Derivatives that work with dolfinx 0.9 do not work with 0.10
Hello everybody,
I have been using derivative decribed in this post:
I have been using this for testing with dolfinx 0.9 and it is passing the convergence test:
from dolfinx import geometry
from dolfinx import fem
import dolfinx.nls.petsc
import dolfinx.fem.petsc
import unittest
def wrap_constant_controls(controls):
    vars = {}
    for control in controls:
        for i in range(len(control)):
            vars[control[i]] = ufl.variable(control[i])
    return vars
class UflObjective:
    def __init__(self, J, u, controls):
        self.J = J
        self.J_form = fem.form(J)
        self.u = u
        self.controls = controls
        self.rhs = -ufl.derivative(J, u)
        self.rhs_form = fem.form(self.rhs)
        self.b = dolfinx.fem.petsc.create_vector(self.rhs_form)
        self.vars = wrap_constant_controls(self.controls)
        self.J_var_form = ufl.replace(self.J, self.vars)
        self.dJdk_form = [fem.form(ufl.diff(self.J_var_form, v)) for v in self.vars.values()]
    def assemble_adjoint_rhs_vector(self):
        with self.b.localForm() as b_loc:
            b_loc.set(0.0)
        dolfinx.fem.petsc.assemble_vector(self.b, self.rhs_form)
        self.b.assemble()
        return self.b
    def eval_dJdk(self):
        dJdk = np.zeros(len(self.dJdk_form))
        for i in range(len(self.dJdk_form)):
            dJdk[i] = fem.assemble_scalar(self.dJdk_form[i])
            dJdk[i] = MPI.COMM_WORLD.allreduce(dJdk[i], op=MPI.SUM)
        return dJdk
    def evaluate(self):
        J_value = fem.assemble_scalar(self.J_form)
        J_value = MPI.COMM_WORLD.allreduce(J_value, op=MPI.SUM)
        return J_value
class Point_wise_lsq_objective:
    def __init__(self, p_coords, f, controls, true_values = None):
        self.p_coords = p_coords
        self.f = f
        self.b = f.copy()
        self.true_values = true_values
        self.evaluate_dofs_sensitivities()
    def evaluate_dofs_sensitivities(self):
        # sensitivity of values at p_coords w.r.t values at dofs
        domain = self.f.function_space.mesh
        points = np.array(self.p_coords)
        fdim = domain.topology.dim
        bb_tree = geometry.bb_tree(domain, fdim)
        cell_candidates = geometry.compute_collisions_points(bb_tree, points)
        colliding_cells = geometry.compute_colliding_cells(domain, cell_candidates, points)
        # initialize result on each proc
        self.points = []
        self.cells = []
        self.dofs = []
        self.sensitivities = []
        self.true_values_map = []
        for i, point in enumerate(points):
                cell = colliding_cells.links(i)[0]
                dofs = self.f.function_space.dofmap.cell_dofs(cell)
                s = np.zeros(len(dofs))
                # there might exist nicer way but finite diff works too on (CG, 1)
                for j in range(len(dofs)):
                    val_0 = self.f.eval(point, cell)
                    self.f.x.array[dofs[j]] += 1.0
                    val_1 = self.f.eval(point, cell)
                    self.f.x.array[dofs[j]] -= 1.0
                    s[j] = val_1[0] - val_0[0]
                self.points.append(point)
                self.cells.append(cell)
                self.dofs.append(dofs)
                self.sensitivities.append(s)
                self.true_values_map.append(i)
        with self.b.x.petsc_vec.localForm() as b_loc:
            b_loc.set(0)
        for i in range(len(self.points)):
            # contribution to dJdu of single point
            value = -2*(self.f.eval(self.points[i], self.cells[i])[0]-self.true_values[self.true_values_map[i]])
            self.b.x.array[self.dofs[i]] += self.sensitivities[i]*value
        return self.b.x.petsc_vec
    def eval_points(self):
        values = []
            values.append(self.f.eval(self.points[i], self.cells[i])[0])
        return values
        dJdk = np.zeros(len(self.vars.keys()))
        return dJdk
    def evaluate(self):
        J_value = 0.0
            J_value += (self.f.eval(self.points[i], self.cells[i])[0]-self.true_values[self.true_values_map[i]])**2
