I am solving the problem
-\kappa\nabla^2u=f in \Omega
with Dirichlet boundary conditions on left and right boundaries and Neumann boundary conditions on top, bottom and middle boundaries. The domain \Omega is made of \Omega_{\mathrm{left}} and \Omega_{\mathrm{right}} and \kappa varies with subdomain such that \kappa_{\mathrm{left}}=0.1 and \kappa_{\mathrm{right}}=1.
The goal is to enforce a discontinuity in u in the middle boundary while also allowing for variation of \kappa in each subdomain. I’m using Discontinuous Galerkin with interior penalty numerical fluxes (modified).
We have, at the middle boundary
-\kappa \nabla u = D0 [[u]]
where [[u]] is jump(u, n)
I am obtaining the right jump in the middle boundary, but I am not obtaining variation of the slope in each subdomain. Can someone help debug my formulation below:
D0 = 4000
U0 = ufl.as_vector((0.66, 0.66, 0.66))
α = 100
γ = 1e5
F = inner(Κ * grad(u), grad(v)) * dx
# Add DG/IP terms
F += - inner(avg(grad(v)), jump(u, n)) * dS
F += - inner(jump(v, n), avg(grad(u))) * dS
F += γ / h_avg * inner(jump(v, n), jump(u, n)) * dS
# Nitsche boundary terms
F += - Κ * v * inner(grad(u), n) * ds(left)
F += - Κ * v * inner(grad(u), n) * ds(right)
F += - g * v * ds(insulated)
F += - Κ * (u - u_left) * inner(grad(v), n) * ds(left)
F += - Κ * (u - u_right) * inner(grad(v), n) * ds(right)
F += -h / α * u * inner(grad(v), n) * ds(insulated)
F += α / h * (u - u_left) * v * ds(left)
F += α / h * (u - u_right) * v * ds(right)
# Middle boundary
F += + inner(avg(grad(v)), 1 / D0 * (Κ * grad(u))('-') - U0) * dS(middle)
F += + inner(jump(v, n), avg(Κ * grad(u))) * dS(middle)
F += - γ / h_avg * inner(jump(v, n), 1 / D0 * (Κ * grad(u))('+') - U0) * dS(middle)
# Source term
F += -f * v * dx
The rest of the MWE code is below, and includes mesh generation steps.
import os
import warnings
from dolfinx import cpp, default_scalar_type, fem, io, mesh, nls, plot
from dolfinx.fem import petsc
from dolfinx.nls import petsc as petsc_nls
from dolfinx.geometry import bb_tree, compute_collisions_points, compute_colliding_cells
from ufl import (Circumradius, FacetNormal, SpatialCoordinate, TrialFunction, TestFunction,
dot, div, dx, ds, dS, grad, inner, grad, avg, jump)
import commons, geometry, utils
warnings.simplefilter('ignore')
out_mesh = meshio.Mesh(points=mesh.points,
cells={cell_type: cells},
cell_data={"name_to_read": [cell_data]}
if prune_z:
out_mesh.prune_z_0()
return out_mesh
if __name__ == '__main__':
# facet labels
left = 0
right = 2
middle = 3
insulated = 4
# subdomain labels
left_domain = 0
right_domain = 1
encoding = io.XDMFFile.Encoding.HDF5
LX = 50e-6
LY = 250e-6
points = [
(0, 0, 0),
(0.5 * LX, 0, 0),
(LX, 0, 0),
(LX, LY, 0),
(0.5 * LX, LY, 0),
(0, LY, 0),
gpoints = []
lines = []
gmsh.model.add('full-cell')
# gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 0.1 * micron)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.5e-6)
for idx, p in enumerate(points):
gpoints.append(
gmsh.model.occ.addPoint(*p)
gmsh.model.occ.synchronize()
for idx in range(0, len(points)-1):
lines.append(
gmsh.model.occ.addLine(gpoints[idx], gpoints[idx+1])
lines.append(
gmsh.model.occ.addLine(gpoints[-1], gpoints[0])
lines.append(
gmsh.model.occ.addLine(gpoints[1], gpoints[4])
ltag = gmsh.model.addPhysicalGroup(1, [lines[-2]], left)
