Dirichlet Boundary Conditions Involving Extant UFL Functions
Hi everyone,
I’m using FEniCS 2019.1.0 to solve the lattice Boltzmann equations - that is
\frac{\partial f_i}{\partial_t} + \mathbf{c}_i \cdot \nabla f_i = j_i(f_1,...,f_m) + F_i(f_1,...,f_m)
on the domain
\Omega = [0,1]^2.
The above is a system of m (in this case 9) coupled PDEs, where j_i and F_i are non-linear functions of all the f_i's. It bears mentioning that each f_i is referred to as a distribution.
My question specifically concerns the application of boundary conditions. A common technique is to apply so-called bounce \,back boundary conditions. This means, for example, that on the bottom boundary, we impose the condition that f_5^{n+1} \gets f_7^n, \; f_4^{n+1} \gets f_2^{n} and f_8^{n+1} \gets f_6^{n}. Here I will refer to f_7 as the conjugate distribution to f_5, f_2 as the conjugate to f_4 and so on.
Currently, my procedure for imposing boundary conditions is the following (considering only f_5 for the sake of brevity): after defining a function to identify the bottom boundary, I define a UFL Function f5_lower_func.
After this – having applied initial values to on all the distributions – I project the conjugate distribution to f_5 into the function space V and store the result in f5_lower_func.
I then initialize an object of type DirichletBC, using
bc_f5 = fe.DirichletBC(V, f5_lower_func, Bdy_Lower)
Then, within the time loop, after updating each of distributions and saving the updated value of f_7 in f7_n, I project f_7 into V, saving the result in f5_lower_func.
This seemed like a sensible procedure but my results don’t agree with my expectation. Does my boundary procedure do what I think it’s doing?
import fenics as fe
plt.close('all')
T = 100
dt = 1
#num_steps = 750
num_steps = int(np.ceil(T/dt))
tau = 1.0
# Number of discrete velocities
Q = 9
Force_density = np.array([2.6e-5, 0.0])
#Force prefactor
alpha = ( 2/dt + 1/tau )
# Density on wall
rho_wall = 1.0
# Initial density
rho_init = 1.0
u_wall = (0.0, 0.0)
# Lattice speed of sound
c_s = 1/np.sqrt(3)
# D2Q9 lattice velocities
xi = [
    fe.Constant(( 0.0,  0.0)),
    fe.Constant(( 1.0,  0.0)),
    fe.Constant(( 0.0,  1.0)),
    fe.Constant((-1.0,  0.0)),
    fe.Constant(( 0.0, -1.0)),
    fe.Constant(( 1.0,  1.0)),
    fe.Constant((-1.0,  1.0)),
    fe.Constant((-1.0, -1.0)),
    fe.Constant(( 1.0, -1.0)),
# Corresponding weights
w = np.array([
    4/9,
    1/9, 1/9, 1/9, 1/9,
    1/36, 1/36, 1/36, 1/36
# Set up domain. For simplicity, do unit square mesh.
nx = ny = 30
L_x = L_y = 1
mesh = fe.UnitSquareMesh(nx, ny)
# Set periodic boundary conditions at left and right endpoints
class PeriodicBoundaryX(fe.SubDomain):
        return fe.near(x[0], 0.0) and on_boundary
    def map(self, x, y):
        # Map left boundary to the right
        y[0] = x[0] - L_x
        y[1] = x[1]
pbc = PeriodicBoundaryX()
V = fe.FunctionSpace(mesh, "P", 1, constrained_domain=pbc)
V_vec = fe.VectorFunctionSpace(mesh, "P", 1, constrained_domain=pbc)
f0, f1, f2 = fe.TrialFunction(V), fe.TrialFunction(V), fe.TrialFunction(V)
f3, f4, f5 = fe.TrialFunction(V), fe.TrialFunction(V), fe.TrialFunction(V)
