Create Mesh through combination of two xdmf files
Hello everyone,
I have created two parts, saved them as a xdmf file and would now like to create a single mesh out of them, so that I can define my FunctionSpaces on the total domain.
I know how to do it for a mesh stored in a single xdmf.file:
with io.XDMFFile(MPI.COMM_WORLD, “Meshfile.xdmf”, “r”) as xdmf:
domain = xdmf.read_mesh(name=“Grid”)
cell_tag = xdmf.read_meshtags(domain, name=“Grid”)
But I do not know, how to combine two dolfinx.mesh.Mesh types together.
I tried combining the meshes using meshio, but there the difficulty lies in keeping the definition of the subdomains.
Thank you in advance for any assistance you can provide. I’m open to any suggestions or solutions that might help resolve this issue. Your help is greatly appreciated!
Martin
Hi Martin,
What do you mean by
when combining the meshes using meshio. Couldn’t you use a cell_data field that would be, say 1 on the cells of your first mesh and 2 on the cells of the second, so that you could then extract meshtags in FEniCS ?
Here is an example of merging two meshes which has both facet and cell markers.
In the following example I use gmsh to make two separate xdmf files with marker information in them. Next I read them into dolfinx and combine the meshes there.
import dolfinx.io.gmshio
# Generate two separate meshes with gmsh
gmsh.model.add("Mesh1")
gmsh.model.setCurrent("Mesh1")
box_1 = gmsh.model.occ.addBox(0, 0, 0, 1, 1, 1)
gmsh.model.occ.synchronize()
volumes = gmsh.model.getEntities(dim=3)
assert len(volumes) == 1
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], 1)
c = 3
for boundary in boundaries:
    gmsh.model.addPhysicalGroup(boundary[0], [boundary[1]], c)
    c += 1
gmsh.model.mesh.generate(3)
mesh1, ct1, ft1 = dolfinx.io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0)
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "mesh1.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh1)
    xdmf.write_meshtags(ct1, mesh1.geometry)
    xdmf.write_meshtags(ft1, mesh1.geometry)
gmsh.model.add("Mesh2")
gmsh.model.setCurrent("Mesh2")
box_2 = gmsh.model.occ.addBox(2, 2, 2, 3, 3, 3)
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], 2)
    c += 1
mesh2, ct2, ft2 = dolfinx.io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0)
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "mesh2.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh2)
    xdmf.write_meshtags(ct2, mesh2.geometry)
    xdmf.write_meshtags(ft2, mesh2.geometry)
gmsh.finalize()
# Read meshes data into dolfinx
with dolfinx.io.XDMFFile(MPI.COMM_SELF, "mesh1.xdmf", "r") as xdmf:
    mesh_1 = xdmf.read_mesh()
    mesh_1.topology.create_connectivity(mesh_1.topology.dim - 1, mesh_1.topology.dim)
    ct_1 = xdmf.read_meshtags(mesh_1, name="Cell tags")
    ft_1 = xdmf.read_meshtags(mesh_1, name="Facet tags")
with dolfinx.io.XDMFFile(MPI.COMM_SELF, "mesh2.xdmf", "r") as xdmf:
    mesh_2 = xdmf.read_mesh()
    ct_2 = xdmf.read_meshtags(mesh_2, name="Cell tags")
    mesh_2.topology.create_connectivity(mesh_2.topology.dim - 1, mesh_2.topology.dim)
    ft_2 = xdmf.read_meshtags(mesh_2, name="Facet tags")
def extract_local_information(mesh, ct, ft):
    tdim = mesh.topology.dim
    num_cells = mesh.topology.index_map(tdim).size_local
    mesh.topology.create_connectivity(tdim, tdim)
    x_indices = dolfinx.mesh.entities_to_geometry(
        mesh, tdim, np.arange(num_cells, dtype=np.int32), False
    num_nodes = mesh.geometry.index_map().size_local
    x = mesh.geometry.x[:num_nodes]
    ct_indices = dolfinx.mesh.entities_to_geometry(mesh, ct.dim, ct.indices, False)
    ct_values = ct.values
    mesh.topology.create_connectivity(ft.dim, tdim)
    ft_indices = dolfinx.mesh.entities_to_geometry(mesh, ft.dim, ft.indices, False)
    ft_values = ft.values
    return (
        x_indices,
        x,
        mesh.ufl_domain().ufl_coordinate_element(),
        ct_indices,
        ct_values,
        ft_indices,
        ft_values,
# Extract information from each mesh
data_1 = extract_local_information(mesh_1, ct_1, ft_1)
data_2 = extract_local_information(mesh_2, ct_2, ft_2)
# Combine data
cells = np.vstack([data_1[0], data_2[0] + data_1[1].shape[0]])
points = np.vstack([data_1[1], data_2[1]])
ct_indices = np.vstack([data_1[3], data_2[3] + data_1[1].shape[0]])
ct_values = np.hstack([data_1[4], data_2[4]])
ft_indices = np.vstack([data_1[5], data_2[5] + data_1[1].shape[0]])
ft_values = np.hstack([data_1[6], data_2[6]])
assert data_1[2] == data_2[2]
# Create combined mesh and tags
mesh = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, cells, points, data_1[2])
c, c_values = dolfinx.io.distribute_entity_data(
    mesh, mesh.topology.dim, ct_indices, ct_values
f, f_values = dolfinx.io.distribute_entity_data(
    mesh, mesh.topology.dim - 1, ft_indices, ft_values
ct = dolfinx.mesh.meshtags_from_entities(
    mesh,
    mesh.topology.dim,
    dolfinx.graph.adjacencylist(c.astype(np.int32)),
    c_values.astype(np.int32),
ft = dolfinx.mesh.meshtags_from_entities(
    mesh,
    dolfinx.graph.adjacencylist(f.astype(np.int32)),
    f_values.astype(np.int32),
ct.name = "Cell tags"
ft.name = "Facet tags"
# Write to file
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "combined_mesh.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_meshtags(ct, mesh.geometry)
    xdmf.write_meshtags(ft, mesh.geometry)
Dear Dokken,
Thank you very much for your fast reply, I will try this!