        return J_value
class AdjointDerivative:
    def __init__(self, J, controls, form, forward_solver, u, bcs=None):
        self.form = form
        self.J = J
        self.forward_solver = forward_solver
        self.u = u
        self.lmbda = u.copy()
        self.bcs = bcs or []
        self.var_form = ufl.replace(self.form, self.vars)
        self.dFdk_form = [fem.form(ufl.diff(self.var_form, var)) for var in self.vars.values()]
        self.dFdk = [fem.petsc.create_vector(form) for form in self.dFdk_form]
        # adjoint problem solver definition
        self.lhs = ufl.adjoint(ufl.derivative(self.form, u))
        self.lhs_form = fem.form(self.lhs)
        self.A = dolfinx.fem.petsc.create_matrix(self.lhs_form)
        self.adjoint_solver = PETSc.KSP().create(u.function_space.mesh.comm)
        self.adjoint_solver.setOperators(self.A)
        self.adjoint_solver.setType(PETSc.KSP.Type.PREONLY)
        self.adjoint_solver.setTolerances(atol=1e-16)
        self.adjoint_solver.getPC().setType(PETSc.PC.Type.LU)
    def solve_adjoint_problem(self):
        # lhs assembly
        self.A.zeroEntries()
        dolfinx.fem.petsc.assemble_matrix_mat(self.A, self.lhs_form, bcs=self.bcs)
        self.A.assemble()
        # rhs assembly
        b = self.J.assemble_adjoint_rhs_vector()
        dolfinx.fem.petsc.apply_lifting(b, [self.lhs_form], bcs=[self.bcs])
        dolfinx.fem.petsc.set_bc(b, self.bcs)
        self.adjoint_solver.solve(b, self.lmbda.x.petsc_vec)
        self.lmbda.x.scatter_forward()
        return self.lmbda
    def compute_gradient(self, *args, **kwargs):
        # run forward solve
        self.forward_solver(*args, **kwargs)
        # solve adjoint vector
        self.solve_adjoint_problem()
        #initialize empty gradient vector
        dJdk = self.J.eval_dJdk()
        for i in range(len(self.dFdk)):
            # reassemble adjoint stuff
            with self.dFdk[i].localForm() as dfdk_loc:
                dfdk_loc.set(0)
            dolfinx.fem.petsc.assemble_vector(self.dFdk[i], self.dFdk_form[i])
            self.dFdk[i].ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
            # add dFdk*lmbda
            dJdk[i] += self.dFdk[i].dot(self.lmbda.x.petsc_vec)
        J_value = self.J.evaluate()
        return dJdk, J_value
def taylor_test(loss, grad, k0, p=1e-3, n=5):
        g0 = grad(k0)
        l0 = loss(k0)
        reminder = []
        perturbance = []
        for i in range(0, n):
            l1 = loss(k0+p)
            reminder.append(l1 - l0 - np.sum(g0*p))
            perturbance.append(p)
            p /= 2
        conv_rate = convergence_rates(reminder, perturbance)
        return reminder, perturbance, conv_rate
def convergence_rates(r, p):
    cr = []
    for i in range(1, len(p)):
        cr.append(np.log(r[i] / r[i - 1])
                 / np.log(p[i] / p[i - 1]))
    return cr
class TestDerivative(unittest.TestCase):
    def setUp(self) -> None:
        # mesh and function spaces
        mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD, [[0, 0], [1, 1]], [64, 64], dolfinx.mesh.CellType.triangle)
        V = dolfinx.fem.functionspace(mesh, ("P", 1)) # solution space
        self.u = dolfinx.fem.Function(V)  # solution trial
        v = ufl.TestFunction(V)  # solution test
        self.k = dolfinx.fem.Constant(mesh, PETSc.ScalarType((1.0, 1.0)))
        self.dx = ufl.Measure("dx")
        self.F = ufl.inner(ufl.grad(self.u), ufl.grad(v))*self.dx # heat equation
        self.F += sum(self.k)*v*self.dx # add source of heat
        # boundary conditions
        def left(x): return np.isclose(x[0], 0)
        fdim = mesh.topology.dim - 1
        u1 = dolfinx.fem.Function(V)
        boundary_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, left)
        with u1.x.petsc_vec.localForm() as loc:
            loc.set(0)
        bc1 = dolfinx.fem.dirichletbc(u1, dolfinx.fem.locate_dofs_topological(V, fdim, boundary_facets))
        self.bcs = [bc1]
        # solve the problem
        problem = dolfinx.fem.petsc.NonlinearProblem(self.F, self.u, self.bcs)
