Discrepancy Between Direct and Iterative Solvers
Hi everyone,
I am currently comparing the performance of direct and iterative solvers in my code, but I am encountering an issue where the iterative solver does not produce the same results as the direct solver.
Has anyone experienced a similar issue or have any suggestions on what might be causing the discrepancy?
Here is my code with iterative solver:
import pyvista
import math
from dolfinx.fem import (Constant, Function, functionspace, assemble_scalar, dirichletbc, form, locate_dofs_geometrical,
                         locate_dofs_topological, assemble, locate_dofs_topological)
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc, LinearProblem
from dolfinx.io import XDMFFile, VTXWriter, gmshio
from dolfinx.mesh import create_unit_square, locate_entities, meshtags, locate_entities_boundary, create_box, CellType
from ufl import (FacetNormal, Identity, TestFunctions, TrialFunctions,
                 div, dot, dx, inner, lhs, nabla_grad, rhs, sym, indices, as_tensor, Measure, split, action,
                 SpatialCoordinate)
import time
start = time.time()
Fl = 1e-8
Fs = 1e-5
Fp = 1e-4
C_star = Fl ** 2 / Fs
h_star = 1 / Fl
mu_star = Fp / Fs
perm_star = Fp ** 2 / Fs
q_star = Fp / (Fs * Fl)
mo_star = Fp / (Fl ** 2)
diff_star = 1 / (Fl ** 2)
p_star = Fl ** 3
F_star = Fs
# ......................................... Parameters
E = 1 * 152e9 * C_star
nu = 0.33
la = E * nu / ((1 + nu) * (1 - 2 * nu))
mu = E / (2 * (1 + nu))
perm = 146.6e-9 * perm_star
epsilon = 11e-9
non_local = 10e-9 / Fl
mu11 = 0.5 * 121e-6 * mu_star
mu12 = 0.5 * 121e-6 * mu_star
mu44 = 0.0 * mu_star
# ......................................... Reading mesh file
h = 0.76e-3 / Fl
H = 0.76e-3 / Fl
mesh = create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([h, h, h])],
                  [10, 10, 10], cell_type=CellType.hexahedron)
# ......................................... Define Loading
Force = 200.00000 / Fs
Area1 = 7.398400000000025e-06 / Fl ** 2  # Bottom
Area2 = 1.2769000000000007e-06 / Fl ** 2
tr_S1 = Constant(mesh, ScalarType((0, 0, Force / Area1)))  # Bottom
tr_S2 = Constant(mesh, ScalarType((0, 0, -Force / Area2)))
NN = Constant(mesh, ScalarType((1.0, 1.0, 1.0)))
# ......................................... Define Elements
v = element("Lagrange", mesh.basix_cell(), 2, shape=(mesh.geometry.dim,))  # Displacement Element
s = element("Lagrange", mesh.basix_cell(), 1, shape=(3, 3))  #
lm = element("Lagrange", mesh.basix_cell(), 1, shape=(3, 3))
p = element("Lagrange", mesh.basix_cell(), 1)  #
# ......................................... Define mixed element
MIXEL = mixed_element([v, s, lm, p])
Space = functionspace(mesh, MIXEL)
# ......................................... Define Trail and Test Functions
(u, gradu, lamu, p) = TrialFunctions(Space)
(del_u, del_gradu, del_lamu, del_p) = TestFunctions(Space)
# ....................................... Mark boundary regions
tol = 1e-16
def Bottom(x):
    return np.isclose(x[2], 0, atol=tol)
# ....................................... ds
boundaries = [(1, lambda x: np.isclose(x[2], 0.0, atol=tol)), (2, lambda x: np.isclose(x[2], H, atol=tol))]
fdim = mesh.topology.dim - 1
    facets = locate_entities(mesh, fdim, locator)
    facet_indices.append(facets)
facet_tag = meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = Measure("ds", domain=mesh, subdomain_data=facet_tag)
# ....................................... BCs
S0, S0_to_Space = Space.sub(0).collapse()
# Clamp BC for left side
clamp = Function(S0)
clamp.x.array[:] = 0
clamp_facets = locate_entities_boundary(mesh, mesh.topology.dim - 1, Bottom)
# .........Fixed BC
clamp_dofs = locate_dofs_topological((Space.sub(0), S0), mesh.topology.dim - 1, clamp_facets)
bc0 = dirichletbc(clamp, clamp_dofs, Space.sub(0))
# # .........Ground BC
P0, P0_to_Space = Space.sub(3).collapse()
ground = Function(P0)
ground.x.array[:] = 0
ground_facets = locate_entities_boundary(mesh, mesh.topology.dim - 1, Bottom)
ground_dofs = locate_dofs_topological((Space.sub(3), P0), mesh.topology.dim - 1, ground_facets)
bc1 = dirichletbc(ground, ground_dofs, Space.sub(3))
bc = [bc0, bc1]
