I am trying to reproduce an example from Mathematica:
u_1'(x)-u_2(x)=0
u_2'(x)+u_1(x)-5(1-u_1^2(x))u_2(x)=0
with u_1(0)=2 and u_2(0)=0.
The solution should be like this (confirmed from Mathamtica):
This is a nonlinear problem. So when solving the algebraic system, proper initial guess should be assigned. The function is shaking violently, so I choose a random array as the initial guess. To obtain this solution, I had to run the code again and again until I saw a convergence in the iteration. The reason might still lie on the shape of the functions. Also, if I shrank the interval, say [0, 4], it became easier to converge and harder when prolong the interval say [0, 15]. This is understandable from the same view: the shorter interval corresponds to smoother functions while the longer interval may introduce another peak. In the example I choose [0, 8]. I was wondering if there is a better way to solve the algebraic system. I was trying to adjust
snes.getKSP().setType("preonly")
snes.getKSP().getPC().setType("lu")
snes.getKSP().getPC().setFactorSolverType("mumps")
but didn’t know how to do exactly… And I also wonder if there is another way to improve the code.
import dolfinx.fem
import dolfinx.fem.petsc
import dolfinx.io
import mpi4py.MPI
import petsc4py.PETSc
import viskex
import multiphenicsx.fem
import multiphenicsx.fem.petsc
n = 300
(x_min, x_max) = (0, 8)
mesh = dolfinx.mesh.create_interval(mpi4py.MPI.COMM_WORLD, n, [x_min, x_max])
tdim = mesh.topology.dim
fdim = tdim - 1
facet_left = dolfinx.mesh.locate_entities_boundary(
mesh, fdim, lambda x: np.isclose(x[0], x_min)
boundaries = [(1, lambda x: np.isclose(x[0], x_min)),
(2, lambda x: np.isclose(x[0], x_max))]
facets = dolfinx.mesh.locate_entities(mesh, fdim, locator)
facet_indices.append(facets)
facet_tag = dolfinx.mesh.meshtags(mesh, fdim,
facet_indices, facet_markers)
ds = ufl.Measure("ds", domain=mesh, subdomain_data=facet_tag)
U1_element = ufl.FiniteElement("Lagrange", mesh.ufl_cell(), 2)
U2_element = ufl.FiniteElement("Lagrange", mesh.ufl_cell(), 2)
def run_monolithic():
U_element = ufl.MixedElement(U1_element, U2_element)
U = dolfinx.fem.functionspace(mesh, U_element)
du1u2 = ufl.TrialFunction(U)
u1u2 = dolfinx.fem.Function(U)
(u1, u2) = ufl.split(u1u2)
v1v2 = ufl.TestFunction(U)
(v1, v2) = ufl.split(v1v2)
u1u2.x.array[:] = 2 * np.random.rand(1,1)[0][0]
F = u1 * v1 * ds(2) - 2 * v1 * ds(1) - u1 * v1.dx(0) * ufl.dx - u2 * v1 * ufl.dx\
+ (u2.dx(0) + u1 - 5 * (1 - u1**2) * u2) * v2 * ufl.dx
J = ufl.derivative(F, u1u2, du1u2)
u2_left = dolfinx.fem.Function(U.sub(1).collapse()[0])
u2_left.x.array[:] = 0
bdofs_U2 = dolfinx.fem.locate_dofs_topological(
(U.sub(1), U.sub(1).collapse()[0]), fdim, facet_left)
left_bc_u2 = dolfinx.fem.dirichletbc(u2_left, bdofs_U2, U.sub(1))
bc = [left_bc_u2]
class coupled2_1(object):
def __init__(
self, F, J, solution, bcs, P=None
self._F = dolfinx.fem.form(F)
self._J = dolfinx.fem.form(J)
self._obj_vec = dolfinx.fem.petsc.create_vector(self._F)
self._solution = solution
self._bcs = bcs
self._P = P
def create_snes_solution(self):
x = self._solution.vector.copy()
with x.localForm() as _x, self._solution.vector.localForm() as _solution:
_x[:] = _solution
return x
def update_solution(self, x):
x.ghostUpdate(addv=petsc4py.PETSc.InsertMode.INSERT, mode=petsc4py.PETSc.ScatterMode.FORWARD)
_solution[:] = _x
def obj(
self, snes, x
self.F(snes, x, self._obj_vec)
return self._obj_vec.norm()
def F(
self, snes, x, F_vec
self.update_solution(x)
with F_vec.localForm() as F_vec_local:
F_vec_local.set(0.0)
dolfinx.fem.petsc.assemble_vector(F_vec, self._F)
dolfinx.fem.apply_lifting(F_vec, [self._J], [self._bcs], x0=[x], scale=-1.0)
F_vec.ghostUpdate(addv=petsc4py.PETSc.InsertMode.ADD, mode=petsc4py.PETSc.ScatterMode.REVERSE)
dolfinx.fem.set_bc(F_vec, self._bcs, x, -1.0)
def J(
self, snes, x, J_mat, P_mat
J_mat.zeroEntries()
dolfinx.fem.petsc.assemble_matrix(
J_mat, self._J, self._bcs, diagonal=1.0
J_mat.assemble()
if self._P is not None:
P_mat.zeroEntries()
P_mat, self._P, self._bcs, diagonal=1.0
P_mat.assemble()
problem = coupled2_1(F, J, u1u2, bc)
F_vec = dolfinx.fem.petsc.create_vector(problem._F)
J_mat = dolfinx.fem.petsc.create_matrix(problem._J)
snes = petsc4py.PETSc.SNES().create(mesh.comm)
snes.setTolerances(max_it=200)
snes.setObjective(problem.obj)
snes.setFunction(problem.F, F_vec)
snes.setJacobian(problem.J, J=J_mat, P=None)
snes.setMonitor(lambda _, it, residual: print(it, residual))
u1u2_copy = problem.create_snes_solution()
snes.solve(None, u1u2_copy)
problem.update_solution(u1u2_copy)
u1u2_copy.destroy()
snes.destroy()
return u1u2
u1u2_m = run_monolithic()
(u1_m, u2_m) = (u1u2_m.sub(0).collapse(), u1u2_m.sub(1).collapse())
viskex.dolfinx.plot_scalar_field(u1_m, "u1_m")
viskex.dolfinx.plot_scalar_field(u2_m, "u2_m")
