if I have discontinuous Neumann boundary data, but I guess that FEniCS interpolates these data with a Courant function (that is continuous). This leads to difficulties, for example, the solution to the following problem is u(x,y) = x and should be computed exactly. But the algorithm does not lead to the exact solution. Can I circumvent this issue? Best regards, Johannes
mesh = UnitSquareMesh(4,4)
f = Expression(‘x[0]’,degree = 1)
u_exact = Expression(‘x[0]’,degree = 1)
g = Expression(’-(x[0]<=0.000000000001)+(0.99999999999999<=x[0])’,degree = 0)
V = FunctionSpace(mesh,‘P’,1)
a = (dot(grad(u),grad(v)) + uv)dx
L = fvdx + gvds
u_h = Function(V)
solve(a == L, u_h)
error = assemble((u_exact-u_h)**2*dx)
print(error)
