Dirichlet BCs not iterable in newton solver (newton Krylov)
Hi, I am faced with the following strange error, which I do not understand: “TypeError: ‘DirichletBC’ object is not iterable”. The error proceeds from solver.solve(u) in the code below. I don’t understand why the Dirichlet BCs need to be iterable? How can I make them iterable? Any help would be greatly appreciated! Thanks!
import matplotlib
from dolfinx import mesh, fem, io, plot, la
import pyvista
from dolfinx import *
import numpy, sys
from ufl import (VectorElement, FiniteElement,
                 SpatialCoordinate, TrialFunction, TestFunction,
                 as_vector, cos, sin, inner, div, grad, dx, pi, system)
from dolfinx import mesh, fem, io, nls, log
##cretae a rectangular mesh with quadrilateral elements
##note: here theta=x
domain = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
D= fem.Constant(domain, 1.0) ##diffusion constant
u_ufl = x[1] - (1/6)*x[1]**3  ##note that u_ufl is the exact solution we are using to interpolate AKA this is the trial fucntion
#define the domain and boundary conditions
V = fem.FunctionSpace(domain, ("Lagrange", 3))
def u_exact(x):
    return eval(str(u_ufl))
u_D = fem.Function(V)
##set up interpolation calling on the seleted basis (u xact, exact soln)
u_D.interpolate(u_exact)
#boundary_facets = mesh.locate_entities_boundary(domain, fdim, lambda x: numpy.full(x.shape[1], True, dtype=bool))
#bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets))
domain.topology.create_connectivity(fdim, fdim + 1)
boundary_facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
bc = dolfinx.fem.dirichletbc(u_D, dolfinx.fem.locate_dofs_topological(V, fdim, boundary_facets))
##setting up the variational problem
from ufl import (TestFunction, SpatialCoordinate, TrialFunction,
                 as_vector, dx, grad, inner, system, equation, Constant)
u = fem.Function(V)  ##time-dep c at n+1
un = fem.Function(V) ##time dep C at n
dt = fem.Constant(domain, 0.05)
##define the variational problem
F = (un*v*ufl.dx)
F -= u*v*dx - sin(u)*u*v*dt*dx - D*dt*inner(grad(u), grad(v))*dx + D*dt*v*dx
# variational problem stated as a=L
problem = NonlinearProblem(F, u, bcs=bc)
solver = NewtonSolver(MPI.COMM_WORLD, problem )
solver.rtol = 1e-6
solver.report = True
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
n, converged = solver.solve(u)
assert (converged)
print(f"Number of interations: {n:d}")```
The error might remove with update of NonlinearProblem(F, u, bcs=[bc])
Thanks so much! Now I obtain the following error:“RuntimeError: Newton solver did not converge because maximum number of iterations reached”. How might I change the number of newton iterations allowed?
Nonlinear problem page could help by changing jit_options.
