Consider the following MWE that is producing a segfault in latest dolfinx nightly (pulled 17 Jun) occasionally when trying to set DBCs on a submesh (though not on every call, hence the locate_dofs_topological is called in a loop of 100 times):
#!/usr/bin/env python3
from dolfinx import io, fem, mesh
comm = MPI.COMM_WORLD
dbcs_on_submeshes = True # True, False
mshfile_d='artseg-fsi-quad_domain.xdmf'
mshfile_b='artseg-fsi-quad_boundary.xdmf'
with io.XDMFFile(comm, mshfile_d, 'r', encoding=io.XDMFFile.Encoding.ASCII) as infile:
msh = infile.read_mesh(name="Grid")
mt_d = infile.read_meshtags(msh, name="Grid")
with io.XDMFFile(comm, mshfile_b, 'r', encoding=io.XDMFFile.Encoding.ASCII) as infile:
mt_b1 = infile.read_meshtags(msh, name="Grid")
# cf. https://fenicsproject.discourse.group/t/transfer-meshtags-to-submesh-in-dolfinx/8952/6
def meshtags_parent_to_child(mshtags, childmsh, childmsh_emap, parentmsh):
dim = parentmsh.topology.dim-1
d_map = parentmsh.topology.index_map(dim)
all_ent = d_map.size_local + d_map.num_ghosts
# create array with zeros for all entities that are not marked
all_values = np.zeros(all_ent, dtype=np.int32)
all_values[mshtags.indices] = mshtags.values
c_to_e = parentmsh.topology.connectivity(parentmsh.topology.dim, dim)
childmsh.topology.create_entities(dim)
subf_map = childmsh.topology.index_map(dim)
childmsh.topology.create_connectivity(parentmsh.topology.dim, dim)
c_to_e_sub = childmsh.topology.connectivity(parentmsh.topology.dim, dim)
num_sub_ent = subf_map.size_local + subf_map.size_global
sub_values = np.empty(num_sub_ent, dtype=np.int32)
for i, entity in enumerate(childmsh_emap):
parent_ent = c_to_e.links(entity)
child_ent = c_to_e_sub.links(i)
for child, parent in zip(child_ent, parent_ent):
sub_values[child] = all_values[parent]
return mesh.meshtags(childmsh, childmsh.topology.dim-1, np.arange(num_sub_ent, dtype=np.int32), sub_values)
for i in range(100):
msh_emap_solid = mesh.create_submesh(msh, msh.topology.dim, mt_d.indices[mt_d.values == 1])[0:2]
msh_emap_fluid = mesh.create_submesh(msh, msh.topology.dim, mt_d.indices[mt_d.values == 2])[0:2]
mt_b1_fluid = meshtags_parent_to_child(mt_b1, msh_emap_fluid[0], msh_emap_fluid[1], msh)
mt_b1_solid = meshtags_parent_to_child(mt_b1, msh_emap_solid[0], msh_emap_solid[1], msh)
# fluid and solid function spaces
P_v = ufl.VectorElement("CG", msh_emap_fluid[0].ufl_cell(), 2)
V_v = fem.FunctionSpace(msh_emap_fluid[0], P_v)
P_u = ufl.VectorElement("CG", msh_emap_solid[0].ufl_cell(), 2)
V_u = fem.FunctionSpace(msh_emap_solid[0], P_u)
if dbcs_on_submeshes:
# fluid DBCs
func_f = fem.Function(V_v) # zero function
dbcs_fluid = []
dbcs_fluid.append( fem.dirichletbc(func_f, fem.locate_dofs_topological(V_v, msh_emap_fluid[0].topology.dim-1, mt_b1_fluid.indices[mt_b1_fluid.values == 4])) )
dofs_x_f = fem.locate_dofs_topological(V_v.sub(0), msh_emap_fluid[0].topology.dim-1, mt_b1_fluid.indices[mt_b1_fluid.values == 5])
dbcs_fluid.append( fem.dirichletbc(func_f.sub(0), dofs_x_f) )
# solid DBCs
func_s = fem.Function(V_u) # zero function
dbcs_solid = []
dbcs_solid.append( fem.dirichletbc(func_s, fem.locate_dofs_topological(V_u, msh_emap_solid[0].topology.dim-1, mt_b1_solid.indices[mt_b1_solid.values == 4])) )
dofs_x_s = fem.locate_dofs_topological(V_u.sub(0), msh_emap_solid[0].topology.dim-1, mt_b1_solid.indices[mt_b1_solid.values == 5])
dbcs_solid.append( fem.dirichletbc(func_s.sub(0), dofs_x_s) )
# some function spaces on full mesh
P_ = ufl.VectorElement("CG", msh.ufl_cell(), 2)
V_ = fem.FunctionSpace(msh, P_v)
func_ = fem.Function(V_) # zero function
dbcs_ = []
dbcs_.append( fem.dirichletbc(func_, fem.locate_dofs_topological(V_, msh.topology.dim-1, mt_b1.indices[mt_b1.values == 5])) )
dofs_x_ = fem.locate_dofs_topological(V_.sub(0), msh.topology.dim-1, mt_b1.indices[mt_b1.values == 5])
dbcs_.append( fem.dirichletbc(func_.sub(0), dofs_x_) )
## check that mesh tags are actually written correctly
#with io.XDMFFile(comm, "sub_tag_solid.xdmf", "w") as xdmf:
#xdmf.write_mesh(msh_emap_solid[0])
#msh_emap_solid[0].topology.create_connectivity(msh.topology.dim-1, msh.topology.dim)
#xdmf.write_meshtags(mt_b1_solid, msh_emap_solid[0].geometry)
#with io.XDMFFile(comm, "sub_tag_fluid.xdmf", "w") as xdmf:
#xdmf.write_mesh(msh_emap_fluid[0])
#msh_emap_fluid[0].topology.create_connectivity(msh.topology.dim-1, msh.topology.dim)
#xdmf.write_meshtags(mt_b1_fluid, msh_emap_fluid[0].geometry)
Mesh files (hexa 27) can be retrieved from
http://www.deepambit.com/stuff/artseg-fsi-quad_domain.xdmf
http://www.deepambit.com/stuff/artseg-fsi-quad_boundary.xdmf
Error says
python3: /src/dolfinx/cpp/dolfinx/graph/AdjacencyList.h:102: int dolfinx::graph::AdjacencyList<T>::num_links(int) const [with T = int]: Assertion (node + 1) < (int)_offsets.size()’ failed.`
Setting dbcs_on_submeshes = False, hence bypassing that step and setting the DBCs on the main mesh works. Uncomment the last lines to verify that the meshtags are correctly transformed.
Am I doing something wrong here?
Thanks for any help.
Best,
Marc