f6, f7, f8 = fe.TrialFunction(V), fe.TrialFunction(V), fe.TrialFunction(V)
f_list = [f0, f1, f2, f3, f4, f5, f6, f7, f8]
v = fe.TestFunction(V)
# Define functions for solutions at previous time steps
f0_n, f1_n, f2_n = fe.Function(V), fe.Function(V), fe.Function(V)
f3_n, f4_n, f5_n = fe.Function(V), fe.Function(V), fe.Function(V)
f6_n, f7_n, f8_n = fe.Function(V), fe.Function(V), fe.Function(V)
f_list_n = [f0_n, f1_n, f2_n, f3_n, f4_n, f5_n, f6_n, f7_n, f8_n]
# Define density
def rho(f_list):
    return f_list[0] + f_list[1] + f_list[2] + f_list[3] + f_list[4]\
        + f_list[5] + f_list[6] + f_list[7] + f_list[8]
# Define velocity
def vel(f_list):
    distr_fn_sum = f_list[0]*xi[0] + f_list[1]*xi[1] + f_list[2]*xi[2]\
        + f_list[3]*xi[3] + f_list[4]*xi[4] + f_list[5]*xi[5]\
            + f_list[6]*xi[6] + f_list[7]*xi[7] + f_list[8]*xi[8]
    density = rho(f_list)
    vel_term1 = distr_fn_sum/density
    F = fe.Constant( (Force_density[0], Force_density[1]) )
    vel_term2 = F * dt / ( 2 * density )
    return vel_term1 + vel_term2
# Define initial equilibrium distributions
def f_equil_init(vel_idx, Force_density):
    rho_init = fe.Constant(1.0)
    rho_expr = fe.Constant(1.0)
    vel_0 = -fe.Constant( ( Force_density[0]*dt/(2*rho_init),
                           Force_density[1]*dt/(2*rho_init) ) )
    # u_expr = fe.project(V_vec, vel_0)
    ci = xi[vel_idx]
    ci_dot_u = fe.dot(ci, vel_0)
    return w[vel_idx] * rho_expr * (
        1
        + ci_dot_u / c_s**2
        + ci_dot_u**2 / (2*c_s**4)
        - fe.dot(vel_0, vel_0) / (2*c_s**2)
# Define equilibrium distribution
def f_equil(f_list, vel_idx):
    rho_expr = sum(fj for fj in f_list)
    u_expr   = vel(f_list)
    ci       = xi[vel_idx]
    ci_dot_u = fe.dot(ci, u_expr)
        1
        + ci_dot_u / c_s**2
        - fe.dot(u_expr, u_expr) / (2*c_s**2)
# Define collision operator
def coll_op(f_list, vel_idx):
    return -( f_list[vel_idx] - f_equil(f_list, vel_idx) ) / tau
def body_Force(vel, vel_idx, Force_density):
    prefactor = (1 - dt/( 2 * tau) )*w[vel_idx]
    inverse_cs2 = 1 / c_s**2
    inverse_cs4 = 1 / c_s**4
    xi_dot_prod_F = xi[vel_idx][0]*Force_density[0]\
        + xi[vel_idx][1]*Force_density[1]
    u_dot_prod_F = vel[0]*Force_density[0] + vel[1]*Force_density[1]
    xi_dot_u = xi[vel_idx][0]*vel[0] + xi[vel_idx][1]*vel[1]
    Force = prefactor*( inverse_cs2*(xi_dot_prod_F - u_dot_prod_F)\
                       + inverse_cs4*xi_dot_u*xi_dot_prod_F)
    return Force
# Initialize distribution functions. We will use
# f_i^{0} \gets f_i^{0, eq}( \rho_0, \bar{u}_0 ),
# where \bar{u}_0 = u_0 - F\Delta t/( 2 \rho_0 ).
# Here we will take u_0 = 0.
f0_n = fe.project(f_equil_init(0, Force_density), V )
f1_n = fe.project(f_equil_init(1, Force_density), V )
f2_n = fe.project(f_equil_init(2, Force_density), V )
f3_n = fe.project(f_equil_init(3, Force_density), V )
f4_n = fe.project(f_equil_init(4, Force_density), V )
f5_n = fe.project(f_equil_init(5, Force_density), V )
f6_n = fe.project(f_equil_init(6, Force_density), V )
f7_n = fe.project(f_equil_init(7, Force_density), V )
f8_n = fe.project(f_equil_init(8, Force_density), V )
