Hello everyone,
I want to save solution fields obtained from dolfinx in a XDMF file using the dolfinx.io.XDMFFile
class.
I execute the following MWE on two cores in parallel with the usual command mpirun -n 2 /home/miniconda3/envs/fenicsx-bis/bin/python test.py
import dolfinx.io as io
comm = MPI.COMM_WORLD
filename = "test.xdmf"
if comm.rank == 0:
ffile = io.XDMFFile(comm, filename, 'w')
ffile.close()
However, it raises this error:
Abort(679551630) on node 1 (rank 1 in comm 496): Fatal error in internal_Allreduce_c: Message truncated, error stack:
internal_Allreduce_c(4173)...................: MPI_Allreduce_c(sendbuf=0x7ffc320b53e4, recvbuf=0x7ffc320b4f58, count=1, MPI_INT, MPI_MAX, comm=0x84000001) failed
MPID_Allreduce(475)..........................:
MPIDI_Allreduce_allcomm_composition_json(391):
MPIDI_Allreduce_intra_composition_gamma(599).:
MPIDI_POSIX_mpi_allreduce(313)...............:
MPIR_Allreduce_impl(4813)....................:
MPIR_Allreduce_allcomm_auto(4726)............:
MPIC_Sendrecv(309)...........................:
MPIC_Wait(91)................................:
MPIR_Wait(785)...............................:
MPIDIG_recv_type_init(77)....................: Message from rank 0 and tag 2 truncated; 4 bytes received but buffer size is 128
I set the environment variable HDF5_USE_FILE_LOCKING=FALSE
as suggested on other forums.
I installed dolfinx, mpi4py, and mpich from conda-forge. I have the following versions installed in the fenics-bis
conda environment in Ubuntu 24.04.1:
- fenics-dolfinx 0.9.0
- mpi4py 4.0.1
- mpich 4.2.3
Thanks in advance