        self.solver = dolfinx.nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
        self.solver.convergence_criterion = "residual"
        self.solver.rtol = 1e-16
        self.forward = lambda : self.solver.solve(self.u)
    def test_ufl_objective(self):
        J = ufl.inner(self.u, self.u)*self.dx
        controls = [self.k]
        Jr = UflObjective(J, self.u, controls)
        adjoint = AdjointDerivative(Jr, controls, self.F, self.forward, self.u, self.bcs)
        def grad(value):
            self.k.value[:] = value
            g, l = adjoint.compute_gradient()
            return g
        def loss(value):
            l = Jr.evaluate()
            return l
        k0 = np.array([1, 1])
        r = taylor_test(loss, grad, k0)
        print(r[2])
        self.assertTrue(np.allclose(r[2], 2.0, atol=0.1), f"Taylor test failed - Convergence rate: {r[2]}")
    def test_lsq_objective(self):
        # sum of square errors at specific point in the domain
        points = [[0.0, 0.0, 0.0], [0.5, 0.5, 0.0]]
        true_values = [0.0, 0.0]
        controls = [self.k]
        Jr = Point_wise_lsq_objective(points, self.u, controls, true_values)
        def grad(value):
            return g
        def loss(value):
            l = Jr.evaluate()
            return l
    def test_optimisation(self):
        controls = [self.k]
        # find zero
        k_value = np.array([1.0, 1.0])
        alpha = 0.5
        # Vanila gradient descent
        for i in range(150):
            self.k.value += -alpha*g
            if MPI.COMM_WORLD.rank == 0:
                print(l, self.k.value)
        self.assertTrue(np.allclose(self.k.value, 0.0, atol=1e-6), f"k_value should be [0.0, 0.0] not {self.k.value}")
    def tearDown(self) -> None:
        pass
if __name__ == '__main__':
    unittest.main()
I have tried to implement this for version 0.10, but without success. I have change some of the stuff acording to the changlogs like this:
#0.9 version
#0.10 version
dolfinx.fem.petsc.create_vector(dolfinx.fem.extract_function_spaces(self.rhs_form))
#0.9 version
#0.10 version
dolfinx.fem.petsc.assemble_matrix(self.A, self.lhs_form, bcs=self.bcs)
#0.9 version
#0.10 version
self.F, self.u,
bcs=self.bcs,
petsc_options={"snes_type": "newtonls", "snes_atol": 1e-16, "snes_rtol": 1e-16, "ksp_rtol": 1e-16},
petsc_options_prefix="nonlindertest")
self.solver = problem
self.forward = lambda : self.solver.solve()
therefore the full version for dolfinx 0.10 is as follows
import unittest
    vars = {}
    return vars
class UflObjective:
        self.J = J
        self.u = u
            b_loc.set(0.0)
        self.b.assemble()
        return self.b
        return dJdk
    def evaluate(self):
        return J_value
        self.f = f
        self.b = f.copy()
        self.points = []
        self.cells = []
        self.dofs = []
            b_loc.set(0)
        values = []
        return values
        return dJdk
    def evaluate(self):
        J_value = 0.0
        return J_value
        self.form = form
        self.J = J
        self.u = u
        # lhs assembly
        self.A.assemble()
        # rhs assembly
        return self.lmbda
        # run forward solve
                dfdk_loc.set(0)
            # add dFdk*lmbda
        g0 = grad(k0)
        l0 = loss(k0)
        reminder = []
        perturbance = []
            l1 = loss(k0+p)
            p /= 2
    cr = []
    return cr
            loc.set(0)
        self.bcs = [bc1]
        # solve the problem
        controls = [self.k]
        def grad(value):
            return g
        def loss(value):
            l = Jr.evaluate()
            return l
        print(r[2])
        controls = [self.k]
        def grad(value):
            return g
        def loss(value):
            l = Jr.evaluate()
            return l
        controls = [self.k]
        # find zero
        alpha = 0.5
        pass
    unittest.main()
Nothing more is different, but now it does not work and I do not know what can be wrong, since it should in principle work the just the same. What am I missing?
