Hey again.
Below I’m adding my actual code. I used Paraview to visualise the domain and everything looks okay. As I mentioned, the program runs properly but clearly states boundary conditions may not have been applied properly. As I also mentioned above, I raised my forces to 1e-1 and still displacements are almost 0. There are three holes, but I want to calculate the solution as if the force was only applied on the upper lip of the upper hole. There might be other programming issues as I’m new to this, but I may have not seen them. Thanks in advance.
from dolfin import*
from mshr import*
from mshr import Polygon, generate_mesh
mesh=Mesh()
#longitudes en cm
domain = Polygon([Point(0.0,25.37), Point(-8.0,0.0), Point(8.0,0.0)])
domain = domain - Rectangle(Point(-0.5,5.),Point(0.5,6.79)) - Rectangle(Point(-0.5,11.79),Point(0.5,13.58)) - Rectangle(Point(-0.5,18.58),Point(0.5,20.37))
mesh = generate_mesh(domain,4)
vtkfile = File('holein/malla.pvd')
vtkfile << mesh
def eps(v):
return sym(grad(v))
#caracterizamos material E en N/cm^2
E = Constant(3.3e5)
nu = Constant(0.45)
model = "plane_stress"
G = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
if model == "plane_stress":
lmbda = 2*G*lmbda/(lmbda+2*G)
def sigma(v):
return lmbda*tr(eps(v))*Identity(2) + 2.0*G*eps(v)
#definir carga, cómo?
f=Constant((0,1e-3))
V = VectorFunctionSpace (mesh, 'Lagrange', degree=2)
du = TrialFunction(V)
u_ = TestFunction(V)
a = inner(sigma(du),eps(u_))*dx
l = inner(f,u_)*ds(4)
#contorno
class Left(SubDomain):
return near (x[0], -8.) and on_boundary
class Right(SubDomain):
return near (x[0], 8.) and on_boundary
class Bottom(SubDomain):
return near (x[1], 0.) and on_boundary
class Top(SubDomain):
return near (x[1], 20.37) and on_boundary
facets = MeshFunction("size_t", mesh, 1)
facets.set_all(0)
Left().mark(facets,1)
Right().mark(facets,2)
Bottom().mark(facets,3)
Top().mark(facets, 4)
ds = Measure('ds', subdomain_data=facets)
bc = [DirichletBC(V.sub(0), Constant(0.), facets, 1), DirichletBC(V.sub(1), Constant(0.), facets, 2), DirichletBC(V.sub(1), Constant(0.), facets, 3)]
u=Function(V, name="Desplazamientos")
solve (a==l, u, bc)
vtkfile = File('holein/desplazamientos.pvd')
vtkfile << u
Thanks
