I simulating fluid structure interaction problems, and as part of this I need an expression which is 1 in the solid and zero in the fluid. As part of my mesh creation I already make a mesh function that satisfies this, and I find it useful to be able to simply create an expression from this mesh function, rather than having to try again. I have found a way of doing this by adapting the tensor-weighted-poisson demo, which I show below in a minimal working example,
# create mesh (marking the solid part in the process)
L, H = 2.5, 0.41
l, h = 0.35, 0.02
C, r, SEGMENTS = (0.2,0.2), 0.05, 10
RESOLUTION = 30
domain = Rectangle(Point(0.0,0.0),Point(L,H)) - \
Circle(Point(C[0],C[1]),r,SEGMENTS)
domain.set_subdomain(1,Rectangle(Point(C[0],C[1]-h/2),Point(C[0]+r+l,C[1]+h/2)))
mesh = generate_mesh(domain, RESOLUTION)
# create mesh function using domains already defined
mf = MeshFunction("size_t", mesh, mesh.geometric_dimension(), mesh.domains())
# c++ code to create an expression using a mesh function
cpp_code = """
#include <pybind11/eigen.h>
namespace py = pybind11;
#include <dolfin/function/Expression.h>
#include <dolfin/mesh/MeshFunction.h>
class MeshFunExpression : public dolfin::Expression
public:
// Create scalar expression
MeshFunExpression() : dolfin::Expression() {}
// Function for evaluating expression on each cell
void eval(Eigen::Ref<Eigen::VectorXd> values,
Eigen::Ref<const Eigen::VectorXd> x, const ufc::cell& cell)
const override
const uint cell_index = cell.index;
values[0] = (*mf)[cell_index];
// The data stored in mesh functions
std::shared_ptr<dolfin::MeshFunction<size_t>> mf;
PYBIND11_MODULE(SIGNATURE, m)
py::class_<MeshFunExpression, std::shared_ptr<MeshFunExpression>,
dolfin::Expression> (m, "MeshFunExpression")
.def(py::init<>())
.def_readwrite("mf", &MeshFunExpression::mf);
# compile the c++ code to make an expression
phi = CompiledExpression( \
compile_cpp_code(cpp_code).MeshFunExpression(), \
mf=mf, degree=0)
# plotting
Z = FunctionSpace(mesh,"DG",0)
phi = project(phi,Z)
plot(phi)
plt.savefig("tmp.png")
I would be curious to know if anyone has done this in a neater or better way.