Thank you for any reply.
You haven’t configured the solver of the linearized sub-problems of the Newton solver, for instance, setting:
            self.F,
            self.u,
            bcs=self.bcs,
            petsc_options={
                "snes_atol": 1e-16,
                "snes_rtol": 1e-16,
                "ksp_rtol": 1e-16,
                "ksp_type": "preonly",
                "pc_type": "lu",
                "snes_error_if_not_converged": True,
                "snes_monitor": None,
            petsc_options_prefix="nonlindertest",
will use a direct solver for the sub problems, and throw an error if snes doesn’t converge. To get an error if the linearized problem doesn’t converge, add "ksp_error_if_not_converged": True
Complete modified code:
import unittest
    vars = {}
    return vars
class UflObjective:
        self.J = J
        self.u = u
        self.dJdk_form = [
            b_loc.set(0.0)
        self.b.assemble()
        return self.b
        return dJdk
    def evaluate(self):
        return J_value
    def __init__(self, p_coords, f, controls, true_values=None):
        self.f = f
        self.b = f.copy()
        self.points = []
        self.cells = []
        self.dofs = []
            b_loc.set(0)
            value = -2 * (
                - self.true_values[self.true_values_map[i]]
            self.b.x.array[self.dofs[i]] += self.sensitivities[i] * value
        values = []
        return values
        return dJdk
    def evaluate(self):
        J_value = 0.0
            J_value += (
            ) ** 2
        return J_value
        self.form = form
        self.J = J
        self.u = u
        self.dFdk_form = [
        self.dFdk = [
            fem.petsc.create_vector(fem.extract_function_spaces(form))
        # lhs assembly
        self.A.assemble()
        # rhs assembly
        return self.lmbda
        # run forward solve
        # initialize empty gradient vector
                dfdk_loc.set(0)
            # add dFdk*lmbda
    g0 = grad(k0)
    l0 = loss(k0)
    reminder = []
    perturbance = []
        l1 = loss(k0 + p)
        reminder.append(l1 - l0 - np.sum(g0 * p))
        p /= 2
    cr = []
        cr.append(np.log(r[i] / r[i - 1]) / np.log(p[i] / p[i - 1]))
    return cr
        self.F = ufl.inner(ufl.grad(self.u), ufl.grad(v)) * self.dx  # heat equation
        self.F += sum(self.k) * v * self.dx  # add source of heat
        def left(x):
            loc.set(0)
        self.bcs = [bc1]
        # solve the problem
            self.F,
            self.u,
            bcs=self.bcs,
            petsc_options={
                "snes_atol": 1e-16,
                "snes_rtol": 1e-16,
                "ksp_rtol": 1e-16,
                "pc_type": "lu",
        self.forward = lambda: self.solver.solve()
        J = ufl.inner(self.u, self.u) * self.dx
        controls = [self.k]
        def grad(value):
            return g
        def loss(value):
            self.solver.solve()
            l = Jr.evaluate()
            return l
        print(r[2])
        self.assertTrue(
            f"Taylor test failed - Convergence rate: {r[2]}",
        controls = [self.k]
        def grad(value):
            return g
        def loss(value):
            self.solver.solve()
            l = Jr.evaluate()
            return l
        self.assertTrue(
        controls = [self.k]
        # find zero
        alpha = 0.5
            self.k.value += -alpha * g
        self.assertTrue(
            f"k_value should be [0.0, 0.0] not {self.k.value}",
        pass
if __name__ == "__main__":
    unittest.main()
Thank you @dokken,
I have been away for a while, but it worked well and all of my code is now converted to 0.10.