# ......................................... Define tensor
delta = Identity(len(u))
i, j, k, l, m, n = indices(6)
# Strain Tensor
def StrainT(u):
    return as_tensor((1. / 2. * (u[i].dx(j) + u[j].dx(i))), [i, j])
VarForm = ((la * delta[i, j] * delta[k, l] + 2. * mu * delta[i, k] * delta[j, l]) * StrainT(u)[k, l]) * StrainT(del_u)[i, j] * dx - lamu[j, k] * del_u[k].dx(j) * dx
VarForm += -perm * delta[i, j] * (-1 * nabla_grad(p))[j] * (-1 * nabla_grad(del_p)[i]) * dx
VarForm += (mu11 * gradu[j, j].dx(i) + 2 * mu12 * gradu[j, i].dx(j)) * (-1 * nabla_grad(del_p)[i]) * dx
VarForm += (-mu11 * (-1 * nabla_grad(p))[i] * delta[j, k] - 2 * mu12 * (-1 * nabla_grad(p))[j] * delta[i, k]) * (1. / 2. * (del_gradu[k, j].dx(i) + del_gradu[j, k].dx(i))) * dx
VarForm += (non_local ** 2) * ( la * gradu[l, l].dx(i) * delta[j,k] + 2* mu * gradu[j, k].dx(i)) * (1. / 2. * (del_gradu[k, j].dx(i) + del_gradu[j, k].dx(i))) * dx
VarForm += lamu[j, k] * del_gradu[j, k] * dx + del_lamu[j, k] * u[k].dx(j) * dx + del_lamu[j, k] * gradu[j, k] * dx
# ......................................... Preparing the form
a = VarForm
L = tr_S2[i] * del_u[i] * ds(2)
#.................................................SOLVER
bilinear_form = form(a)
linear_form = form(L)
A = assemble_matrix(bilinear_form, bcs=bc)
b = assemble_vector(linear_form)
apply_lifting(b, [bilinear_form], [bc])
b.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)  # if run in parrallel
set_bc(b, bc)
b.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A)
solver1.setType(PETSc.KSP.Type.CG)
pc1 = solver1.getPC()
pc1.setHYPREType("boomeramg")
Result = Function(Space)
solver1.solve(b, Result.vector)
print(solver1.getConvergedReason())
Displ, DisGrad, LaMA, potent = Result.split()
uf = Displ.collapse()
pot = potent.collapse()
# ......................................... Export Results
with VTXWriter(mesh.comm, ("DIS.bp"), [uf]) as vtx:
    vtx.write(0.0)
with VTXWriter(mesh.comm, ("POT.bp"), [pot]) as vtx:
    vtx.write(0.0)
end = time.time()
print('Time', end - start)
and for solving with Direct solver, I use:
# problem = LinearProblem(a, L, bcs=bc,
#                         petsc_options={"ksp_type": "preonly", "pc_type": "lu",
#                                        "pc_factor_mat_solver_type": "mumps"})  #, "mat_mumps_icntl_24": 1, "mat_mumps_icntl_25": 0})
# Result = problem.solve()
That is a very broad question. On top of that, it’s quite hard to guess from your code what problem you are actually solving, so don’t expect that many people in the community will be able to give precise answers.
Speaking from myself as a layman, are you really sure that your VarForm gives an A which is symmetric positive definite? If not, you’d be in trouble in applying CG.
Quickly looking at the complicated expression, I wouldn’t vouch on that.
Start with ensuring that you get the same result when calling:
solver1.setType("preonly")
pc1.setType("lu")
pc1.setFactorSolverType("mumps")
as with your CG/hypre-boomeramg setup.
Secondly, you can add:
def monitor(ksp, it, rnorm):
    print(f"iteration: {it} rnorm: {rnorm:.3e}")
solver1.setMonitor(monitor)
to look at the progress of your solver.
Please note that AMG is more efficient when supplied relevant near null spaces, see: BoomerAMG — hypre 2.31.0 documentation
As @francesco-ballarin and @dokken have already stated, iterative solvers should not be used as a “black box” for solving linear systems. You need to carefully choose the non-stationary method and appropriate preconditioner based on the properties of the discretised operator. And your system at a glance does not look symmetric positive definite.
Thank you all for your replies. I have begun checking my variational form term by term and noticed that it is not symmetric. After some research, I found that the Pardiso solver, which is based on LU decomposition, is recommended as a good iterative solver for my problem. Is it possible to use the Pardiso solver in FEniCSx?
If you have installed PETSc with Paradiso support you can use the following options: MATSOLVERMKL_PARDISO — PETSc v3.21.2-331-g20d74df88af documentation
Please note that it is a direct solver, not an iterative solver.