# Define boundary conditions.
# For f_5, f_2, and f_6, equilibrium boundary conditions at lower wall
# Since we are applying equilibrium boundary conditions
# and assuming no slip on solid walls, f_i^{eq} reduces to
# \rho * w_i
tol = 1e-8
def Bdy_Lower(x, on_boundary):
    if on_boundary:
        if fe.near(x[1], 0, tol):
            return True
            return False
        return False
rho_expr = sum( fk for fk in f_list_n )
f5_lower = f7_n
f2_lower = f4_n
f6_lower = f8_n
f5_lower_func = fe.Function(V)
f2_lower_func = fe.Function(V)
f6_lower_func = fe.Function(V)
f5_lower_func = fe.project( f5_lower, V )
f2_lower_func = fe.project( f2_lower, V )
f6_lower_func = fe.project( f6_lower, V )
bc_f2 = fe.DirichletBC(V, f2_lower_func, Bdy_Lower)
bc_f6 = fe.DirichletBC(V, f6_lower_func, Bdy_Lower)
# Similarly, we will define boundary conditions for f_7, f_4, and f_8
# at the upper wall. Once again, boundary conditions simply reduce
# to \rho * w_i
tol = 1e-8
def Bdy_Upper(x, on_boundary):
    if on_boundary:
        if fe.near(x[1], 1, tol):
            return True
            return False
        return False
f7_upper = f5_n
f4_upper = f2_n
f8_upper = f6_n
f7_upper_func = fe.Function(V)
f4_upper_func = fe.Function(V)
f8_upper_func = fe.Function(V)
f7_upper_func = fe.project( f7_upper, V )
f4_upper_func = fe.project( f4_upper, V )
f8_upper_func = fe.project( f8_upper, V )
bc_f7 = fe.DirichletBC(V, f7_upper_func, Bdy_Upper)
bc_f4 = fe.DirichletBC(V, f4_upper_func, Bdy_Upper)
bc_f8 = fe.DirichletBC(V, f8_upper_func, Bdy_Upper)
# Define variational problems
a0 = f0 * v * fe.dx + dt*fe.dot( xi[0], fe.grad(f0) ) * v * fe.dx
L0 = ( f0_n + dt*coll_op(f_list_n, 0)\
      + dt * body_Force( vel(f_list_n), 0, Force_density) ) * v * fe.dx
a1 = f1 * v * fe.dx + dt*fe.dot( xi[1], fe.grad(f1) ) * v * fe.dx
L1 = ( f1_n + dt*coll_op(f_list_n, 1)\
      + dt * body_Force( vel(f_list_n), 1, Force_density) ) * v * fe.dx
a2 = f2 * v * fe.dx + dt*fe.dot( xi[2], fe.grad(f2) ) * v * fe.dx
L2 = ( f2_n + dt*coll_op(f_list_n, 2)\
      + dt * body_Force( vel(f_list_n), 2, Force_density) ) * v * fe.dx
a3 = f3 * v * fe.dx + dt*fe.dot( xi[3], fe.grad(f3) ) * v * fe.dx
L3 = ( f3_n + dt*coll_op(f_list_n, 3)\
      + dt * body_Force( vel(f_list_n), 3, Force_density) ) * v * fe.dx
a4 = f4 * v * fe.dx + dt*fe.dot( xi[4], fe.grad(f4) ) * v * fe.dx
L4 = ( f4_n + dt*coll_op(f_list_n, 4)\
      + dt * body_Force( vel(f_list_n), 4, Force_density) ) * v * fe.dx
a5 = f5 * v * fe.dx + dt*fe.dot( xi[5], fe.grad(f5) ) * v * fe.dx
L5 = ( f5_n + dt*coll_op(f_list_n, 5)\
      + dt * body_Force( vel(f_list_n), 5, Force_density) ) * v * fe.dx
a6 = f6 * v * fe.dx + dt*fe.dot( xi[6], fe.grad(f6) ) * v * fe.dx
L6 = ( f6_n + dt*coll_op(f_list_n, 6)\
      + dt * body_Force( vel(f_list_n), 6, Force_density) ) * v * fe.dx
a7 = f7 * v * fe.dx + dt*fe.dot( xi[7], fe.grad(f7) ) * v * fe.dx
L7 = ( f7_n + dt*coll_op(f_list_n, 7)\
      + dt * body_Force( vel(f_list_n), 7, Force_density) ) * v * fe.dx
a8 = f8 * v * fe.dx + dt*fe.dot( xi[8], fe.grad(f8) ) * v * fe.dx
L8 = ( f8_n + dt*coll_op(f_list_n, 8)\
      + dt * body_Force( vel(f_list_n), 8, Force_density) ) * v * fe.dx
# Assemble matrices
A0, A1, A2 = fe.assemble(a0), fe.assemble(a1), fe.assemble(a2)
A3, A4, A5 = fe.assemble(a3), fe.assemble(a4), fe.assemble(a5)
A6, A7, A8 = fe.assemble(a6), fe.assemble(a7), fe.assemble(a8)
# Time-stepping
f0, f1, f2 = fe.Function(V), fe.Function(V), fe.Function(V)
f3, f4, f5 = fe.Function(V), fe.Function(V), fe.Function(V)
f6, f7, f8 = fe.Function(V), fe.Function(V), fe.Function(V)
t = 0
for n in range(num_steps):
    # Update current time
    # Assemble right-hand side vectors
