Hey,
i am trying to create subdomains on a cube mesh because i want to impose a mixed functionspace on it, but solve two different, coupled equations on it.
The main geometry itself is a cube, but i want the cube and its top plate as two sperate subdomains on which i can solve the equations in one formulation.
Yes, one equation on the top of the cube, therefore a plate and the other equation on the rest of the volume.
The equations are coupled and i hope, that using subdomains, make it possible to use a mixed element space
A MixedElement is defined over the whole domain. Its intended usage is for instance when you have multiple variables on the full domain, such as a velocity-pressure pair. I would suggest having a look at the references I linked you above.
That is kind of the case, i first tried to solve each domain for itself and transfer the value from one functionspace to the ofther, since they are coupled. I was already able to define the desired functionspace with the desired subdomains. I will continue reading the references, but will mark this question as solved.
