Hi, I am trying to define a time-varying velocity profile at the inlet of an arterial geometry in the normal direction. I found the following old code snippet to be very relevant (Simula.acdc.40).
class InflowBoundaryValue(Expression):
def init(self, problem=None, side=None):
self.problem = problem
self.side = side
self.bc_func, self.t_period = makeIC()
def eval_data(self, values, data):
n = data.cell().normal(data.facet())
t = self.problem.t
val = splev(t - int(t/self.t_period)*self.t_period, self.bc_func)
values [0] = -n.x()*val
values [1] = -n.y()*val
values [2] = -n.z()*val
def rank(self):
return 1
def dim(self):
return 3
It seems though that this concept of overloading the eval_data method of an Expression subclass is not still valid. Also, I don’t get what this data class(?) is (i.e. the argument in the eval_data method) that you can apply the cell() and facet() methods.
Anyway, I cannot find documentation on this issue or some other way to solve it. Can you please help me? Assume that I have this spline representation of the flow data (i.e. the val variable in the eval_data method) and my concern is how to create the normal parabolic profile. Also, I have a meshfunction representing the boundary where the condition needs to be applied.