    b0, b1, b2 = fe.assemble(L0), fe.assemble(L1), fe.assemble(L2)
    b3, b4, b5 = fe.assemble(L3), fe.assemble(L4), fe.assemble(L5)
    b6, b7, b8 = fe.assemble(L6), fe.assemble(L7), fe.assemble(L8)
    # Apply BCs for distribution functions 5, 2, and 6
    bc_f5.apply(A5, b5)
    bc_f2.apply(A2, b2)
    bc_f6.apply(A6, b6)
    # Apply BCs for distribution functions 7, 4, 8
    bc_f7.apply(A7, b7)
    bc_f4.apply(A4, b4)
    bc_f8.apply(A8, b8)
    f0Vec, f1Vec, f2Vec = f0.vector(), f1.vector(), f2.vector()
    f3Vec, f4Vec, f5Vec = f3.vector(), f4.vector(), f5.vector()
    f6Vec, f7Vec, f8Vec = f6.vector(), f7.vector(), f8.vector()
    # Solve linear system in each time step
    fe.solve(A0, f0Vec, b0)
    fe.solve(A1, f1Vec, b1)
    fe.solve(A2, f2Vec, b2)
    fe.solve(A3, f3Vec, b3)
    fe.solve(A4, f4Vec, b4)
    fe.solve(A5, f5Vec, b5)
    fe.solve(A6, f6Vec, b6)
    fe.solve(A7, f7Vec, b7)
    fe.solve(A8, f8Vec, b8)
    # Update previous solution
    f0_n.assign(f0)
    f1_n.assign(f1)
    f2_n.assign(f2)
    f3_n.assign(f3)
    f4_n.assign(f4)
    f5_n.assign(f5)
    f6_n.assign(f6)
    f7_n.assign(f7)
    f8_n.assign(f8)
    fe.project(f7_n, V, function=f5_lower_func)
    fe.project(f4_n, V, function=f2_lower_func)
    fe.project(f8_n, V, function=f6_lower_func)
    fe.project(f5_n, V, function=f7_upper_func)
    fe.project(f2_n, V, function=f4_upper_func)
    fe.project(f6_n, V, function=f8_upper_func)
u_expr = vel(f_list_n)
u = fe.project(u_expr, V_vec)
# Plot velocity field
coords = V_vec.tabulate_dof_coordinates()[::2]
u_values = u.vector().get_local().reshape((V_vec.dim() // 2, 2))
x = coords[:, 0]  # x-coordinates
y = coords[:, 1]  # y-coordinates
u_x = u_values[:, 0]  # x-components of velocity
u_y = u_values[:, 1]  # y-components of velocity
# Define arrow scale based on maximum velocity
max_u = np.max(np.sqrt(u_x**2 + u_y**2))
arrow_length = 0.05  # 5% of domain size
scale = max_u / arrow_length if max_u > 0 else 1
# Plot vector field
plt.figure()
M = np.hypot(u_x, u_y)
plt.quiver(x, y, u_x, u_y, M, scale=scale, scale_units='height')
plt.title("Velocity field at final time")
plt.xlabel("x")
plt.ylabel("y")
# Plot velocity profile at midpoint of channel
num_points = 100
y_values = np.linspace(0, 1, num_points)
x_fixed = 0.5
points = [(x_fixed, y) for y in y_values]
u_x_values = []
for point in points:
    u_at_point = u(point)
    u_x_values.append(u_at_point[0])
plt.figure()
plt.plot(u_x_values, y_values)
plt.xlabel("u_x")
plt.ylabel("y")
plt.title("Velocity profile at x=0.5")
‘my results don’t agree with my expectation’ doesn’t give the community a lot to go on :wink: . Also, your code and question are quite complex (and not MWE) so it’s difficult to give targeted help.
But, there are two things I notice in your code which may or may not relate to your issue.
Since all your function objects live in space V, why use projection at all? The block
could be replaced by
f5_lower_func.assign(f7_n)
Right? I don’t think that should make a difference in the results, but there actually doesn’t appear to be a reference to the function argument in the project documentation, so I wouldn’t be 100% sure about what it does (my docker image is 2019.2.0.dev, so maybe in 2019.1 it’s different).
I’m also noticing some overwrites of functions, that may lead to unexpected results. I.e.,
all these are later overwritten in
and later again in
Notice that this means that the variable name f0_n maps to a different Function object throughout your code. The same thing happens to a bunch of other functions. That’s asking for trouble.
I haven’t spotted a case in particulat that could be the culprit, but that would be a place to start looking for a bug.
