Create structured alternate volume mesh in gmsh
Hi all, I’ve been trying to create a box mesh in gmsh with a structured and refined layer in the middle, here is the .geo code for it:
lc = 100.;
Mesh.CharacteristicLengthFromPoints = 1.;
Mesh.CharacteristicLengthExtendFromBoundary = 1.;
Mesh.CharacteristicLengthFromCurvature = 1.;
Mesh.CharacteristicLengthMin = 10.;
Mesh.CharacteristicLengthMax = lc;
Lbox = 100;
Hbox = 100;
Wbox = 100;
Wref = 12;
Point(1) = {0, 0, (Wbox - Wref)/2, 1.0};
Point(2) = {Lbox, 0, (Wbox - Wref)/2, 1.0};
Point(3) = {Lbox, Hbox, (Wbox - Wref)/2, 1.0};
Point(4) = {0, Hbox, (Wbox - Wref)/2, 1.0};
Line(1) = {2, 1};
Line(2) = {1, 4};
Line(3) = {4, 3};
Line(4) = {3, 2};
Curve Loop(1) = {4, 1, 2, 3};
Plane Surface(1) = {1};
size_el = 1.5;
n_el_big = Lbox/size_el + 1.;
n_el_small = Wref/size_el + 1.;
Extrude {0, 0, Wref} {
  Surface{1}; //Layers{n_el_small};
Transfinite Curve {2, 3, 4, 1, 8, 9, 6, 7} = n_el_big Using Progression 1;
Transfinite Curve {20, 11, 12, 16} = n_el_small Using Progression 1;
Transfinite Surface {1} Alternate;
Transfinite Surface {21} Alternate;
Transfinite Surface {26} Alternate;
Transfinite Surface {13} Alternate;
Transfinite Surface {25} Alternate;
Transfinite Surface {17} Alternate;
/*//Recombine Surface {1, 21, 26, 13, 25, 17}; Used to have hexahedron elements*/
Transfinite Volume{1} = {14, 10, 6, 5, 4, 1, 2, 3};
Point(15) = {0, 0, 0, 1.0};
Point(16) = {Lbox, 0, 0, 1.0};
Point(17) = {Lbox, Hbox, 0, 1.0};
Point(18) = {0, Hbox, 0, 1.0};
Point(19) = {0, 0, Wbox, 1.0};
Point(20) = {Lbox, 0, Wbox, 1.0};
Point(21) = {Lbox, Hbox, Wbox, 1.0};
Point(22) = {0, Hbox, Wbox, 1.0};
Line(21) = {14, 22};
Line(22) = {22, 21};
Line(23) = {21, 5};
Line(24) = {22, 19};
Line(25) = {19, 10};
Line(26) = {19, 20};
Line(27) = {20, 6};
Line(28) = {20, 21};
Line(29) = {2, 16};
Line(30) = {16, 17};
Line(31) = {17, 3};
Line(32) = {17, 18};
Line(33) = {18, 4};
Line(34) = {18, 15};
Line(35) = {15, 1};
Line(36) = {15, 16};
Curve Loop(2) = {31, -3, -33, -32};
Plane Surface(27) = {2};
Curve Loop(3) = {33, -2, -35, -34};
Plane Surface(28) = {3};
Curve Loop(4) = {35, -1, 29, -36};
Plane Surface(29) = {4};
Curve Loop(5) = {30, 31, 4, 29};
Plane Surface(30) = {5};
Curve Loop(6) = {32, 34, 36, 30};
Plane Surface(31) = {6};
Curve Loop(7) = {23, 6, -27, 28};
Plane Surface(32) = {7};
Curve Loop(8) = {23, -9, 21, 22};
Plane Surface(33) = {8};
Curve Loop(9) = {27, 7, -25, 26};
Plane Surface(34) = {9};
Curve Loop(10) = {25, 8, 21, 24};
Plane Surface(35) = {10};
Curve Loop(11) = {26, 28, -22, 24};
Plane Surface(36) = {11};
Surface Loop(1) = {35, 34, 32, 33, 36, 26};
Volume(2) = {1};
Surface Loop(2) = {28, 27, 30, 31, 29, 1};
Volume(3) = {2};
Transfinite Curve {33, 35, 25, 31, 27, 23} = 6 Using Progression 0.6;
Transfinite Curve {29, 21} = 6 Using Progression 1.4;
The problem I’m having is that I wanted the 3D mesh in the refined layer to be alternated. As you can see in the figure below, the 2D mesh is alternated the way I want it to be:
However, when I mesh it in 3D, the elements get converted to diagonal elements, as you can see in the figure below
Would there be a way to obtain 3D structured alternate elements in the middle layer?
Thanks in advance for your help!
This is a Gmsh question, and I guess the best people to ask are the Gmsh developers:
https://gmsh.info/#Documentation
or
Apparently, they don’t have a well-structured forum like the FEniCS discourse (at least I didn’t find it). That’s why I posed the question here since I saw other inquiries related to gmsh in this forum.