gmsh.model.setPhysicalName(1, ltag, "left")
rtag = gmsh.model.addPhysicalGroup(1, [lines[2]], right)
gmsh.model.setPhysicalName(1, rtag, "right")
evptag = gmsh.model.addPhysicalGroup(1, [lines[idx] for idx in [-1]], middle)
gmsh.model.setPhysicalName(1, evptag, "middle")
insultag = gmsh.model.addPhysicalGroup(1, [lines[idx] for idx in [0, 1, 3, 4]], insulated)
gmsh.model.setPhysicalName(1, insultag, "insulated")
left_loop = gmsh.model.occ.addCurveLoop([lines[idx] for idx in [0, 6, 4, 5]])
right_loop = gmsh.model.occ.addCurveLoop([lines[idx] for idx in [1, 2, 3, 6]])
left_phase = gmsh.model.occ.addPlaneSurface([left_loop])
right_phase = gmsh.model.occ.addPlaneSurface([right_loop])
gmsh.model.addPhysicalGroup(2, [left_phase], left_domain)
gmsh.model.addPhysicalGroup(2, [right_phase], right_domain)
gmsh.model.mesh.generate(2)
gmsh.write("mesh.msh")
gmsh.finalize()
mesh_2d = meshio.read("mesh.msh")
tria_mesh = create_mesh(mesh_2d, "triangle")
meshio.write("triangles.xdmf", tria_mesh)
line_mesh = create_mesh(mesh_2d, "line")
meshio.write("lines.xdmf", line_mesh)
# simulation
comm = MPI.COMM_WORLD
with io.XDMFFile(comm, "triangles.xdmf", "r") as infile3:
domain = infile3.read_mesh(cpp.mesh.GhostMode.none, 'Grid')
ct = infile3.read_meshtags(domain, name="Grid")
tdim = domain.topology.dim
fdim = tdim - 1
domain.topology.create_connectivity(tdim, fdim)
ft_imap = domain.topology.index_map(fdim)
num_facets = ft_imap.size_local + ft_imap.num_ghosts
indices = np.arange(0, num_facets)
values = np.zeros(indices.shape, dtype=np.intc) # all facets are tagged with zero
with io.XDMFFile(comm, "lines.xdmf", "r") as infile2:
ft = infile2.read_meshtags(domain, name="Grid")
values[ft.indices] = ft.values
meshtags = mesh.meshtags(domain, fdim, indices, values)
domaintags = mesh.meshtags(domain, domain.topology.dim, ct.indices, ct.values)
dx = ufl.Measure("dx", domain=domain, subdomain_data=domaintags)
ds = ufl.Measure("ds", domain=domain, subdomain_data=meshtags)
dS = ufl.Measure("dS", domain=domain, subdomain_data=meshtags)
V = fem.FunctionSpace(domain, ("DG", 1))
u = fem.Function(V)
u.name = "potential"
n = ufl.FacetNormal(domain)
h = ufl.CellDiameter(domain)
h_avg = avg(h)
f = fem.Constant(domain, PETSc.ScalarType(0))
g = fem.Constant(domain, PETSc.ScalarType(0))
voltage = 1000e-3
u_left = fem.Function(V)
with u_left.vector.localForm() as u0_loc:
u0_loc.set(0)
u_right = fem.Function(V)
with u_right.vector.localForm() as u1_loc:
u1_loc.set(voltage)
# domain-varying parameter
Κ = fem.Function(V)
cells_left = ct.find(left_domain)
cells_right = ct.find(right_domain)
Κ.x.array[cells_left] = np.full_like(cells_left, 0.1, dtype=default_scalar_type)
Κ.x.array[cells_right] = np.full_like(cells_right, 1, dtype=default_scalar_type)
# constant for kinetics with -K * inner(grad(u), n) = D0 * (jump(u, n) - U0)
D0 = 4000
α = 100
γ = 1e5
# Add DG/IP terms
# Middle boundary
# Source term
F += -f * v * dx
# problem and solution
problem = petsc.NonlinearProblem(F, u)
solver = petsc_nls.NewtonSolver(comm, problem)
solver.convergence_criterion = "residual"
solver.maximum_iterations = 5
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
n_iters, converged = solver.solve(u)
with VTXWriter(comm, "potential.bp", [u], engine="BP4") as vtx:
vtx.write(0.0)
