I would suggest using the MixedDimensional Finite element method implemented by @cdaversin, whole paper can be found at: https://arxiv.org/pdf/1911.01166.pdf
Using a MeshView for each domain should make it possible to transfer data between the two domains.
You could Also consider interpolating between the non-matching meshes, see: Data projection from one mesh to another mesh
