forms = [
    239     _compute_form_ir(
    240         fd,
    250     for (i, fd) in enumerate(analysis.form_data)
    251 ]
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/ffcx/ir/representation.py:588, in _compute_integral_ir(form_data, form_index, element_numbers, integral_names, finite_element_names, options, visualise)
    583 integrand_map: dict[QuadratureRule, ufl.core.expr.Expr] = {
    584     rule: integral.integrand() for rule, integral in sorted_integrals.items()
    585 }
    587 # Build more specific intermediate representation
--> 588 integral_ir = compute_integral_ir(
    589     itg_data.domain.ufl_cell(),
    590     itg_data.integral_type,
    591     ir["entitytype"],
    592     integrand_map,
    593     ir["tensor_shape"],
    594     options,
    595     visualise,
    596 )
    598 ir.update(integral_ir)
    600 # Fetch name
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/ffcx/ir/integral.py:85, in compute_integral_ir(cell, integral_type, entitytype, integrands, argument_shape, p, visualise)
     73 # Build terminal_data from V here before factorization. Then we
     74 # can use it to derive table properties for all modified
     75 # terminals, and then use that to rebuild the scalar graph more
     76 # efficiently before argument factorization. We can build
     77 # terminal_data again after factorization if that's necessary.
     79 initial_terminals = {
     80     i: analyse_modified_terminal(v["expression"])
     81     for i, v in S.nodes.items()
     82     if is_modified_terminal(v["expression"])
     83 }
---> 85 mt_table_reference = build_optimized_tables(
     86     quadrature_rule,
     87     cell,
     88     integral_type,
     89     entitytype,
     90     initial_terminals.values(),
     91     ir["unique_tables"],
     92     use_sum_factorization=p["sum_factorization"],
     93     rtol=p["table_rtol"],
     94     atol=p["table_atol"],
     95 )
     97 # Fetch unique tables for this quadrature rule
     98 table_types = {v.name: v.ttype for v in mt_table_reference.values()}
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/ffcx/ir/elementtables.py:415, in build_optimized_tables(quadrature_rule, cell, integral_type, entitytype, modified_terminals, existing_tables, use_sum_factorization, rtol, atol)
    413             t["array"] = np.vstack([td["array"] for td in new_table])
    414 else:
--> 415     t = get_ffcx_table_values(
    416         quadrature_rule.points,
    417         cell,
    418         integral_type,
    419         element,
    420         avg,
    421         entitytype,
    422         local_derivatives,
    423         flat_component,
    424     )
    425 # Clean up table
    426 tbl = clamp_table_small_numbers(t["array"], rtol=rtol, atol=atol)
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/ffcx/ir/elementtables.py:139, in get_ffcx_table_values(points, cell, integral_type, element, avg, entitytype, derivative_counts, flat_component)
    137 for entity in range(num_entities):
    138     entity_points = map_integral_points(points, integral_type, cell, entity)
--> 139     tbl = component_element.tabulate(deriv_order, entity_points)
    140     tbl = tbl[basix_index(derivative_counts)]
    141     component_tables.append(tbl)
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/basix/ufl.py:660, in _ComponentElement.tabulate(self, nderivs, points)
    650 def tabulate(self, nderivs: int, points: _npt.NDArray[np.float64]) -> _npt.NDArray[np.float64]:
    651     """Tabulate the basis functions of the element.
    652
    653     Args:
    658         Tabulated basis functions.
    659     """
--> 660     tables = self._element.tabulate(nderivs, points)
    661     output = []
    662     for tbl in tables:
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/basix/ufl.py:415, in _BasixElement.tabulate(self, nderivs, points)
    404 def tabulate(self, nderivs: int, points: _npt.NDArray[np.float64]) -> _npt.NDArray[np.float64]:
    405     """Tabulate the basis functions of the element.
    406
    407     Args:
    413
    414     """
--> 415     tab = self._element.tabulate(nderivs, points)
    416     # TODO: update FFCx to remove the need for transposing here
    417     return tab.transpose((0, 1, 3, 2)).reshape((tab.shape[0], tab.shape[1], -1))
File /opt/homebrew/Caskroom/miniconda/base/envs/try10/lib/python3.12/site-packages/basix/finite_element.py:137, in FiniteElement.tabulate(self, n, x)
    105 def tabulate(self, n: int, x: npt.NDArray) -> npt.NDArray[np.floating]:
    106     """Compute basis values and derivatives at set of points.
    107
    108     Note:
    135             basis functions.
    136     """
--> 137     return self._e.tabulate(n, x)
RuntimeError: Point dim (2) does not match element dim (1).
The code, in its current form, cannot work with v0.8.0. Especially the usage of ufl.extract_blocks, which underwent a rewrite from 0.8.0 to 0.9.0.
Alot of work was put into mixed dimensional from 0.8.0 to 0.9.0. See: FEniCS release notes | FEniCS Project
Could you elaborate on why you haven’t upgraded to 0.9.0?
There are not that many API changes, ref:
Hi Jørgen,
Thank you so much for your prompt and clear advice. (and thank you for keep developing FEniCSx!!)
Now I can clearly see that I would need the newer version of FEniCSx for this.
The reason I installed 0.8.0 was because of this issue.
That was a few months ago, and maybe there has been updates to address the issue since then. (Do you know if it was resolved in newer version?)
Regarding my current issue, I would like to try the latest FEniCSx so that I can solve the coupled PDEs of multiple dimensions.
Hello!
I’ve finally got round to looking at that Bempp bug and have a PR open to fix it: Make normals of FEniCSx trace mesh point outward by mscroggs · Pull Request #226 · bempp/bempp-cl · GitHub. I’ll get that merged and make a new release of Bempp as soon as possible.
(Note: I also merged a PR renaming bempp to bempp_cl so you’ll need to do a find and replace)
