Dirichlet boundary of DG/RT/N1curl element?
Hi everyone!
I attempted to assemble Dirichlet boundary conditions for DG finite element analysis, but in my testing, dofs was empty. It seems that it cannot locate the freedom of the node. Why is this?
from dolfinx import fem
from dolfinx.fem import (Constant, Function, FunctionSpace, dirichletbc,
                         extract_function_spaces, form,
                         locate_dofs_geometrical, locate_dofs_topological)
from dolfinx.mesh import (CellType, GhostMode, create_rectangle,
                          locate_entities_boundary,create_unit_cube)
from ufl import div, dx, grad, inner,dot,outer,ds,dS,avg,jump,rot,cross
from petsc4py import PETSc as _PETSc
                               create_vector, set_bc)
msh = create_unit_cube(MPI.COMM_WORLD,
                       1,1,1,
                       CellType.tetrahedron, GhostMode.none)
u_element=ufl.VectorElement("DG", ufl.tetrahedron, 1)
A_element=ufl.FiniteElement("N1curl",ufl.tetrahedron,1)
P_element=ufl.FiniteElement("DG",ufl.tetrahedron,0)
TH= ufl.MixedElement([u_element, A_element,P_element])
W =fem.FunctionSpace(msh,TH)
W0,map0=W.sub(0).collapse()
W1,map1=W.sub(1).collapse()
W2,map2=W.sub(2).collapse()
(unv,Anv,Pn)=ufl.TrialFunctions(W)   #
(v,fai,q)=ufl.TestFunctions(W)       #
un=fem.Function(W0)
def initial_u(x):
    values=np.zeros((3,x.shape[1]))
    values[0,:]=2    #y
    values[1,:]=2    #z
    values[2,:]=2    #x
    return values
un.interpolate(initial_u)
An=fem.Function(W1)
def initial_A(x):
    values[0,:]=3       #z
    values[1,:]=3       #0
    values[2,:]=3       #y
    return values
An.interpolate(initial_A)
P=fem.Function(W2)
def initial_P(x):
    values=np.zeros((x.shape[1]))
    return values
P.interpolate(initial_P)
def local_u(x):
    return np.isclose(x[1],0)
def u_D(x):
    values[0,:]=0
    values[1,:]=0
    values[2,:]=0
    return values
Vh=fem.FunctionSpace(msh,u_element)
u_boundary = Function(W0)
u_boundary.interpolate(u_D)
facets = locate_entities_boundary(msh,2, local_u)
dofs = locate_dofs_topological((W.sub(0), W0), 2, facets)
bc0 = dirichletbc(u_boundary, dofs, W.sub(0))
print('facets is',facets)
bcs=[bc0]
print('un initial is',un.x.array)
set_bc(un.vector,bcs)
print('un last is',un.x.array)
print('dofs is',dofs)
Do I have any other mandatory measures besides adding a penalty item in the weak form?
Many Thanks!
If there is relevant information, it would be even better!
A DG element does not have any dofs associated with its, facets, thus, locate_dofs_topological will always be empty.
A dof is associated with a facet would mean that the degree of freedom is shared with all other cells that has this facet. If you instead use locate_dofs_geometrical:
from dolfinx.fem import (Function, dirichletbc,
                         locate_dofs_geometrical)
from dolfinx.mesh import (CellType, GhostMode, create_unit_cube)
from dolfinx.fem.petsc import (set_bc)
                       1, 1, 1,
                       CellType.tetrahedron, ghost_mode=GhostMode.none)
u_element = ufl.VectorElement("DG", ufl.tetrahedron, 1)
A_element = ufl.FiniteElement("N1curl", ufl.tetrahedron, 1)
P_element = ufl.FiniteElement("DG", ufl.tetrahedron, 0)
TH = ufl.MixedElement([u_element, A_element, P_element])
W = fem.FunctionSpace(msh, TH)
W0, map0 = W.sub(0).collapse()
W1, map1 = W.sub(1).collapse()
W2, map2 = W.sub(2).collapse()
def local_u(x):
    return np.isclose(x[1], 0)
def u_D(x):
    values = np.zeros_like(x, dtype=_PETSc.ScalarType)
    values[0, :] = 1
    values[1, :] = 2
    values[2, :] = 3
    return values
dofs = locate_dofs_geometrical((W.sub(0), W0), local_u)
bcs = [bc0]
un = Function(W)
print(f'un initial is {un.x.array}')
set_bc(un.vector, bcs)
print(f'un last is {un.x.array}')
print(f'{dofs=}')
