I need to create a “callable” object from the solution of a FEM problem so I can use it as an initial condition for a coupled problem with a perturbed mesh, i.e. I can’t just copy over the current values at the domain DOFs.
I tried to create such a callable object and it works when -np is 1, but deadlocks when running with more than one process.
class InterpolatedSolution:
def __init__(self, fem_solution, domain):
self.fem_solution = fem_solution
self.bb_tree = geometry.bb_tree(domain, domain.topology.dim)
self.domain = domain
def __calc_solution_at(self, x):
pt = np.array([x]).reshape(1, 3)
# Choose one of the cells that contains the point
cell_candidates = geometry.compute_collisions_points(self.bb_tree, pt)
colliding_cells = geometry.compute_colliding_cells(
self.domain, cell_candidates, pt
cells = []
if len(colliding_cells.links(0)) > 0:
cells.append(colliding_cells.links(0)[0])
result = 0.0
if len(cells) == 1:
result = float(np.squeeze(self.fem_solution.eval(pt, cells)))
comm.barrier() # memory fence to make sure we wait on the actual thread that does the calculation
# from here on, result should be either 0.0 or the actual value on all threads
output = comm.allreduce(result, op=MPI.SUM)
return output
def __call__(self, x):
x = np.array(x)
if x.shape == (3,):
return self.__calc_solution_at(x)
return np.apply_along_axis(self.__calc_solution_at, axis=0, arr=x)
I’m sure that there is an easier way to do this, but I’m not used to MPI/fork-style parallelism yet ![]()
