Robin boundary condition for 2D problem
Hello everyone,
I am trying to implement Robin boundary condition in 2D problem. The schematic for the problem is given below. In the problem 𝜎_12= 𝛼_1 𝑒_1 and 𝜎_22= 𝛼_2 𝑒_2 where 𝑒_1 and 𝑒_2 are components of the vector displacement field u to be solved. Any suggestions or help on how to add the stress terms in the variational form ?
Have you written down the weak form on paper?
Do you know how that would work for the case of a Neumann boundary condition? Can you start from there and see what is the difference in your case?
This is a forum about FEniCS specific support, we are not supposed to answer in detail about all possible background you may be missing on the finite element method.
Hello Francesco,
I have the weak form written down as
The term on the right side can be written as
I know how to implement Neumann boundary condition. So implement this in FEniCSx, I tried the following code:
Coeff = ufl.as_tensor([[alpha1, 0], [0, alpha_2]])
u = ufl.TrialFunction(V)
Tr_top = ufl.dot(Coeff, u)
a = ufl.inner(sigma(u), epsilon(v))*ufl.dx - ufl.dot(Tr_top, v) *ufl.ds
Is this the correct way to implement it ?
It follows the same logic as when you write the problem on paper.
So yes, you would include the term
in your variational form.
Please note that since you are using a as a variable name, I am assuming that you are trying to set up a linear system (a(u,v)=L(v)).
Then you should either write everything in a residual form, such as
F = ufl.inner(sigma(u), epsilon(v))*ufl.dx - ufl.dot(Tr_top, v) *ufl.ds
and use
a, L = ufl.system(F)
to get the bi-linear and linear form, or just write them out by hand:
L = ufl.dot(Tr_top, v) *ufl.ds
@viveksingh What you have written down is not a Robin condition though. Are you sure that is what you need?
In your context, a Neumann condition would be:
\sigma\cdot n = T_{top} \,\, on \,\,\partial\Omega_{top}
That condition is substituted into the boundary integral that shows up in working out the weak formulation and then moved to the right hand side. And @dokken has provided you the code with how to implement that in FEniCS.
A Robin condition, though, would look like:
\sigma\cdot n + \alpha u = T_{top} \,\, on \,\,\partial\Omega_{top}
Substituting that into the boundary integral gives you an additional term in your left hand side.
Augmenting Dokken’s earlier code snippet:
a = ufl.inner(sigma(u), epsilon(v))*ufl.dx + ufl.dot(alpha * u, v) *ufl.ds
